Old 11th Nov 2015, 19:24   #1
IBMer
What's a Dremel?
IBMer has yet to learn the way of the Dremel
Any hint on EK Vardar 140 availability?
Hi everyone,
I am trying to sort out better cooling for my latest vintage mod project (http://forums.bit-tech.net/showthread.php?t=293459) and I was interested in EK Vardar F3-140ER.
Unfortunately it seems that anything above the F1 is currently unavailable due to a flaw on early series.
Does anyone have a hint on when higher rpm models will be back?
I was planning to use 4x Vardar F3-140ER in push/pull on a very think 280 rad such as the Alphacool Monsta 280 (due to the nature of my project I am only using one rad for both CPU and GPU). Does anyone have alternative fans in mind (trying to get good static pressure + good rpm control through pwm)?
Thanks in advance for the advice.
IBMer is offline   Reply With Quote
Old 12th Nov 2015, 21:29   #2
Akira749
Multimodder
Akira749 has yet to learn the way of the DremelAkira749 has yet to learn the way of the DremelAkira749 has yet to learn the way of the DremelAkira749 has yet to learn the way of the DremelAkira749 has yet to learn the way of the Dremel
If all goes well, they should finally be available next week.
Akira749 is offline   Reply With Quote
Old 15th Nov 2015, 01:06   #3
IBMer
What's a Dremel?
Thanks for the info!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
