Memory Microsoft fudging RAM
Discussion in 'Hardware' started by enterobsidian, 9 May 2012.
  1. enterobsidian
    enterobsidian Hopless World Wonderer
    11 Apr 2011
    Hi Guys,
    It appears black magic has but found it's wicked way into the darkest depths of the place which should not be visited! And behold, it shall but attept to thwart my great steam goliath!
    Basically, I ordered 8GB (2x4GB) of DDR3 Corsair XMS3 to go with the existing 4GB (2x2GB. When it arrived this afternoon (I almost tore the hand off the woman delivering it) I was straight up the stairs to try it out. Plugged them in, changed the settings and fired up windows. Back did I sit, but to revel in my glorious 12GB of RAM, only to find that looking up My Computer specs reported that 12GB was installed and only 2GB was available. Checking Hardware Monitor gave me that all of 10GB was taken up by "Reserved for Hardware".
    So, rising to the challange, I did but pull new shiny new 8GB from the system, leaving the 4GB in the primary memory slots. This gave the following results in HM:
    I then tried moving the 8GB to the primary slots, which reported the full 8GB as being present, and only 14MB being used for hardware. (Sorry, forgot to get a shot)
    Installing the 4GB kit in the secondary slots took me back up to 12GB, but even then only 4GB was useable.
    I then installed another 8GB kit, which I had purchased for a friend, thinking that the 4GB was the problem. Surely 16GB would register and work, I thought. Nope:
    So I removed the second 8GB kit and refitted the 4GB kit, and booted windows. This showed some improvement, and here is what the system sits at currently:
    Same configuration as above, but now up to 7GB of useable space.....
    It registers that there is 12GB of RAM, so I don't think there is a problem with the board, but just incase: MSI 990XA-GD55
    Has anyone come across this before?
    Cheers
    Enterobsidian
    This isn't actually too far off me - :wallbash:
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Please tell me you're running 64-bit Windows? Else that'll be the cause right there and then.
    That or you're using Windows Basic, anything from Home Premium supports 16GB, up to "unlimited" for Windows Ultimate.
    Basically; Windows 32 Bit can only address up to 4GB of system memory (There may be a work-around to double this. I don't know.), Anything over that and it has difficulty accessing it, simply because the addressing scheme isn't long enough for it to note down the memory locations. (Same issue IPv4 is running into), so it limits some off. Not sure if it outright ignores it, or just shows it as "Hardware Reserved", not had a 32Bit machine with more than 4GB of memory to test that.
  3. enterobsidian
    11 Apr 2011
    Yes Windows & Professional, 64 bit. If It was 32 I would never have got 5GB of useable RAM. Cheers for pointing that out though, forgot to put it in!
    Cheers
    Enterobsidian
  4. .//TuNdRa
    12 Feb 2011
    Hrm... Try starting the machine in Safe-Mode, see if the information is any different there, it may be a driver going "NO! I NEED ALL THE MEMORIES!" on normal startup.
  5. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    are you running enough voltage through the sticks? Wrong, or too low volts could cause this quirky behaviour.
  6. .//TuNdRa
    12 Feb 2011
    Theoretically possible, but last time I was undervolting RAM; I just got constant BSOD's from where the memory just couldn't function.
  7. enterobsidian
    11 Apr 2011
    It's running 1.5v into 1.5v sticks of ram, I did wonder if that was a problem...
    Cheers
    Enterobsidian
  8. faugusztin
    11 Aug 2008
    If you see too many gigabytes in "Hardware reserved", then it is every time a hardware issue. That means one of the following options :
    - bent pins (this is typical to Intel boards, but you could have damaged one or more on AMD system as well)
    - overtightened CPU cooler, which bends the board
    - bad RAM modules
    - bad RAM contacts on either side of the DDR3 slot
    - not enough memory controller voltage, usually labeled Vtt (don't confuse it with the following item)
    - not enough memory voltage
  9. .//TuNdRa
    12 Feb 2011
    Try 1.55V, it's little enough that it won't damage the modules, and enough to combat the vdroop that can occur when running a full four modules. Sounds like a remove everything, clean and re-build job it that doesn't work, though.
  10. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    I had this kind of issue with my system when I built it, where only 4GB out of 8GB was available, other 4GB became hardware reserved. I swapped them around and made sure they were seated tightly and then I got the full 8GB :confused:
    Also make sure Hardware Remapping, or Memory Remapping whatever it's called in BIOS, is enabled too.
  11. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Give the CPU NB voltage a little bump if you have a Phenom II in there,this can help with 4 DIMM slots being populated.
  12. The_Crapman
    5 Dec 2011
    I'm surprised no one has mentioned this, but it's more than likely from running unmatched sticks. Especially 2x2gb and 2x4gb. It can sometime be ok, sometimes.....
  13. favst89
    favst89 What's a Dremel?
    23 Jul 2010
    I have seen something similar to this before. One of my friends had about 2GB reserved out of 6GB. It turned out he had set the memory for the system to use to be maximum.
    You can check this in msconfig -> 'boot' tab -> advanced options.
    Make sure the maximum memory option is not checked, even if it is written out to the correct value for your system.
    I doubt it is the issue for you as it is something you have to set but though it was worth mentioning.
  14. Guest-44432
    Guest-44432 Guest
    Have you updated the motherboard bios?
    Flash the bios with all the memory Dimms installed.:)
  15. Harlequin
    Harlequin Modder
    4 Jun 2004
    after 4 hours of gaming - with 8gb ram in my machine i still had 150mb of FREE ram - thats ram doing nothing at all.
  16. faugusztin
    11 Aug 2008
    What does your post have to do with the "Hardware Reserved" issue ?
  17. Harlequin
    Harlequin Modder
    4 Jun 2004
    what a polite person you are.....
    its to gain more of an understanding of how windows manages ram
  18. RevDarny
    RevDarny Minimodder
    27 Oct 2011
    I'd check the board can run that type of mixed RAM together and make sure the motherboard is configured correctly for that. Also like Truegamer said, make sure your BIOS is up to date.
    It's more than likely a hardware issue and not windows. This link may help you out though.
    http://support.microsoft.com/kb/978610/
  19. faugusztin
    11 Aug 2008
    But we are trying to fix a hardware problem, not "understand how Windows manages RAM". Or maybe i try to describe it better for you - OP had 4GB RAM. He inserted another 8GB RAM in his board. For hardware reasons, Windows (or any other OS) sees (can use) 2/4/7GB of RAM instead of 12GB. Free/Cached/Total/Available has nothing to do with the issue in this topic, we are trying to fix the "Hardware reserved" part.
  20. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Are you sure all the sticks are the same voltage?
