Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 1st Sep 2007, 01:21   #81
Modder
... has yet to learn the way of the Dremel
Not sure if this has been mentioned before, but in addition to getting live cd distros to test drive/play around with the OS, you can alternatively get VMWare player here, and download the OS/config of your choice here.
It is basically, as i understand it, an OS running within an OS, with minimal overheads, and you can run it as you would a proper install (as opposed to limited function in live cd)
I havent tried it, but i plan to do this when i delve into linux at some point, as it saves reformatting/reinstalling/dual booting again and again,. Gives you a dry run of the install on your pc, without any driver or other incompatibility issues.
If you want full control, you can purchase VMWare workstation, which allows you to install/configure an OS instead of downloading it.
Hope this helps in your foray into the world of linux
... is offline   Reply With Quote
Old 1st Sep 2007, 09:26   #82
Glider
/dev/null
Glider's Avatar
Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.Glider is definitely a rep cheat.
Or you can just get VMware Server, register for a key and do it all yourself with minimal overhead...
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't
Glider is offline   Reply With Quote
Old 1st Sep 2007, 18:14   #83
Blind was Mingson
What's a Dremel?
Blind was Mingson has yet to learn the way of the Dremel
Originally Posted by Woodstock View Post
yeah but no real use for it
You're kidding, right? You might as well say you couldn't use 4 monitors.
PS yall needs to chill.
Blind was Mingson is offline   Reply With Quote
Old 1st Sep 2007, 18:49   #84
Techno-Dann
Disgruntled kumquat
Techno-Dann's Avatar
Techno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the Dremel
Okay, here's another problem... I, being me, bought a Radeon HD 2900 XT. I'm running Mint (Ubuntu Feisty with codecs and such preinstalled), and trying to get fglrx to work. I've followed this guide as well as using envy, and both times, when I reboot X, I get a "fatal error: No screens found" error. Everything else appears to work without error messages, but X simply won't start. I go back and set xorg.conf to the older version, and it works fine.
I don't really care about OpenGL or Beryl performance, I just want to run my monitors at their native 1680x1050, and run both of them. Is there something in a config file I'm not changing, or do the drivers just not work for the 2900 yet?
Techno-Dann is offline   Reply With Quote
Old 1st Sep 2007, 20:51   #85
Woodstock
So Say We All
Woodstock's Avatar
Woodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming SaiyanWoodstock is a Super Spamming Saiyan
no im not kidding - is there a real need for "fancy" 3d effects, absolutely not. As it has been stated before Linux is about choice and freedom, fell free to make yours. TBH i dont think i need to chill i merely stated my opinion as has many others on these fourms before
__________________
Hell hath no fury like a hippo with a machine gun.
i5-4670 | Asrock Q87M vPro | Corsair DDR3 16GB | 2x Intel 530 180GB | 9TB of misc spining disks | ATI 7870 | Corsiar something case | Dual boot ArchLinux and Windows 7 (aka game launcher)
Woodstock is offline   Reply With Quote
Old 1st Sep 2007, 21:22   #86
Fophillips
Hypermodder
Fophillips's Avatar
Fophillips has yet to learn the way of the Dremel
I totally agree. Someone told me my fluxbox theme was "boring" today, so much they have to learn...
Fophillips is offline   Reply With Quote
Old 1st Sep 2007, 21:49   #87
Woodstock
So Say We All
Woodstock's Avatar
i hope you slapped em hard
__________________
Old 1st Sep 2007, 21:52   #88
Glider
/dev/null
Glider's Avatar
I usually impress them how fast, lightweight and functional my fluxbox is
__________________
Old 1st Sep 2007, 22:27   #89
Woodstock
So Say We All
Woodstock's Avatar
yeah i guess that would work to
__________________
Old 1st Sep 2007, 23:58   #90
Fophillips
Hypermodder
Fophillips's Avatar
A bit difficult over IRC
Old 2nd Sep 2007, 01:11   #91
Liquor Mortis
What's a Dremel?
Liquor Mortis has yet to learn the way of the Dremel
There are no drivers for the 2X00 series cards yet, one is promised "before the end of the year", see articles here.
Edit: Make that this coming week, same link.
Liquor Mortis is offline   Reply With Quote
Old 2nd Sep 2007, 04:43   #92
Woodstock
So Say We All
Woodstock's Avatar
no excuse man no excuse
__________________
Old 10th Sep 2007, 19:02   #93
D3s3rt_F0x
Hypermodder
D3s3rt_F0x has yet to learn the way of the Dremel
Great thread book marked for future reference when I can be bothered and have the time to get stuck into linux properly
D3s3rt_F0x is offline   Reply With Quote
Old 10th Sep 2007, 20:31   #94
Woodstock
So Say We All
Woodstock's Avatar
highly reccommened you do... soon/now
__________________
Old 10th Sep 2007, 20:36   #95
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the Dremel
He needs to buy a laptop first
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 10th Sep 2007, 21:03   #96
Woodstock
So Say We All
Woodstock's Avatar
ill acept that answer
__________________
Old 12th Sep 2007, 11:00   #97
Muaz
What's a Dremel?
Muaz has yet to learn the way of the Dremel
Hi, This post of mine is very knowledgable and may enhance the information of the viewers , however I would like some specific information for myself. If someone can help me then please send me a private message. Best Regards,
Muaz is offline   Reply With Quote
Old 12th Sep 2007, 11:29   #98
Glider
/dev/null
Glider's Avatar
YGPM
__________________
Old 13th Sep 2007, 23:17   #99
Faulk_Wulf
Internet Addict
Faulk_Wulf's Avatar
Faulk_Wulf has yet to learn the way of the Dremel
I was happy to stumble across this as I enjoyed all the articles on the main site quite thoroughly. With it I've tested my first server. Planning on writing some more in the coming months?
Love the work.
("YGPM" ?)
__________________
-- Faulken S. Wulf
"Under the Willow, he sleeps and dreams, of Heaven."
Looking over my threads, I've come to realize that I have a ridiculous amount of bad luck with my electronics.
Faulk_Wulf is offline   Reply With Quote
Old 14th Sep 2007, 08:50   #100
Glider
/dev/null
Glider's Avatar
If Brett asks me to do an other article, I'd be glad to do so. If you have an idea what to write it about, I'm open to suggestions.
YGPM = You got a private message
__________________
Reply
Tags
*nix, gnu, linux, open source
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
