Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 21st Jul 2015, 15:42   #1
aryehsteiner
What's a Dremel?
aryehsteiner has yet to learn the way of the Dremel
Corrupt Access DB
Access 2003 database. Unable to open - error message "database engine could
not find object MSysDb".
Can not JetComp it; can not import tables into a new db; can not open in
Access 2007; can not compact & repair.
aryehsteiner is offline   Reply With Quote
Old 21st Jul 2015, 19:25   #2
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
Yesterday's backup?
phuzz is offline   Reply With Quote
Old 21st Jul 2015, 20:55   #3
deathtaker27
Probook Addict
deathtaker27's Avatar
deathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyan
Previous versions?
deathtaker27 is offline   Reply With Quote
Old 23rd Jul 2015, 22:40   #4
Landy_Ed
Combat Novice
Landy_Ed's Avatar
Landy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming Saiyan
I'd say search for a similar sized file with a different name (like ZXCFGREWJW.tmp, it'll look quite arbitrary) in the same directory (make sure hidden files are shown) and temp dir, try renaming any such found file to be an accdb or mdb file and attempt to open that.
MSysDB, I think, contains the metadata for all the tables held in the file. without that data, you can't reasonably interrogate it at all. You're then into opening the file in pure binary. Good luck with that, especially if it's encrypted.
__________________
CDR SPUD
Landy_Ed is offline   Reply With Quote
Old 5th May 2016, 15:42   #5
jensonwright
What's a Dremel?
jensonwright's Avatar
jensonwright has yet to learn the way of the Dremel
Try this sequence in order below or as an additional resources for restoring .mdb file see and learn following topics, and in case your corruption is severe, one more solution must assist you Access Repair Toolbox
The repair method attempts to recover only the tables, indexes and queries in the database. Do not attempt to repair damaged forms, reports, macros and modules. Before executing the Compact and Repair tool, please ensure the following condition:
1. Do not open Access database must closed
2. Sufficient storage space available - minimum double in size of your Access database on that Disk.
3. Close the .mdb file related to .ldb file before you delete the .ldb file.
4. Then Run the Compact and Repair tool
jensonwright is offline   Reply With Quote
Old 8th Mar 2017, 18:24   #6
Leiton
What's a Dremel?
Leiton has yet to learn the way of the Dremel
Hello, I need recover an Access database now but this software does not work. Is there other access database repair software that works?
Leiton is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
