Reply
Thread Tools View Mode
Old 9th Sep 2014, 03:53   #21
Jumeira_Johnny
16032 - High plains drifter
Jumeira_Johnny's Avatar
Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.
bump for an update.
__________________
Dachshund of War™|TerrierX™|Macbook Pro|1967 Pontiac Catalina|360# Anvil|2 Burner Gas Forge|135 Amp MIG Welder
Jumeira_Johnny is offline   Reply With Quote
Old 9th Sep 2014, 11:42   #22
Lystfiskern
What's a Dremel?
Lystfiskern has yet to learn the way of the Dremel
Originally Posted by Cheapskate View Post
Sorry about delays. I'm in home repair limbo.
@Meelobee -no
@Jumeira Johnny -No again.
@Bad Fenny -You forgot, "mix with hammer."
@Lystfiskern - No again!
@Furball - Rats. Almost doesn't count.
I see what u did there. Still in limbo i guess ?
Lystfiskern is offline   Reply With Quote
Old 9th Sep 2014, 16:46   #23
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
@Johnny- HEY!
Yes, still in limbo. The end of summer is always bad. I'm up to 3 vacancies as of this week. I'm trying to get some entertainment for you, but the back room looks like a hardware store exploded at the moment.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is online now   Reply With Quote
Old 9th Sep 2014, 16:49   #24
Lystfiskern
What's a Dremel?
all in good time brother..
Old 18th Sep 2014, 01:45   #25
Cheapskate
Cheapskate's Avatar
Most of what I've done so far is digging out tons of random metal bits I've saved. Things would go faster if I kept this kind of stuff in ONE PLACE. There's been a lot of mulling over what to use them for, and lots of attempts to jigsaw parts together.
-Earlier last month there was Desk-a-palooza, a massive migration of office furniture. Five staplers, four scotch tape dispensers, and a jillion of those magnetic-topped paper clip holders later, I got a desk space I could photograph for the first time. The rest of the room is still filled with spare desks, sadly. I think I'll make a chain mail suit with the paper clips later...
Don't laugh at my high-spec monitor.
-I've set aside some candidates for power switches.
-I've opted for a lawnmower piston for the power button housing. I'm going to try to seat it Dalek-style on the tank.
-To work out the shape of the cut, I used some index cards and some scotch tape. I had plenty around to burn through.
-That's a good start. I traced the line onto the piston next.
-I found a mystery box at my door the other day. This one didn't tick, thankfully. I'd really like to know who keeps sending me clocks.
-Yay! Bubble wrap! It will take me a month to pop all this.
-No! Monkey! Not again!
-Ah...Anyway, There was some nifty Swiftech kit in the box. This 140mm x 2 radiator will fit the tank nicely, and allow me to chop about five inches off the tank. There's a greasy spot where my nose touched it. -Gotta love that fresh paint smell.
-There was also the new MCP50X pump.
-It's almost the same footprint as the DDC, although just a hair bigger. The height is noticeably taller to this dead DDC I wired backwards that one time.
-Warranty-voided. I was planning on mounting the top reverse cowgirl anyway. These are a complete redesign, so no aftermarket DDC tops for you. These are using a ceramic shaft and have a lot tighter fit that the free-floating DDC impeller. I'm awfully tempted to make a new top anyway. I think I can.
-The impeller is seated on nylon bushings. It looks like this setup allows for a lot more electromagnet. The intake is huge compared to the DDC too. The open impeller means I could change the shape of the intake a bit if I made a custom top.
-Also there was-Holy cow! how did they fit that in the box? There's a million baggies with color plates, TIM, AMD chip brackets, and 2011 mounting screws. -Wait... socket 2011 screws. there's only 4.
The Apogee XL in all it's shiny guts glory. The top's light box can be changed with the included plates in primary colors. I think I'll be making a cover of my own since I stumbled onto a sale of unique colored plexiglas. -I told myself no more plexiglas. I think I have an addiction.
-Must...resist... The inevitable dismantling to see the guts will have to wait too.
-Back to that Radiator. Seating this in the tank is the critical bit. I plan to have the components assembled as a single part that slides in the tank over the fans. This plate salvaged from an x-ray machine Is a perfect start for a subframe. (Again, it's amazing what you find in vacant houses.)
-Here's the first fan I mounted...
-Now a bit of plastic to represent the seating surface...
-The plastic is a little thick, I think I can get the radiator even closer to the sides of the tank. It's hard to tell. I can't exactly fit my head in there to see. -I tried.
-Then our X-ray aluminum on top.
-I dug out some PSU heatsinks that fit over the plate perfectly. I can use these for seating the frame in the tank, and building the motherboard support.
I'd like to say thanks to Brian and everyone at Swiftech for their support. I'll try not to disappoint.
__________________
Old 18th Sep 2014, 09:51   #26
perplekks45
LIKE AN ANIMAL!
perplekks45's Avatar
perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.
I just HAVE to follow this, don't I?
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far.
ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
Iä! Iä! Cthulhu fhtagn!
perplekks45 is offline   Reply With Quote
Old 18th Sep 2014, 14:30   #27
GeneralFun
Lurker with tools
GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.
Cheaps is no doubt one of the characters that makes this forum so addictive. Can't believe "Gwassgween"... after years of fabrication gets connected to a what.... 15 inch monitor? You'd think Nvidia would send a sponcered adaptive vsync monitor to hook up to such a legendary PC? This should be "GehtoFun!" Subbed!
GeneralFun is offline   Reply With Quote
Old 18th Sep 2014, 17:14   #28
Cheapskate
Cheapskate's Avatar
@Perp- Yes, you do.
@General - It's 17! -ish. and I asked you not to pick on my monitor. There was a time when this was all that would fit on the desk.
__________________
Old 21st Sep 2014, 20:14   #29
Primum Agmen
Multimodder
Primum Agmen has yet to learn the way of the Dremel
This is great. Can't wait to see how this pile of junk comes together. The Millennium Trashcan indeed.
Primum Agmen is offline   Reply With Quote
Old 22nd Sep 2014, 08:47   #30
perplekks45
LIKE AN ANIMAL!
Any plans to finish this beast this side of 2020?
__________________
Old 22nd Sep 2014, 17:25   #31
Cheapskate
Cheapskate's Avatar
@Primum -Thanks.
@Perplekks - Yes, but the world has other plans. -Plans to thwart me an' keep me down.
__________________
Old 23rd Sep 2014, 12:39   #32
perplekks45
LIKE AN ANIMAL!
You know who I blame, don't you?
__________________
Old 24th Sep 2014, 16:43   #33
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Monkey magic turnip, woohoo.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 25th Sep 2014, 16:32   #34
Cheapskate
Cheapskate's Avatar
Someone will asking for a translator.
I mentioned on the zoo that despite picking up a load of new colors in plexi, I'll be going with dark blue and dark purple plexi for my accent colors.
-STILL searching for a pile of brass keychain blanks I cubbied away really well. -perhaps too well. Oh, yes. There will be brass.
__________________
Old 27th Sep 2014, 21:48   #35
Cheapskate
Cheapskate's Avatar
Ah, some monkey edited my log start at the zoo. I suspect AMD are on board. -See post one for a hint.
-New colors from Delvie's. They are great edge-effect materials, but not very strong backlit. I'm going with my stockpile of dark blue and purple.
-This little hacksaw is great for complex cuts. I had a little trouble when the pads rubbed my marks off.
-At this point, I switched to a file.
-The desk just keeps getting worse. Anyone for some cast floppy frames? I never found that cache of brass plates. I did find 6 more dead harddrives, though.
-I'll leave you with a hint. Session one of four and parked on the zero so I can come back later. I had the spindle geared way up, and I think I got 30weight and chips in my hair.
__________________
Old 29th Sep 2014, 04:19   #36
The_Crapman
Don't phone it's just for fun.
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Fudge yeh!
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP³ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 30th Sep 2014, 18:36   #37
Cheapskate
Cheapskate's Avatar
Your name has "crap" in it, so I'm worried that your censored post may be from only moderate enthusiasm.
__________________
Old 7th Oct 2014, 20:43   #38
Cheapskate
Cheapskate's Avatar
Putobuket is in prime form today. -gotta love a service so loaded with code that you have to wait a minute or so for the name to finish typing in the login window.
-That fits a little better.
-I'm still filing down where the rod fit. It's taking forever because of the lack of clearance. *Insert short stroke joke here*
-You know that line about "everything but the kitchen sink"? Well, guess what. I have one of those too. -four or five, actually, but one sink and one faucet that are completely destroyed. They never have screens in them either when we get a house back. -Stupid stoner tenants!
-Ah, yeah. Front-loading USB, right in little R2D2-knock-off's eye socket.
-Bill/AKA MNPCTech sent some of the Munkeyplates to me. I designed it, so I get a copy. ...That didn't work with the FrozenCpu Test Bench, though.
-120mm fan for reference. I have no clue if I can use them here.
-Last update, I was teasing a cut session. Here's session 2. I'm running about 40 minutes for each. It's not the fastest rig.
-#5,-er...3. Or how to turn a tiny bit of metal into a big pile of oily sand.
-Session...? Dude, I should totally design sneakers, man!
-Since I'm using silicone glue to stick it to the MDF, I had to soak the board until I could peel it free. It's hard to get the part perfectly flat with this technique, so I had some spots that didn't cut all the way through.
-Here it is sanded down, except for some really conspicuous spot welds filled with primer. I'd have it bolted to the radiator, but I used the wrong measurements for the fan holes. -Story of my life.
__________________
Old 7th Oct 2014, 21:10   #39
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
Cheaps....I've just been looking though this and I haven't got the foggiest idea what is going on.. This is proper seat of the pant modding.
There was me thinking I was the only one who modded with whatever is laying about.
bulldogjeff is offline   Reply With Quote
Old 8th Oct 2014, 00:24   #40
Waynio
Relaxing
Waynio's Avatar
Nice grill & Munkeyplates.
__________________
Reply
Tags
aardvarks and aasvogels, cheapskate, metal, salvage, stainless steel, water cooling
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
