Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 5th May 2017, 21:05   #481
Xlog
Supermodder
Xlog's Avatar
Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.
Originally Posted by lilgoth89 View Post
it seemed to run ok ( for a 'starter' gun ) until i had a MOSFET and High power motor installed by a friend ( who, while knowing more than me, mainly does HPA ) ever since then it has sounded a little bit sick. It likely only needs shimming and lubing and such, but i lack the knowledge and would prefer a competent set of eyes to help me put it back together myself
the plan is to simply throw a TM V2 gearbox in without the mosfet to get me going again
Lession learned, dont let clueless people ( including myself ) mess around with a gearbox
Have you tried adjusting motor height (usually a big screw in the bottom of a pistol-grip or hole for hex key)?
Originally Posted by crazyg1zm0 View Post
Mosfets, from my reading do need a high Torque low speed motor so im looking at an asg 22k motor for mine, at least when i drop in a LiPo from what i understand NiMH shouldn't change much. I have also been told there can be issues with the trigger contacts if they are not replaced too. Although the mosfet should in theory prevent most of that.
there are plenty of good guides on shimming you the youtubes, i would suggest if you do buy a new box to then use the old one as a learning tool and practice.
1. Good Mosfet/ECU itself wont care what motor you are running.
2. Even 22k originally would be considered "Hi-speed", because stock is usually 18k. Though nowadays its hard to find after market motors under 20k.
2. Unless your trigger contacts are damaged, don't bother replacing them. It wont impact performance with FET.
3. Imo, if your current motor is fine, you are better off investing into a Lipo. You'll get a lot better trigger response, increased ROF and so on. Rule of thumb is - don't bother with ECUs/wires/connectors/motors if you are running NiMH, the battery will be the weakest link (why are people even running NiMHs nowadays?). Plus Lipos are fun - they can act as smokebombs . If you don't want such fun - get a LiFe.
__________________
http://x-log.deviantart.com/
Xlog is offline   Reply With Quote
Old 8th May 2017, 09:16   #482
crazyg1zm0
Mod Master
crazyg1zm0's Avatar
crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.
Thanks for the great infomation.
And I only have a NiMh for now as it was the same 9.6v battery i have had for 10 years and i have spent the past few years out so i missed everyone starting to use LiPo's
Planning to order a couple of LiPo's shortly for it, just looking at options for what I want.
__________________
Originally Posted by GreatOldOne View Post
That just made me LOL my coffee over my keyboard....
Intel i7 2600k | Be Quiet Dark Rock Advanced | ASUS P8P67 pro | Patriot 1600 6GB | XFX 6870 Twin fan | corsair 650W | OCZ Vertex II 30gb | Samsung SP 1TB, Samsung 1.5TB, Samsung 500GB | Lian Li V-1000 | 2x23" screens
crazyg1zm0 is offline   Reply With Quote
Old 10th May 2017, 00:11   #483
lilgoth89
Captin Calliope
lilgoth89's Avatar
lilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyan
yeah, its the piston end of the gearbox that really sounds sick, and the gears are not shimmed as they can wobble, and i really dont have the experience to fix it. I have also heard that the ICS split gearbox is prone to being loud and isnt as good simply due to its design
so the current plan is to contact Firesupport and get a Marui gearbox and get THEM To install the Mosfet and rear wiring so i can just shove it straight into my gun and get onto a field ( travel accommodations permitting ).
__________________
I7 3770 @ 4.5Ghz | Asrock z77 extreme 6 | 16gb hyper X Ram 1600 | SfX7870 oc |Crucial 512 gb M4 | Samsung Spin point 2tb x2 | SiverStone Raven02 | Corsair Hx 850
lilgoth89 is online now   Reply With Quote
Old 10th May 2017, 08:00   #484
crazyg1zm0
Mod Master
crazyg1zm0's Avatar
Fire-Support should be able to happily sort you out there. they have a couple of complete gearboxes available I believe. I do love those guys, And miss living 30 mins from the shop.
As far as my G&G trigger install went... It was not good. got everything in and cables routed but the pinion shredded one of the battery connector wires due to space issues. Not overly impressed but theres not much i can do now. So got a couple of bits and bobs shipping from the states to fix the situation.
__________________
Old 11th May 2017, 08:34   #485
crazyg1zm0
Mod Master
crazyg1zm0's Avatar
My new LiPo for My M4 arrived yesterday for when my mosfet is working, and I cant get over how tiny it is compared to the old G&P 9.6v Ni-MH that i did have. Gotta love battery tech
__________________
Old 11th May 2017, 09:55   #486
Xlog
Supermodder
Xlog's Avatar
Yeh, thats the one of the quirks of V2 gearboxes, I hate working on them. First time I worked on one, I manage to route the cables only on my 3rd try.
__________________
Old 11th May 2017, 14:36   #487
crazyg1zm0
Mod Master
crazyg1zm0's Avatar
Yup. At first i started looking at trying to find a better Shell that would be easier but in the end just decided to go back to the original trigger and add the mosfet instead of trying to replace the trigger as well.
Maybe one day when I get another AEG (probably an M4 again) i will do it again. I also do quite want to try a polarstar system as they look interesting as hell.
__________________
Old 11th May 2017, 14:49   #488
liratheal
Sharing is Caring
liratheal's Avatar
liratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyan
I'm looking at a Polar* Jack for my M82. To either use it as a sniper rifle/DMR ~400fps, or to use it like a support weapon to irritate the WISWYG crowd.
__________________
Shadow Moses: Windows 10, Asus Sabertooth X58, 12gb Corsair XMS3, i7 950, Sapphire RX480 4gb, Corsair 1kw.
2008 Mondeo estate
Focus RS Mk1; Build number 1506
liratheal is online now   Reply With Quote
Old 11th May 2017, 15:15   #489
lilgoth89
Captin Calliope
lilgoth89's Avatar
HPA systems look great, but they have a very bad rep, either people find ways to turn them up after Chrono to get more power, or they crank up the rounds per second to crazy levels and hose people down at point blank range.
I wish that some sites would introduce rounds per second rules as well as feet per second, it would give support classes a reason to exist if they were the only class allowed high rates of fire and high cap mags XD
__________________
Old 11th May 2017, 15:41   #490
liratheal
Sharing is Caring
liratheal's Avatar
Yeah. As with most things, minority ruining something for the majority!
__________________
2008 Mondeo estate
Old 11th May 2017, 16:19   #491
Xlog
Supermodder
Xlog's Avatar
One way to get around this problem is to use gearbox as a busbar for one of the terminals. I even bolt FETs directly to the gearbox.
Increasing FPS is not something specific to HPA systems, especially with introduction of quick-change springs (even my AEG has adjustable fps). This sounds more like a lack of culture and respect for one another, than anything else. This can be usually solved by random chronys during the game and publicly banning players.
This is why i hate playing in some countries - lack of ban on hicaps and distinction between different weapons in general is maddening.
__________________
Old 14th May 2017, 09:43   #492
BeauchN
Hypermodder
BeauchN's Avatar
BeauchN is a Super Spamming SaiyanBeauchN is a Super Spamming SaiyanBeauchN is a Super Spamming SaiyanBeauchN is a Super Spamming SaiyanBeauchN is a Super Spamming SaiyanBeauchN is a Super Spamming SaiyanBeauchN is a Super Spamming SaiyanBeauchN is a Super Spamming SaiyanBeauchN is a Super Spamming SaiyanBeauchN is a Super Spamming SaiyanBeauchN is a Super Spamming Saiyan
Hiya, any recommendations for airsoft sites in or around London?
I used to play at Uni (about 15 years ago!), when Firefight ran game nights in Angel. I know the 'spiritual successor' of that event is Bunker 51 near Greenwich, but apart from that, I'm pretty much out the loop.
Cheers
__________________
ML08 | 6700k | Z170i Pro Gaming | 16GB 3000MHz LED RAM | NH-L9i | EVGA GTX 1070 FTW | 256GB Samsung PM961 | 512GB Vertex 4
BeauchN is offline   Reply With Quote
Old Today, 09:18   #493
crazyg1zm0
Mod Master
crazyg1zm0's Avatar
Cheers
Only one I can think of that i have been told about recently is Ultimate Airsoft, I think that was the name anyway.
Also in other news My m4 is back up and running, just need to chrono it and make sure its not too hot for the sites i can easily attend. And just grabbed an eotech 551 clone.
__________________
Reply
Tags
airsoft, airsoft in the head, mil-sim, say no to skimlinks, say yes to skimmed milk
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
