Cooling Rasa CPU block
Discussion in 'Hardware' started by badman_mo007, 18 May 2010.
  1. badman_mo007
    badman_mo007 What's a Dremel?
    6 May 2010
    Has anyone used this block is it worth me changing from my V3 to this for better mounting?
    I think reviews say it beats the Heatkiller.
  2. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    which review were you looking at in particular ?
    I also have a heatkiller V3 block and been pretty pleased with it.
  3. badman_mo007
    6 May 2010
    Sorry i wasn't clear I currently have the XSPC Delta V3
    and here's the review I looked at: http://www.overclockerstech.com/xspc-rasa-cpu-water-block-review/1/
    According to that the rasa block beats the Heatkiller V3 by a few degrees.
  4. Big Elf
    23 Apr 2009
  5. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    The Rasa would be a step in the right direction ;)
  6. badman_mo007
    6 May 2010
    Thanks Nitrix, gonna look into it.
    Is there anything else in that that you would recommend over the Rasa?
  7. badman_mo007
    6 May 2010
    sorry accidently double posted...
  8. Big Elf
    23 Apr 2009
  9. aquatuning
    5 Jul 2006
    ^ theres your answer
    but bang for buck the Rasa is a good bet.
  10. Big Elf
    23 Apr 2009
    Also check out this mod. It got me just under 2ºC improvement but took me a few attempts to get it right as I found it difficult to use small amounts and keep it smooth. I used the silicone sealant you use for sealing sinks and baths. One warning though, leave it a few days to set properly. On my first attempt I just left it for 24 hours and it hadn't set fully and was a real pain to remove from the micro channels.
    http://skinneelabs.com/heatkiller-i7.html
    aquatuning likes this.
  11. aquatuning
    5 Jul 2006
    nice link - that could be something to have a look at
    +Reps
