Go Back   bit-tech.net Forums > bit-tech.net > Industry News
Reply
Thread Tools
Old 7th Jan 2014, 13:49   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
NETGEAR DEMONSTRATES THE ‘POWER TO CONNECT’
http://www.bit-tech.net/news/industr...r-to-connect/1
Meanmotion is offline   Reply With Quote
Old 10th Sep 2015, 14:25   #2
OmightyOne
Multimodder
OmightyOne's Avatar
OmightyOne is a Super Spamming SaiyanOmightyOne is a Super Spamming SaiyanOmightyOne is a Super Spamming SaiyanOmightyOne is a Super Spamming SaiyanOmightyOne is a Super Spamming SaiyanOmightyOne is a Super Spamming SaiyanOmightyOne is a Super Spamming SaiyanOmightyOne is a Super Spamming SaiyanOmightyOne is a Super Spamming SaiyanOmightyOne is a Super Spamming SaiyanOmightyOne is a Super Spamming Saiyan
I was hoping more for 10Gb Ethernet in home, wireless is still always going to have interference issues, nothing better then a good old cat 6 cable!
__________________
Retired System - The Tank - Intel i7 920 @ 4ghz - Nvidia 560ti F/OC (Main) Nvidia gtx 460 F/OC (Physx) - 6gb 1866mhz ocz Reaper Ram - F3 1TB - Coolermaster 850w slient pro - CM HAF case - Custom water loop!
OmightyOne is offline   Reply With Quote
Old 18th Sep 2015, 00:29   #3
play_boy_2000
It was funny when I was 12
play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.
NBase-T (or the 802.3 derivative) will probably be the next standard to make it into consumer gear.
__________________
Intel Core i5 2500k @ 4.5Ghz
16GB @ 1600mhz CL9 1.5V
XFX 7950 3GB
Asus P8P67
Patriot Wildfire 120GB SSD
play_boy_2000 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
