Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 19th Jul 2007, 22:44   #61
SPQQKY
Evil Modder
SPQQKY's Avatar
SPQQKY has yet to learn the way of the Dremel
Originally Posted by Glider View Post
It's all done CLI in that guide... So I don't understand what you need to uncheck...
Just exit X by doing
Code:
ctrl+alt+F1
sudo su
/etc/init.d/gdm stop
Then,
Code:
cp /etc/X11/xorg.conf /etc/X11/xorg.conf.backup
nano -w /etc/X11/xorg.conf
Search for the resolution line, alter it, save and exit
And restart XJust exit X by doing
Code:
/etc/init.d/gdm start
I don't have a clue as to anything you just posted....LOL.
EDIT: You see, it's crap like this.............
"If you wish to install the NVIDIA Linux graphics driver on a Debian GNU/Linux or Ubuntu system that ships with Xorg 7.x, please ensure that your system meets the following requirements:
* development tools like make and gcc are installed
* the linux-headers package matching the installed Linux kernel is installed
* the pkg-config and xserver-xorg-dev packages are installed
* the nvidia-glx package has been uninstalled with the --purge option and the files /etc/init.d/nvidia-glx and /etc/init.d/nvidia-kernel do not exist
If you use Ubuntu, please also ensure that the linux-restricted-modules or linux-restricted-modules-common packages have been uninstalled. Alternatively, you can edit the /etc/default/linux-restricted-modules or /etc/default/linux-restricted-modules-common configuration file and disable the NVIDIA linux-restricted kernel modules (nvidia, nvidia_legacy) via:
DISABLED_MODULES="nv nvidia_new"
Additionally, delete the following file if it exists:
rm -f /lib/linux-restricted-modules/.nvidia_new_installed"
.....that has kept me from using Linux and I already have a feeling I'm done with it. All this trouble for something that I cannot see offers me anything that Windows can't.
__________________
I could be bounded in a nutshell and count myself a king of infinite space, were it not that I have bad dreams.
Core2Duo E8400 @ 4GHz - Gigabyte GA-EP45-UD3P - 4 x 2 GB G.Skill Pi Black-6400C4 - eVGA GeForce GTX 260 - Auzentech X-Plosion
1 x 250GB and 2 x 300GB Barracuda - LaCie 1TB BD - Corsair CMPSU 620HX - etc., etc.
SPQQKY is offline   Reply With Quote
Old 19th Jul 2007, 23:14   #62
Glider
/dev/null
Glider's Avatar
Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.
Linux is a choice... and with a choice comes consequences... I think following guides like those is dead easy... They explain every step and every click... But that's a personal thing...
You should stick to Windows I guess...
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't
Glider is offline   Reply With Quote
Old 19th Jul 2007, 23:55   #63
SPQQKY
Evil Modder
SPQQKY's Avatar
There are no drivers available to support my card under linux it would appear, it's too new.
__________________
Old 20th Jul 2007, 00:58   #64
Glider
/dev/null
Glider's Avatar
nvidia has decent Linux support tough... ATI has next to none
__________________
Old 20th Jul 2007, 02:25   #65
SPQQKY
Evil Modder
SPQQKY's Avatar
After installing Envy, I got the drivers installed, but it still won't let me change to any resolution above 1024 and it dropped my refresh rate to 50hz. My eyes are bleeding now.
EDIT: Alas my monitor is at native resolution. I can now begin to comfortably get familiar with this OS. I may have some questions down the road, but I'll make a new thread when I do. Thanks all for your help.
EDIT # 2 : Update manager popped up and so I installed the updates, now I cannot boot to Ubuntu, I just get garbled text I cannot read. Here comes those "F&@k, $h17, d@mn1t to all 4e11!!!!"
__________________
Old 22nd Jul 2007, 05:29   #66
SPQQKY
Evil Modder
SPQQKY's Avatar
So I totally forgot that you have to reinstall drivers for the graphics card after updating the kernel. Luckily it was easy to fix with Envy installed. On second reboot I was able to read the error report, then it was simple to just type in the text only terminal envy -t. This let me first uninstall the nvidia drivers, then reinstall them and I was back in business. After a couple of shaky installs of needed codecs (thanks Ubuntu forums) for video playback and mp3 conversion, I am able to do what I originally wanted Linux for, multimedia. I'll stick with my Vista install for games (don't do much of it anyway until some of the new dx10 games are out), but it was actually a fun learning experience this time around.
__________________
Old 22nd Jul 2007, 11:56   #67
Glider
/dev/null
Glider's Avatar
Glad it starts to turn out for you, see, Linux isn't that Evil
__________________
Old 22nd Jul 2007, 15:07   #68
g3n3tiX
resident frenchy
g3n3tiX's Avatar
g3n3tiX has yet to learn the way of the Dremelg3n3tiX has yet to learn the way of the Dremelg3n3tiX has yet to learn the way of the Dremelg3n3tiX has yet to learn the way of the Dremelg3n3tiX has yet to learn the way of the Dremelg3n3tiX has yet to learn the way of the Dremel
Nice guide, I might turn to the penguin some day...
Where is VLC ??
__________________
With paracord and duct tape, one can get out of any situation. Except being out of either of them.
g3n3tiX is offline   Reply With Quote
Old 4th Aug 2007, 10:27   #69
Blind was Mingson
What's a Dremel?
Blind was Mingson has yet to learn the way of the Dremel
Originally Posted by SPQQKY View Post
Okay, must've been a bad download, I've got 7.04 32-bit installed now.
learn to md5, nub.
You might wanna try sabayon if you have a new computer. No use having linux without beryl.
Blind was Mingson is offline   Reply With Quote
Old 4th Aug 2007, 16:51   #70
IanW
Grumpy Old Git
IanW's Avatar
IanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming Saiyan
Ubuntu now comes with Beryl as standard. It's not enabled by default as some GFX cards don't like it. *cough*ATI*cough
__________________
i7 4770K@3.9GHz / Corsair H100i / Asus Maximus VI Gene / 16GB Corsair Vengeance 2133 /
Asus Strix GTX1080 Advanced / 500GB Samsung 840 Evo / 1TB Sandisk SSD / BeQuiet! 1kW /
Thermaltake Core V21 / Dell U2713HM / Corsair K70 RGB / Logitech Performance MX / Win10 / Kubuntu 17.04
IanW is offline   Reply With Quote
Old 5th Aug 2007, 03:51   #71
Tyinsar
6 screens 1 card since Nov 17 2007
Tyinsar's Avatar
Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.
I tried Beryl in Mepis on an ATI AIW 9600 - runs smooth
__________________
Regardless of what you believe there is someone at least as smart, or smarter, than you who believes something you think is stupid (and it's not just because you know something they don't).
Tyinsar is offline   Reply With Quote
Old 5th Aug 2007, 08:24   #72
IanW
Grumpy Old Git
IanW's Avatar
Yes, but to game as well requires ATi's proprietary driver "fglrx".
To use fglrx & Beryl together requires switching to the (extremely flaky) XGL video layer as fglrx doesn't have the required "Composite extension"
At least that was the situation I faced before my 9600XT died.
Which is why I'm saving my pennies for a shiny 8800GTS before reactivating Beryl.
__________________
Old 5th Aug 2007, 19:26   #73
Tyinsar
Tyinsar's Avatar
Well, that would explain it. I don't use Linux for games so I don't face that problem.
__________________
Old 7th Aug 2007, 03:55   #74
SPQQKY
Evil Modder
SPQQKY's Avatar
learn to md5, nub.
Why would I need beryl? I don't game with linux nor do I want much flashy stuff going on.
Suddenly, I can't see my ntfs drives any more. I had them mounted and used ntfs -config to enable writing, everything was fine but after a reboot I can no longer see them.
__________________
Old 7th Aug 2007, 06:43   #75
Glider
/dev/null
Glider's Avatar
learn to md5, nub.
It's exactly this attitude that makes Linux seem elite...
Sabayon is Gentoo based. Alltought it takes care of the install it's still Gentoo based.
Beryl on the other hand is nice and flashy for 10 minutes, and then it's a pain in the butt slowing things down...
__________________
Old 7th Aug 2007, 13:40   #76
SPQQKY
Evil Modder
SPQQKY's Avatar
learn to md5, nub.
Thanks Glider.......I know what md5 is too, the disk was supposedly fine. I redownloaded it and guess what, the second DL worked, but I've been using 32-bit just fine. As I posted above, don't need the flashy crap offered by beryl, it offers no functionality for me. Thanks for registering and making your first post a bash at me, you're the one acting like a nub....n00b, whatever....punk.
And my above problem was simple......
The last time I was in Winblows, explorer hung like a mofo, so I just hit the reset button. Because it wasn't a clean shutdown, Linux was smart enough not to mount the drives and all I had to do was go back to winblows and make sure it shut down cleanly.
__________________
Old 9th Aug 2007, 12:54   #77
Woodstock
So Say We All
Woodstock's Avatar
Woodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming Saiyan
i disagree, no use in having beryl
__________________
Hell hath no fury like a hippo with a machine gun.
i5-4670 | Asrock Q87M vPro | Corsair DDR3 16GB | 2x Intel 530 180GB | 9TB of misc spining disks | ATI 7870 | Corsiar something case | Dual boot ArchLinux and Windows 7 (aka game launcher)
Woodstock is offline   Reply With Quote
Old 23rd Aug 2007, 11:50   #78
D3s3rt_F0x
Hypermodder
D3s3rt_F0x has yet to learn the way of the Dremel
Nice guide considering trying out Linux soon on a spare PC I got knocking about and looks like evetrything I need to get cracking.
D3s3rt_F0x is offline   Reply With Quote
Old 23rd Aug 2007, 19:00   #79
IanW
Grumpy Old Git
IanW's Avatar
Actually, there is ONE use for Beryl/Compiz/whatever it's called this week:-
Shutting up the Vista fanbois talking about their Aero Glass interface!
__________________
Old 23rd Aug 2007, 22:07   #80
Woodstock
So Say We All
Woodstock's Avatar
yeah but no real use for it
__________________
Reply
Tags
*nix, gnu, linux, open source
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
