Server Maintenance Today
Discussion in 'Feedback & Suggestions' started by jon4tron, 4 Apr 2015.
  1. jon4tron
    jon4tron Administrator Administrator
    25 Feb 2014
    There will be some bit-tech forums server maintenance today. You may notice a few blips, and the forums will be switched off for hopefully only a few minutes, in about an hour probably.
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    *Collapses due to potential Bit-Tech withdrawal*
    :p
  3. stevekez
    stevekez sysadmin Administrator
    2 Apr 2014
    Well, I think that's sorted everything.
  4. stevekez
    2 Apr 2014
    Big thanks to Jon for dealing with today's maintenance. This was the last planned major piece of maintenance for the forums.
    So, save for software updates, that should be the end of the planned maintenances for the foreseeable.
  5. jon4tron
    25 Feb 2014
    Big thanks to little Steve for saving the day and fixing everything :)
  6. Nexxo
    23 Oct 2001
  7. theshadow2001
    3 May 2012
    I've been getting 502's since maintenance when I log in to the user control panel
  8. jon4tron
    25 Feb 2014
    I'm just guessing what the issue, but just tried something, so is it fixed now?
  9. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    Both android and iOS Tapatalk seem to have issues logging in from the app... Anyone else have this issue?
  10. jon4tron
    25 Feb 2014
    Is it fixed now?
  11. theshadow2001
    3 May 2012
    Jon, I logged in today without issue. The problem seemed a bit intermittent so, I'll report back if there are any recurrences
  12. theshadow2001
    3 May 2012
    I have no issues with tapatalk, but I rarely seem to when others do. I'm using version 4.6.2
    Thanks for helping us out Jon btw :thumb:
  13. Teelzebub
    27 Nov 2009
    I had a 502 once but all seems good now
  14. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    All fixed thanks muchly
    Ian
  15. Nexxo
    23 Oct 2001
    Automatic picture resizing (in image upload) appears broken. It used to be able to resize images from my mobile as they uploaded; now it complains it can't and I have to resize manually.
  16. stevekez
    2 Apr 2014
    I suspect it was just the PHP GD library missing. Try it now?
  17. Nexxo
    23 Oct 2001
    Now I get:
    Computers, eh? :p
  18. stevekez
    2 Apr 2014
    So I'm gonna go ahead and ask Jonatron to fix that one, because I don't know where the folder location has been specified :blush:
  19. noizdaemon666
    15 Jun 2010
    If at first you don't succeed....delegate :p
  20. jon4tron
    25 Feb 2014
    Should be fixed now? :dremel:
