Reply
Thread Tools View Mode
Old 31st Dec 2014, 20:52   #101
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Why, Thank you, Sir. It's good to see you around, by the way.
Last we spoke, I was trying to get this awkward shaped part in the drill press.
-Lets see...Nope! I'm hitting the slide frame.
-Nope! Now I don't have room for a bit even.
-I had to pull the cross-slide vise and use a normal one.
-I drilled the PSU angle brackets- all over. I only shot one photo of the process.
-And, BLAMMO! PSU/Mobo/reservoir mount, (mounted backwards, but it works.) This is still a bit wobbly since the back panel hasn't been made yet.
I didn't think this bit out very well, though. There's no room for the cables. I guess I'll make some longer brackets? -We'll see after a few test fits.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is online now   Reply With Quote
Old 31st Dec 2014, 21:04   #102
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Looking awesome in that 2nd to last shot.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 1st Jan 2015, 00:02   #103
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
Adjustable brackets? Connect your wiring, slide PSU into position, nip up screws....... Maybe.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 1st Jan 2015, 18:59   #104
Cheapskate
Cheapskate's Avatar
@Waynio - Thanks.
@Attila - I'm at the max distance for the black brackets, and the PSU said, "clang" when I stuffed it in the tank. Solution: More brackets! It will lower the psu 1/8" and get it to clear the weld lip in the tank bottom. There's a ton of unused space in that dome. I may be stuffing the pump in there.
...The fun bit is making a bulkhead to vent the PSU out the front somehow.
__________________
Old 1st Jan 2015, 20:07   #105
storm-83
Supermodder
storm-83's Avatar
storm-83 has yet to learn the way of the Dremel
if your bracket's bracket's bracket is causign trouble, you can always solve the problem by making more brackets...
this is looking like a very fun build!
storm-83 is offline   Reply With Quote
Old 2nd Jan 2015, 11:00   #106
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Yo dawg, I heard you liked brackets, so I made brackets for your brackets so you can bracket your brackets while you bracket your brackets.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is online now   Reply With Quote
Old 2nd Jan 2015, 16:09   #107
Cheapskate
Cheapskate's Avatar
I need a thesaurus for my CAD file naming. The whole thing is brackets. Perhaps I should start naming the parts like tropical storms? -Part "Bob", part "Betty," part... "Bindi."
__________________
Old 2nd Jan 2015, 17:36   #108
Nexxo
Whatever's Geek.
Nexxo's Avatar
Go wild: Part "Pineapple Express"; Part "Okey-Cokey Shake-Shake"...
__________________
Old 2nd Jan 2015, 17:54   #109
B NEGATIVE
All Hail Kim Jong Magoo!
B NEGATIVE's Avatar
B NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming Saiyan
Tell me about it,My current naming style ("fgfgfgfgfddfgdfg-FINAL" etc)leaves much to be desired.
B NEGATIVE is offline   Reply With Quote
Old 2nd Jan 2015, 18:06   #110
Nexxo
Whatever's Geek.
Nexxo's Avatar
Ada is known as "Metaversa 02-11b", which gives you an idea how many different versions I designed before I settled on her.
__________________
Old 3rd Jan 2015, 18:45   #111
Dr. Coin
Supermodder
Dr. Coin's Avatar
Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.
With my current job revision control is critical and one thing I have learned is nothing is ever FINAL.
Hmm, the directions for assembly could get interesting, fit Bob in Betty and screw until tight… *cough* err umm I'll stop there. Alternatively you could channel your inner Seuss… thingadoodle, jig-a-ma-wizer, wacket-a-booble.
The brackets are looking good.
Dr. Coin is offline   Reply With Quote
Old 3rd Jan 2015, 19:58   #112
Cheapskate
Cheapskate's Avatar
Oh, God! Give them all pornographic names. If someone steals my rig, they'd spend the rest of their lives trying to get the files to work.
-Alternately, I could find the culprit by searching for: ".nc doesn't play in movie player "
__________________
Old 4th Jan 2015, 06:36   #113
onevoicewild
Minimodder
onevoicewild has yet to learn the way of the Dremel
Love your pic's, most peoples stuff you look at it and go hmmm. Your stuff, you look at it and then you look at it some more and the go WTF Hmmm. Wish I could do that lol
onevoicewild is offline   Reply With Quote
Old 4th Jan 2015, 14:34   #114
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
haha, yeah Cheaps is def one-of-a-kind.
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 5th Jan 2015, 16:41   #115
Cheapskate
Cheapskate's Avatar
Thanks.
@OneVoice - That's the response I get from women too. "hmmm, WTF?"
__________________
Old 5th Jan 2015, 17:07   #116
Ace_finland
Multimodder
Ace_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for president
have no idea whats going on but looking good cheaps!
Ace_finland is offline   Reply With Quote
Old 12th Jan 2015, 19:57   #117
Cheapskate
Cheapskate's Avatar
I'm seeing you a lot lately.
-The test fit tells me there's more room for the PSU if I move it down a tiny bit, and my temp screws are too long.:I
...and the current bracketry sags a bit.
-The PSU position requires a 90 degree power plug. Of course, none of the ones available go DOWN. I'm making my own from harvested PSU parts and spare cords.
-The stock AMD backplate didn't trip my tra la la, so I made a new one.
-I used a lot of degreaser to get the chips out of the tiny holes. This is already on the board, but I didn't snap a pic for some reason.
-I mentioned on the modzoo I'm using window caulk for mounting the billet to the pallet. Environmentallyunfriendly, but effective. It doesn't flex like silicone does, and you don't have to wait as long for it to cure.
...mostly it's because I had a half-used tube lying around.
-I haven't killed the grass in my yard yet, but I'm trying. I have bracket # 99,000 cleaned up, but I didn't snap a pic for some reason. I did that a lot last week.
This dose of madness brought to you by the following:
__________________
Old 13th Jan 2015, 07:44   #118
perplekks45
LIKE AN ANIMAL!
perplekks45's Avatar
perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.
Every update just confirms that you are nuts. And a genius. But mainly mad.
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far.
ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
Iä! Iä! Cthulhu fhtagn!
perplekks45 is offline   Reply With Quote
Old 14th Jan 2015, 03:14   #119
Cheapskate
Cheapskate's Avatar
So... I'm mad, but you don't want to offend me, but I'm mad.
__________________
Old 14th Jan 2015, 08:08   #120
Nexxo
Whatever's Geek.
Nexxo's Avatar
When someone declares of your modding project: "This is madness!" you know you're doing it right.
__________________
Reply
Tags
aardvarks and aasvogels, cheapskate, metal, salvage, stainless steel, water cooling
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
