Old 18th Sep 2015, 10:39   #1
Cyclone
What's a Dremel?
Cyclone has yet to learn the way of the Dremel
DIY radiator design
Hi all, I'm new here so go easy on me!
I making a fully DIY water cooing system inspired by project monoith purely for fun, not expecting any performance records but more on that later once I've got some goodies to show!
Main goal is to be as cheap as possible!
Basic System Specs (that will be cooled):
Core2duo/quad of some sort
Motherboard NB, SB and VRMs
HD 7850 (donated by my brother due to the fan dying)
2/4 sticks of DDR2/3
Cooling system specs:
Homemade copper waterblocks
300Lph pump, undervolted to 7V (measured at 200Lph with no resistance)
8mm copper pipe for barbs and radiator (ID more like 7mm)
approx 1L reservoir
8mm clear aquarium tubing
Radiator design process:
I would use a minimum of a thick 120.2 radiator usually for this type of load.
I calculated surface area based on a radiator like the Thermalright PA120.2 (using approximate dimensions from memory as all my watercooling gear is currently at my parents)
Approximate total surface area:
10FPI, 10inches long = 100fins
Area of fin= thickness of rad x width of rad x 2 (assuming each fin has negligible thickness)
=6cmx12cmx2= 144cm2 x100= 14400cm2
for my radiator I plan to cut 100 plates of 1.2mm thick aluminium of approximately 15cmx5cm giving a total surface area of 15000cm2. I then plan to drill 10 8mm holes in each plate and run 8mm copper piping through the parallel fins and use thermal adhesive to hold them in place. the final dimensions of the rad would be approximately 420x150x50mm.
now for the queestions:
1. has anybody tried making a DIY radiator before?
2. will this even work?
3. would it be better to have the copper tubing as one continuous run or to have the flow in parallel? (5 up 5 down?)
if you have any suggestions or design ideas please let me know! I have only very limited funds and very limited tools available
Cyclone is offline   Reply With Quote
Old 22nd Sep 2015, 19:18   #2
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
I don't think I've ever seen someone try to make their own radiator.
Back in the day, before you could buy radiators that were actually designed for use in computers, people would use radiators designed for cars. The main radiator is usually pretty big, but there's various other automotive radiators, eg oil coolers, intercooler, heater core etc which might be the right size for you.
So that answers question 1.
2) Yes, but probably not as efficiently as a manufactured one.
3) All the radiators I've seen use a parallel flow design, so I guess that's the way to go.
Edit, from a quick google of "home made radiator" I've found this thread, so I was wrong, a few people have made their own custom radiators.
phuzz is offline   Reply With Quote
Old 27th Sep 2015, 22:45   #3
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
I've seen people make their own radiators out of copper tubing and thin copper plates for the fins. All soldered together with a blowtorch. It's somewhere in ourforums in the project-logs, but I can't remember the name of it.
If you're putting in some work you can actually make a radiator in this manner yourself that performs like a manufactured one. It's all down to your abilities and your tools.
Using aluminum fins and thermal adhesive won't work aswell as copper fins soldered to the tubes ofc.
1.2mm thickness of the fins is way too much. Go for 0.5mm instead and increase the amount of fins, otherwise the results will be very underwhelming
Parallel flow design is the way to go for a radiator this big.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 28th Sep 2015, 16:06   #4
Cyclone
What's a Dremel?
Thanks for your replies,
Plans have changed slightly, the rad willmake up the front panel of a scratch built case, hence the size, which will now be 200mm x 400mm to accommodate two 200mm fans.
Unfortunately copper fins would be prohibitively expensive for me, so I'm sticking with aluminium.
I've found a website which will do pre-cut aluminium plates (200x100x0.9mm) for 0.29 each, so I plan to buy around 100-140 of these and stack them with steel washers as spacers. I do have a blow torch and I am aware that solder doesn't stick to aluminium all that well, but would it provide a good enough thermal interface if I use other means of providing structural integrity?
otherwise, does anybody know of anywhere in the UK I can get cheap copper plates/sheets.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
