Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 20th Jul 2010, 15:07   #61
Ljs
Mod Master
Ljs's Avatar
Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.
Just had a quick little bash - my 7600gt didn't like it very much, neither did my crappy wireless connection (or I was just connecting to high latency servers).
Ljs is offline   Reply With Quote
Old 20th Jul 2010, 15:28   #62
murraynt
I Mod, Therefore I Own
murraynt's Avatar
murraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for president
Originally Posted by Ph4lanx View Post
Anyone fancy a partner? Add me. Catachan is my steam ID. Used to play this when it was a UT mod, so I know my way around
Done
murraynt is offline   Reply With Quote
Old 20th Jul 2010, 15:28   #63
murraynt
murraynt's Avatar
Originally Posted by smc8788 View Post
This game is fun
Add me on Steam if you want a game.
Also done
Old 20th Jul 2010, 17:24   #64
Sloth
#yolo #swag
Sloth's Avatar
Sloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming Saiyan
Steam name should be in sig, also in BT Steam group. Always ready for a game!
Game runs great for me, set everything to max and it's been no sweat for the 5870. Sounds like you might have some specific problems, PeteJ.
__________________
Intel i5 2500k | Gelid Tranquillo | ASUS P8P67 | G.Skill Ripjaws 8GB | XFX 7970 Black Edition | SeaSonic X650 | Intel X25-M 160GB | WD Caviar Black 1TB | CoolerMaster HAF922
Dell U2412M | 2x Samsung Syncmaster 931B | SteelSeries Siberia V2 | Razer DeathAdder 2013 | Leopold FC200RR/AB | Leopold FC200RC/AB
Sloth is offline   Reply With Quote
Old 20th Jul 2010, 17:39   #65
Threefiguremini
Supermodder
Threefiguremini's Avatar
Threefiguremini has yet to learn the way of the DremelThreefiguremini has yet to learn the way of the DremelThreefiguremini has yet to learn the way of the DremelThreefiguremini has yet to learn the way of the Dremel
I'm having trouble connecting to games. It starts loading then says something like "unsuccessful after 10 attempts". I've had a bash on the offline mode though. Good fun
Threefiguremini is offline   Reply With Quote
Old 20th Jul 2010, 18:05   #66
Ljs
Mod Master
Ljs's Avatar
I was getting the same actually - thought it might be my dodgy connection.
Old 20th Jul 2010, 18:41   #67
Threefiguremini
Supermodder
I'm fine on my other online games. Teething troubles I guess
Old 20th Jul 2010, 18:58   #68
murraynt
murraynt's Avatar
Mine running fine on a 4850 at 1680x1050 although often drops to 25 fps but is still perfect ally playable
Old 20th Jul 2010, 20:16   #69
Akava
Lurking...
Akava's Avatar
Akava has yet to learn the way of the DremelAkava has yet to learn the way of the DremelAkava has yet to learn the way of the DremelAkava has yet to learn the way of the DremelAkava has yet to learn the way of the DremelAkava has yet to learn the way of the Dremel
Played it for a while earlier, considering it is a free game it is pretty good, and so nice and simple too.
__________________
The Mini Rig: Samsung NC10
The Main Rig: Intel Core 2 Quad Q6600 ~ 3.0 | Artic Cooling Freezer 7 Pro | Asus P5E | 8GB OCZ Gold DDR2 1066MHZ | ATI HIS HD4870 | 640GB WD : 1TB WD | Coolermaster CM690 | Dell 2407 24" | Razer Lycosa | Razer DeathAdder
Akava is offline   Reply With Quote
Old 20th Jul 2010, 21:55   #70
Grimloon
Hypermodder
Grimloon's Avatar
Grimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpit
Originally Posted by Pete J View Post
This game rapes my GPUs. 107C
Anyone else finding it hitting their GPU hard?
Great fun though!
Holy whistling ducksht Batman! What are you doing to that poor machine?!
My 5850 is running it at 1920 x 1200 and hitting around 63C. I'll try it in 5040 x 1050 (if I can force it to that) once the bandwidth leeches (aka "younglings" or "spawn") have gone to bed.
Grimloon is offline   Reply With Quote
Old 21st Jul 2010, 00:47   #71
unknowngamer
here
unknowngamer's Avatar
unknowngamer can run Crysisunknowngamer can run Crysisunknowngamer can run Crysisunknowngamer can run Crysisunknowngamer can run Crysisunknowngamer can run Crysisunknowngamer can run Crysisunknowngamer can run Crysisunknowngamer can run Crysis
Great fun.
Up for a game anytime.
Steam: mega_bite
__________________
The ever changing system.... I7 920 (stock atm) XFX X58, 3x 2GB Obsidian OCZ, 2x GTX 280 SLi, NorthQ 850watt Giantconnector, WD 640GB and 1TB, Antec1200.
Cooling: laing ddc1+ xspc restop>Cupluex Di>XSPC 240 rad >dual EK GTX280 blocks with backplates> TFC 360rad (all internally mounted on the 1200)
unknowngamer is offline   Reply With Quote
Old 21st Jul 2010, 01:27   #72
Aracos
Ultramodder
Aracos's Avatar
Aracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run Crysis
I'm up for a game with anyone: storm20200
__________________
Originally Posted by Ubisoft CEO
Our clear goal today is to come more regularly with our top brands
Ragnarok: i5 750 @ 3200MHz | Titan Fenrir | MSI P55-GD65 | 8GiB Vengence 1600MHz CAS 9 | 1GiB 6950 DirectCU II | 60GB Crucial M4 | Samsung F3 500GB | Samsung F3 1TB | Seasonic X-750 | X-Fi XtremeGamer | HAF932 | Win 7 Pro | openSUSE
Aracos is offline   Reply With Quote
Old 21st Jul 2010, 02:42   #73
Idioteque
Telephasic Mongoose
Idioteque's Avatar
Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.
Great fun though!
How on earth is this stressing your GPU? This game runs on my 8800GTS 320MB on full graphics at 1920x1200 with 2xAA at ~50fps
Edit: Just realised you had Fermis... No wonder they be hot.
__________________
Dreams are the subconscious mind's way of reminding people to go to school naked, and have all their teeth fall out.
Idioteque is offline   Reply With Quote
Old 21st Jul 2010, 04:09   #74
erratum1
Banned
erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.
Great fun though!
Understandable with gtx 480, I think they can take the heat though. Its really warm in my spare room at the moment.
I don't do hardly any gpu overclocking when its like this, its just too damned hot, at least for air cooling anyway.
erratum1 is offline   Reply With Quote
Old 21st Jul 2010, 14:25   #75
themcman1
is now 110% win
themcman1's Avatar
themcman1 has yet to learn the way of the Dremelthemcman1 has yet to learn the way of the Dremelthemcman1 has yet to learn the way of the Dremel
It really is excellent, I promoted last night.
themcman1 is offline   Reply With Quote
Old 21st Jul 2010, 14:27   #76
Phalanx
Needs more dragons and stuff.
Phalanx's Avatar
Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.
Go into the options and disable the option for "autofind LAN games". I had the same issue, disabled that and it worked. Just turn it back on if you want to play on LAN
I need more corpsmen to join me in the campaign, people! Add me (my SteamID is in the website on my sig).
__________________
XBOX Live!: Ph4lanx | Steam: Catachan
I'm an author! ChrisDamico.co.uk
Phalanx is offline   Reply With Quote
Old 21st Jul 2010, 15:14   #77
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
I had that same issue, I'll give it a go tonight.
I'm still finding it a little hard to control tbh!
__________________
Ediface
Silverstone FT03 Mini - i7 4790S - Noctua NH-L9i - Gigabyte GTX 1070 'ITX Edition' - Maximus Impact VII - 16GB DDR3 - 1TB NVME - SF600 - AOC Agon AG271QG - Xonar U7 - Bassshaker - RAT3 - Majestouch Minila - Q90s - Orbweaver - Warthog
Parge is offline   Reply With Quote
Old 21st Jul 2010, 15:28   #78
Gunsmith
Maximum Win
Gunsmith's Avatar
Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.
its not quake, work with your squad mates and move up in pairs
__________________
The King of Crysis
// This is currently not used anywhere (David: and I don't see what this would be used for. Our hero is not Jesus).
m_stats.isWalkingOnWater = false;
Gunsmith is offline   Reply With Quote
Old 21st Jul 2010, 15:29   #79
smc8788
...at least I have chicken
smc8788's Avatar
smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.
What do you get when you get promoted?
smc8788 is offline   Reply With Quote
Old 21st Jul 2010, 15:44   #80
Phalanx
Phalanx's Avatar
You unlock more weapons/equipment/bragging rights
__________________
Reply
Tags
free, steam, valve
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
