Reply
Thread Tools View Mode
Old 8th May 2017, 21:51   #441
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
I'm here to do some dusting...
A brutal series of combos has left me off my butt for a long time now. I'm finishing up the 3rd vacancy mentioned above, and there's another eviction in the court system. I happened to be stuck home today, and found some un-posted updates on my camera.
-not much, but it's something.
How does this forum thing work...
-That tube I milled 1/4" holes in was so I could tap this 1/4" purple rod into the holes. The tapered tube to the side is with the mounting plates that attached it to the case MANY MONTHS AGO.
-Here that is sanded down smooth.
-I was still trying to remove the chrome from the faucet tube.
-For that I needed some flap sanding discs. I could buy some God-awful expensive Dremel ones, or... Yeah.
-A little cardboard backing and I'm ready to rock.
-A little side mod I did to a crappy tool design. The battery attachment point disintegrated due to the violent tool vibration. I made an extension cord.
To disgust you, or give you a vague idea of WHY I have been gone so long:
-Check out that sweet paint work! This is vacancy one, somewhere in 2016. They honestly thought they could paint over the filth.
-This is my current project immediately after the scoop-shovel squad finished up. Feral cats, rats, raccoons in the attic, and a hen in the garage. Drugs are bad, M'kay?
-Hoping to do a real update someday. Think of this as a postcard from limbo.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is online now   Reply With Quote
Old 10th May 2017, 18:00   #442
Cown
Supermodder
Cown's Avatar
Cown has yet to learn the way of the Dremel
OMG! I hope you get payed accordingly
__________________
Finished Projects:
ROG Meets Lian Li - Picade - Mr. Wallmount - Milk on the Wall WIP: The Iron suit project
Facebook page:
Cownbuilds
Cown is offline   Reply With Quote
Old 11th May 2017, 19:52   #443
Cheapskate
Cheapskate's Avatar
Who's going to pay me? That one is ours.
__________________
Old 11th May 2017, 22:43   #444
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
My flat looked like that when I moved in. I've done quite a bit of work to get it reasonably presentable. Still, the rent is £120 less than it is in similar refurbished flats so hey, we'll take it..
Sorry you got screwed though dude. At least they're out now. Good idea on the sanding disc. I will probably nick that at some point got me some alu oxide cloth paper too.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 12th May 2017, 18:59   #445
Dr. Coin
Supermodder
Dr. Coin's Avatar
Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.
The forum at its best, highlighting the ingenuity of a member to overcome a challenge without going to the store to buy an off the self product.
Cheapskate your sanding disk reminded me of the following video:
__________________
Wait, I’ve got an idea, and it doesn’t require high explosives.
-Sam & Max Hit the Road
Dr. Coin is offline   Reply With Quote
Old 13th May 2017, 17:27   #446
Cheapskate
Cheapskate's Avatar
I guess that one way to get around exploding grinder discs.
-I wonder if that can remove lime scale from tub tile...
__________________
Old 16th May 2017, 17:30   #447
B NEGATIVE
All Hail Kim Jong Magoo!
B NEGATIVE's Avatar
B NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming Saiyan
Go straight to acids. I use 38% HCL for bathroom cleaning,bloody effortless.
__________________
Missed.....
Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
B NEGATIVE is offline   Reply With Quote
Old 17th May 2017, 03:47   #448
barry99705
sudo rm -Rf /
barry99705's Avatar
barry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyan
Heh, I used some Poly Zag to remove some rust stains out of a shower tub once. The fumes wafted over the copper pipes for the baseboard heat, insta-green!
__________________
It sounds simple, but there will be wires and lube everywhere, like some kind of Japanese porno. --Cheapskate
Crap I've built/building
barry99705 is offline   Reply With Quote
Old 17th May 2017, 17:37   #449
Cheapskate
Cheapskate's Avatar
@Bneg - I would too, but there's things like tub chips, (what the hell do you do in a tub to chip the ceramic anyway?) and that metal thing called the drain fitting. I've had to change out fixtures that had been turned black and peeled the chrome off because someone poured toilet cleaner on the tub and left it.
__________________
Old Yesterday, 00:00   #450
Andreas | Brodholm
Multimodder
Andreas | Brodholm's Avatar
Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!
This is a super cool project. I have been so busy with all my crap that I have basically had no free time to look at the other nice builds. This one is really interesting! 5 out of 5.
Love the milling action you got going also
__________________
[Scratchbuild]
Water Cooled Chassis built from scratch!
Have a look and let me know what you think!
Completed! (Pictures Inside)
Andreas | Brodholm is offline   Reply With Quote
Old Yesterday, 13:17   #451
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
love the tube progress!
yikes, at those tenant pics...
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old Today, 19:59   #452
Cheapskate
Cheapskate's Avatar
Thanks, guys.
My milling is mediocre and you know it. I'm glad you had a look and like the rig, though.
-Bill, get back to the mill. :P
__________________
Reply
Tags
aardvarks and aasvogels, cheapskate, metal, salvage, stainless steel, water cooling
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
