Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 9th May 2017, 07:24   #3001
Kehoe
Multimodder
Kehoe's Avatar
Kehoe has yet to learn the way of the Dremel
So do you guys have a flight stick if so which one ? considering to get one as the one i've got is cramped to hold with two hands, so thinking of upgrading i've got a cyborg x controller and getting to all the buttons easily isnt fun.
Kehoe is offline   Reply With Quote
Old 9th May 2017, 08:05   #3002
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
I use a hotas, currently using a Saitek X55 Rhino however due to some issues with it I have managed to scrape enough to get a X56 should be spending the money on other stuff but I need a Hotas otherwise I cannot play Elite.
If you want to get a Hotas try the Thrustmaster one to start with as it's quite cheap and whilst not having a lot of buttons you can get the main essential buttons mapped on to it, and then if you like it you can move to something better and if you don't like a Hotas then it's not expensive.
You might be able to find it cheaper if you look around.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 9th May 2017, 15:58   #3003
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
+1 for the T.Flight HOTAS X.
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is offline   Reply With Quote
Old 9th May 2017, 16:36   #3004
fix-the-spade
Mod Master
fix-the-spade's Avatar
fix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyan
Another vote for T Flight X, it splits in the middle so you can have stick/throttle each side of the keyboard.
Or go nuts and get a CH Fighter Stick/Throttle or a Thrustmaster Warthog. There'll be no lack of control options then.
__________________
CMDR Fix-the-spade
fix-the-spade is offline   Reply With Quote
Old 9th May 2017, 17:40   #3005
IanW
Grumpy Old Git
IanW's Avatar
IanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming Saiyan
Some over on the Star Citizen side are swearing by a pair of T16000M sticks instead of a HOTAS.
__________________
i7 4770K@3.9GHz / Corsair H100i / Asus Maximus VI Gene / 16GB Corsair Vengeance 2133 /
Asus Strix GTX1080 Advanced / 500GB Samsung 840 Evo / 1TB Sandisk SSD / BeQuiet! 1kW /
Thermaltake Core V21 / Dell U2713HM / Corsair K70 RGB / Logitech Performance MX / Win10 / Kubuntu 17.04
IanW is offline   Reply With Quote
Old 9th May 2017, 19:48   #3006
damien c
Mad FPS Gamer
To be honest I started with the Tflight and eventually moved on to the X55 Rhino, because of the buttons and layout, that is why I have a X56 coming on Thursday.
The buttons have started to fail on the X55 but my dad who is getting the X55 of me is just going to pull it apart, and redo all the wiring in it using Prototyping Wire and Heat Shrink and then some self amalgamating rubber tape over the joints when needed.
I have everything mapped to my Rhino and don't need to touch the keyboard for anything unless I want to use the free cam which I very rarely do, or typing a message or system name, and my mouse get's used in the galaxy map but other than that everything is on the controller.
I will need to look at the bindings as they are abit all over the place but this is them currently.
https://www.mcdee.net/elite/binds/eeqrdt?replay=eeqrdt
__________________
Old 9th May 2017, 21:06   #3007
Kehoe
Multimodder
Kehoe's Avatar
been looking at the X56, kicking my self as we had these in stock at work and we are sold out and i cannot order one.
Might see how i get on with the game further before i spend £150+ for a controller i tried the Thrustmaster T-Flight Hotas X Joystick at work and i didnt like it, rather stick with my current set up than that.
Still feel very lost in this game lol
Old 9th May 2017, 21:29   #3008
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
I know quite a few of you have done this run already, but I finally made it out to Jaques Station... So good to be back civilisation after being "at sea" for nearly 4 weeks! Only about 6,000 LY to my destination.
..and then I have to get back!
I started bookmarking my journey legs after I'd already gone a good few thousand LY. Definitely have to install ESDM.
__________________
Old 11th May 2017, 18:25   #3009
Kehoe
Multimodder
Kehoe's Avatar
Not really found a way to make any cash fast, should i be looking to upgrade my current ship or save my cash get a new ship and upgrade that ?
I am loving the game it so different just lack of time to play atm.. and still overwhelmed lol
Old 12th May 2017, 09:47   #3010
adrock
Caninus Nervous Rex
adrock's Avatar
adrock is definitely a rep cheat.adrock is definitely a rep cheat.adrock is definitely a rep cheat.adrock is definitely a rep cheat.adrock is definitely a rep cheat.adrock is definitely a rep cheat.adrock is definitely a rep cheat.adrock is definitely a rep cheat.adrock is definitely a rep cheat.adrock is definitely a rep cheat.adrock is definitely a rep cheat.
It really depends on what you want to do. I'm trying to get back into it, so I've found a modest trade route I'm running, nets me $2m an hour or so, and I'm going to get enough cash together to buy and outfit an AspX and then go and try some of the engineer stuff.
Are you coming into it completely fresh (are you in a sidewinder?).
__________________
"send in the clowns" they said
"by all means try it, but do be prepared for the mass of blood and red noses, for i am in no mood for such twisted capers."
adrock is offline   Reply With Quote
Old 14th May 2017, 21:06   #3011
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Well... I made it. This is what I travelled over 32,000LY to see. Pretty uninspiring.
Now for the 26,000LY trip home... and I have 2 days left to do it to meet my passenger's timescales. Yeah, that ain't happening.
__________________
Old 15th May 2017, 11:57   #3012
Kehoe
Multimodder
Kehoe's Avatar
Just spent 3 Hours doing bountys for my ship to blow up as my joystick locked up and i couldn't react more annoying was it was before i claimed them lol, I am waiting for my X56 Rhino to arrive, ordered it on Sat, still not arrived , Cost me £120 so rather happy, just wish it would turn up.
Going to hold off playing any more until i get my new controller
Old 17th May 2017, 07:11   #3013
Kehoe
Multimodder
Kehoe's Avatar
My PC has gone belly up since this stupid windows 10 update, I need to reinstall the OS, If i do this will i loose my save ? as it says its online but it also seams to be local ??
Old 17th May 2017, 12:34   #3014
23RO_UK
Hasta Mañana
23RO_UK's Avatar
23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan
Your save is all server side so fear not
23RO_UK is offline   Reply With Quote
Old 17th May 2017, 13:09   #3015
damien c
Mad FPS Gamer
The only thing that is saved on your pc is the control settings and graphics settings which can be found here if you have it installed on your c drive.
C:\Users\Your Name\AppData\Local\Frontier Developments\Elite Dangerous\Options
Back up that folder and then when you reinstall the game, run it and close it and then copy this folder back over and all your controls etc will be like they were before you reinstalled it.
__________________
Old 17th May 2017, 14:28   #3016
Kehoe
Multimodder
Kehoe's Avatar
All reset and loaded, my X56 arrived just as id installed the game, Really need to sit and work out what the hell im doing the default program is god awful, think its a case of sit n read atm to work out where to put everything SOooooooooooooo many buttons lol
Old 17th May 2017, 14:43   #3017
damien c
Mad FPS Gamer
I have my x56 setup almost identically to how I had my X55 setup.
__________________
Old 17th May 2017, 15:04   #3018
Kehoe
Multimodder
Kehoe's Avatar
I only had a crappy controller had to use my keyboard for 90% of my things, Care to point me in the right direction, I've booked marked a youtube video im going to sit n watch n try to setup like theirs as the default one is awful
Old 18th May 2017, 06:42   #3019
damien c
Mad FPS Gamer
This is pretty much how I have it set up other than I am using the extra 2 hat switches for the free cam.
I will get the one later today for my X56 though.
__________________
Old 19th May 2017, 10:32   #3020
Kehoe
Multimodder
Kehoe's Avatar
Slowly setting my controller up when i get time then testing lol, have to have it onscreen as a guide, its like im having to relearn again, would appreciate the x56 plan copied allot of your X55 setup thou thanks allot it helped
Reply
Tags
aha! it's christmas time!, friendship drive charging, my god it's full of stars, parge is feathers!, say yes to skimmed milk
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
