Old 27th Aug 2015, 18:28   #1
hairyknacker
Multimodder
hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.
D5 pump PWM- brain dead :duh:
Howdy- having a very senior moment here
Going back to water for a build and have a D5 pump with pwm 4 pin connector- if I connect to motherboard, will I be able to control the output? If so, any recommended software.
Last time I was under water, I had a D5 pump connected to an Aquaero 5 via aquabus and my current fan controller- a Lamptron Touch- only has 3 pin connectors so don't think that would work- or would it?
I know these are the most stupid questions ever asked but have just had a complete brain freeze
hairyknacker is offline   Reply With Quote
Old 27th Aug 2015, 18:30   #2
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
I doubt you'll be able to drive a D5 off a motherboard fan header.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|980 Ti|3007WFP-HC|Parvum S2.0
David is online now   Reply With Quote
Old 27th Aug 2015, 18:34   #3
Big Elf
“not another f—-ing elf”
Big Elf's Avatar
Big Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming Saiyan
If it's a PWM pump there should only be 2 wires into the 4 pin Fan header with another 2 wires for power ending in a 4 pin molex type/auxiliary connector to go to a PSU connector.
If you have an Asus motherboard then Fan Xpert (part of the AI Suite) is pretty good for PWM control, otherwise Speedfan which can be a bit complicated to setup usually works.
__________________
Case Labs TH10│Asus Rampage III Extreme│Core i7 990X│24GB Corsair Dominator GT│GTX Titan SLI│Samsung 850 EVO 256GB│Crucial M4│2TB Samsung Momentus x 2│SeaSonic P1000W│EK Supremacy│EK FC-RE3│EK-FC Titan SE x 2│EK-RAM Dominator│Black Ice SR-1 480 x 3│Swiftech 35X2
Big Elf is offline   Reply With Quote
Old 27th Aug 2015, 18:47   #4
hairyknacker
Multimodder
pump does have a molex for power- see- having a total nightmare of a day!
mobo is a MSI gaming Z97 ACK thingy and not sure what that has software wise- I am aware of Speedfan so will see when I finish the build- be a week or so as waiting on fittings
Old 27th Aug 2015, 18:59   #5
Big Elf
Big Elf's Avatar
If you do end up using Speedfan then Martin's guide here is very helpful in setting it up.
__________________
Old 27th Aug 2015, 19:12   #6
hairyknacker
Multimodder
Thanks for that Biggie!
Much appreciated
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
