Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 12th Aug 2013, 15:56   #41
notmeagain
Supermodder
notmeagain's Avatar
notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.
Originally Posted by saspro View Post
I find carrying something that looks nothing like a cig attracts a lot less attention than a small 510 battery & carto.
What's you budget for a new device?
Depends on longevity, I can get 3-4 months out of 5 atomisers and 6 or so a battery @ 30-40 a pop.
If i can get something that consistently holds a charge for that time frame, a battery that lasts most of the day (i get through 2-4ml a day), is economical and sleak... 70-100 for a complete new set up.
Considering it's saved me close to 1.5k since making the transition two years ago, I'm happy to continue investing.
notmeagain is offline   Reply With Quote
Old 13th Aug 2013, 09:13   #42
saspro
Infrastructure Specialist
saspro's Avatar
saspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyan
I'd say get a protank or two and a 1300ma battery. Although I'd still go for a vamo if it was me.
__________________
If what I've said helps you please remember to hit the rep button on the left
Missing the old meeting place? Find us here
saspro is online now   Reply With Quote
Old 13th Aug 2013, 09:49   #43
notmeagain
Supermodder
notmeagain's Avatar
Both look absolutely massive!
for an inhome solution that's fine, but i spend 30-40% of my day dashing from A-B.
Old 13th Aug 2013, 10:10   #44
saspro
saspro's Avatar
I use a vamo all the time, fits nicely in my trouser pocket (in both 18350 & 18650 modes) and the protank isn't very big.
All day lasting power means a big battery.
If you want smaller go for something like this. Cheap enough to buy a couple of them and last a good while.
__________________
Old 11th Sep 2013, 09:31   #45
docodine
killed a guy once
docodine's Avatar
docodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for president
docodine is offline   Reply With Quote
Old 12th Sep 2013, 00:16   #46
Ljs
Mod Master
Ljs's Avatar
Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.
Anyone recommend a decent kit for around 30? I find myself smoking more and more at the moment and I'm not getting any younger so would like to try and conver myself.
I've only had a try on the ones that are made to look like cigarettes and think I would prefer a proper one. New to all this so a bit lost. Would like something portable and upgradable (as you chaps seem to be suggesting changing bits on them).
Just been looking at an Ego-T Ce4... Any good?
Ljs is online now   Reply With Quote
Old 12th Sep 2013, 01:05   #47
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
I wouldn't buy the Ego as a kit. It's expensive. I would buy a good clearo/atomiser like this, along with some new coils.
http://www.ebay.co.uk/itm/1811935014...84.m1439.l2649
With 5 atomiser heads. You're looking around 12 or so. Then go to Ecigsoutlet and buy a battery for 10.99
http://www.ecigsoutlet.co.uk/index.p...ypage.tpl.html
http://www.ebay.co.uk/itm/Ego-Batter...item4176717e6c
^Charger.
Basically the atomiser that comes with the Ego is rubbish. A pain in the balls to fit and gives out sod all vape. Bottom coil atomisers to me have been the best as they prevent "dry burning" which is fookin rank. Plus with the one I listed you can replace the coils as a unit.
I would avoid getting batteries from Ebay as the last one I got fell apart in my fiancees hand. Ecigs do good quality batteries
AlienwareAndy is offline   Reply With Quote
Old 12th Sep 2013, 01:45   #48
Ljs
Mod Master
Ljs's Avatar
Sweet, thanks man. I really appreciate the help so I don't waste money on crap!
So if I buy all of the above it is all compatiable? Sorry, I really am new to all this stuff. Is it worth going for a variable voltage battery (I assume this controls the strength to a degree)?
Is it worth going for this Protank people have mentioned in this thread? I'm not in any rush (I have a stockpile of duty free) so shipping from the US isn't a major issue if it would be better to order it all from FastTech.
Another question (although I realise the answer is purely subjective), is what is a good starter liquid to use? How much do you guys generally go through (so I know how much to buy)? Any brands worth a shout over others? I'm was thinking apple flavour but I don't fancy anything to sweet and sickly (and some of the flavours I have seen sound a bit gross in that way).
Old 15th Oct 2013, 00:01   #49
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan
Howdy.
I got an E-lite starter kit via ZiiP almost a year ago and it was fine, but the refills were hard to find in Ireland when I first got it and getting them from England was a bit too costly for me.
Recently got a Liberty Flights eGo from my brother with all the necessary kit, some igniters, chargers, 3 spare batteries, bottle of liquid (50/50 mix) and a few other bits and pieces for about €60. Need to order in some wicks from a polish site he recommended.
Haven't had a cigarette in 2 weeks now and feeling good about it. Noticing the difference in most cases where I would have had them (drinking out, farmers market that I run) where I would churn through a pack as I don't smoke at home. I used to always just "smoke 'em if you got 'em."
Now, even the smell of a regular smoke is just rancid. Goal is to give up altogether.
__________________
ZiiP Gaming Community
Sui Generis: i7 5820K, Corsair H105, 16GB Kingston 2133, ASUS X99-S, Samsung 950 Pro 512GB M2, Samsung 850 1TB EVO, Corsair F3 120GB SSD & Samsung EVO 250GB SSD, MSI GTX 970, Corsair HX850W, Corsair Obsidian 800D, AOC 34", Logitech G15, Shogun Bros Ballista Mk-1, Corsair 1500.
[ZiiP] NaloaC is offline   Reply With Quote
Old 15th Oct 2013, 00:21   #50
notmeagain
Supermodder
notmeagain's Avatar
Originally Posted by [ZiiP] NaloaC View Post
Howdy.
Recently got a Liberty Flights eGo from my brother with all the necessary kit, some igniters, chargers, 3 spare batteries, bottle of liquid (50/50 mix) and a few other bits and pieces for about 60. Need to order in some wicks from a polish site he recommended.
If anything, the e-cigs are more habit forming/reinforcing.
I found that they broke up my regular cig breaks as I had the freedom to use them when/wherever, productivity went through the roof as I wasn't craving the fag breaks
Anyway, the best advise, stick to the 12-24mg strengths for a few weeks, and gradually ween yourself down to the 6's.
Stick to your routine, use it only when you would a normal cigarette, try not to justify to yourself that it's a healthier alternative as that will start to sink in subconsciously and reinforce your new addiction.
Trust me, been using E-cigs for almost 2 years now, and I started with the intention to "Quit" totally, and these are the traps I fell into.
I'm on week 3 of the 6mg fluids, with the aim to switch to low nicotine (2mg) tic-tacs next week, with a full removal of nicotine in my life within the month.
Old 18th Oct 2013, 20:07   #51
Grimloon
Hypermodder
Grimloon's Avatar
Grimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpit
I'd tried the cig-a-likes before (Elite, Skycigs) and just not really got on with them, the menthol ones are just way overkill and the tobacco ones just aren't anywhere near close. I've bought a kit from vapercaper (Kanger EVOD and 2 eGo Winder 1100 mah batteries) which seems to be hitting the spot. It feels a lot more like smoking a pipe than a rolly though, I'm not used to it yet.
I'm running a 19:1 mix of 70/30 12 mg cherry and menthol liquids at the moment which give a nice flavour without being too potent. I'm hoping to drop to a 6 mg liquid in the near future and will probably end up going down the homebrew route as it gives a few more options with strengths etc.
Grimloon is offline   Reply With Quote
Old 18th Oct 2013, 21:39   #52
Panomama
I once signed up on uniform dating
Panomama's Avatar
Panomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpit
I just ordered an ego V, CE9, ViVi Nova and Protank 2 from fasttech,
should be here by christmas.
My Vamo V3 got caught by customs and returned, the 18650 batteries are too expensive to buy in the UK.
Looking to get an itaste MVP2 aswell.
__________________
♦Steam♦ ⚔⚔⚔⚔ ♠Youtube♠ ⚔⚔⚔⚔ ♣Website♣
Panomama is offline   Reply With Quote
Old 19th Oct 2013, 18:15   #53
Apocalypso
Fully armed and operational.
Apocalypso's Avatar
Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!
I picked up a new Protank 2 and some Mrs B's Vanilla Custard from my local vape shop. I bought a starter kit about a month ago and haven't wanted a real cigarette once, in fact the smell is quite off putting.
Think I might look at a variable battery soon.
__________________
Intel Core i5 2500k | ASUS HD 7970 DirectCU II | 8GB Corsair XMS3 1600MHz | Crucial M4 128GB | F3 1TB x 2 | Asus Sabertooth P67 | Corsair HX1050 | HAF 932 | Dell U3011
EK Supreme HF | XSPC RX360 | Scythe AP-14's | MCP355
ARCAM rDAC | Matrix M-Stage | KRK RP5 G2 | KRK 10s | Beyerdynamic DT990 600Ω
Apocalypso is offline   Reply With Quote
Old 19th Oct 2013, 19:08   #54
Panomama
Panomama's Avatar
Howdy.
Only just realised that ZiiP is based in Cambridge
Anyone know the approximate delivery times to the UK from Fasttech?
I had a protank 2 on order along with my VamoV3, unfortunately that got caught because of the 18650s so I've ordered an Ego V instead.
It's been roughly 2 and a half weeks now and tracking still states 'Physical Item Received HONG KONG' since the 11th October.
__________________
Old 20th Oct 2013, 19:21   #55
slaw
At Argos buying "gold"
slaw's Avatar
slaw is definitely a rep cheat.slaw is definitely a rep cheat.slaw is definitely a rep cheat.slaw is definitely a rep cheat.slaw is definitely a rep cheat.slaw is definitely a rep cheat.slaw is definitely a rep cheat.slaw is definitely a rep cheat.slaw is definitely a rep cheat.slaw is definitely a rep cheat.slaw is definitely a rep cheat.
Hey, I have ordered twice from fast tech. The first order took about a month to get to me and my second order is a month and still waitin. Neit her of these orders had batteries or eliquid.
A friend ordered a vamo for himself and 2 weeks later ordered one for a friend and they both arrived last week. It took between 3-5 weeks. They were cheeky and wrapped the batteries in foil
__________________
Gigabyte GA-X58A-UD3R
Intel Corei7 920 @ 4GHz
12GB Corsair Dominator
GTX 480
slaw is offline   Reply With Quote
Old 20th Oct 2013, 19:54   #56
FuzzyOne
FuzzyOne's Avatar
FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!
Ego-T 2x1100mah and 2x600mah + Kanger Protank + Evod's
Not had a real cig since January
I order from Fast tech, as slaw said expect at least a 3 week wait
thealchemistscupboard.co.uk does some awesome juices, like parma violet flavour
__________________
FuzzyOne is offline   Reply With Quote
Old 21st Oct 2013, 00:47   #57
docodine
killed a guy once
docodine's Avatar
Old 21st Oct 2013, 12:33   #58
Andersen
Brain for hire
Andersen's Avatar
Andersen is the Cheesecake. Relix smiles down upon them.Andersen is the Cheesecake. Relix smiles down upon them.Andersen is the Cheesecake. Relix smiles down upon them.Andersen is the Cheesecake. Relix smiles down upon them.Andersen is the Cheesecake. Relix smiles down upon them.Andersen is the Cheesecake. Relix smiles down upon them.Andersen is the Cheesecake. Relix smiles down upon them.Andersen is the Cheesecake. Relix smiles down upon them.Andersen is the Cheesecake. Relix smiles down upon them.Andersen is the Cheesecake. Relix smiles down upon them.Andersen is the Cheesecake. Relix smiles down upon them.
Does anyone know of any ecig stores in London? New trip is being planned and I'd like to visit another B&M there.
Visited UK Ecig store on first trip and liked it. But any others?
Originally Posted by docodine View Post
that's a tiny battery apocalypso, how long does it last you?
Not for long, seems to be one of those 350mAh minis which might get a light vaper through a day. Others like me need one or two 2000mAh 18650 cells.
__________________
Too weird to live, and too rare to die | Help me get more space at Dropbox | Hardcore gamer and proud of it | Vape on
Main: i7 3770k | Asus P8Z77-V LX| Asus GTX770 DC2 | 16GB | 7 Professional 64bit | 24"+24" | Crucial M4 256GB | 1,2TB
HTPC/VMhost: Q6600 G0 | Asus P5N-D | HD4350 Silent | 8GB | Windows Server 2008 R2 | 3TB RAID5 (two identical boxes)
Samsung SF510 | Acer Iconia A1-810 | Samsung Galaxy S III LTE | Asus RT-AC66U | 100/10Mbps VDSL2
Andersen is offline   Reply With Quote
Old 21st Oct 2013, 19:25   #59
docodine
killed a guy once
docodine's Avatar
Old 21st Oct 2013, 20:40   #60
Panomama
Panomama's Avatar
i'm happy with the 2600mah battery in my MVP, that 350mah battery must last like 10 minutes...
i'll be opening a package with honey peary and hobbes blood liquid from vaporchef once i get home today, looking forward to it
If that's the same as what I have, its a 650mAh
One of those will last me a day if I use it between rollups.
I do have two batteries though, so I can alternate between the two.
Only one CE4 though, I can't wait for my FastTech vape mail.
__________________
Reply
Tags
say yes to skimmed milk
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
