Watercooling Advice for a n00b
Discussion in 'Hardware' started by legoman, 25 Jan 2012.
  1. legoman
    legoman breaker of things
    28 Feb 2010
    Looking to add some wet stuff to my system in the nex month or so to quieten it down mainly.
    Case is a Lancool K62 which has 2x140mm fans in the roof a 120mm exhaust and 140mm intake.
    Initially i was looking to just do the CPU but now im tempted to add the GPU into the loop as well.
    my CPU is an AMD 960BE with 6 cores at a max daily clock of 3.8Ghz. I use C&Q as i dont need all the power all the time so idle is around 26C load 55C with ambient of 18C.
    GPU is a AMD 6950 2GB. This is the ASUS Direct CU one so its more similar to a 6970 in board spec
    Can someone advise me on rads to cool both in my loop? im confused on cooling capacities etc of these
    The only constraint is have is the roof rad would need to be a slimline one like the GT Stealth so it sits flush in the roof space with fans Bar that im pretty flexible as to what ill fit. I just dont know cooling capacities of radiators and the like. Any advice?
  2. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Monsta 360 gets good reviews
  3. Parge
    16 Jul 2010
    Regarding your 6950 - as its the direct CU version which has a different PCB layout, I'm not sure youll be able find a waterblock that'll fit it.
  4. zulu9812
    zulu9812 What's a Dremel?
    21 Oct 2010
    Yep, I ran that card through EK's compatibility configurator and they don't do a water block for that card. I'm not sure anyone else does either. And, to be honest, a big reason to buy that card in the first place is the monster air cooler on it.
  5. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Edit: retract as is far too big for you.
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Derp = 9000
    :p
    Have a read through my thread (link in sig) as its great for people starting out
  7. legoman
    28 Feb 2010
    Thanks for that parge, didnt realise they had one! So looks like ill just be doing the CPU in the loop. Rad wise its going to be a GT stealth 280mm. Block wise im going to use an EK Supreme. Only snag is the pump and res. I was looking to use a single bay res with something like a 200Lph pump. Would that give enough pressure or should I go up to a 400?
