Old 11th Dec 2015, 08:29   #1
Sn3akr
What's a Dremel?
Sn3akr has yet to learn the way of the Dremel
Rad fans - which led fans?
Hi guys 'n girls
Starting a mod project and need some fans for my rads, Alphacool NexXxoS XT45 2x360 (and a 240 if i can get it fitted into my newly aquired Phanteks Enthoo Evolv ATX)
I've looked at the the TT Riing, but tests says the are bad at lower voltage, the Antec Truequiet UFO's, but those have bad static pressure and the Corsair SP120 LED, but those seems pretty crappy compared to the non-LED (no rubber corners etc)
Shame about the Riing and UFO though, since their looks are awesome for my mod!
I'd like the fans to be 3-pin (since the case have a 10 fan hub with PWM control) and have white led.
What fans do you guys have experience with that have good static pressure, LED and still can be undervolted without loosing all cooling power? Please let me know about your experience /advise
Sn3akr is offline   Reply With Quote
Old 11th Dec 2015, 14:57   #2
alfizzle
I *am* a Dremel
alfizzle's Avatar
alfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyan
Cougar vortex fans are great!
https://www.overclockers.co.uk/searc...=cougar+vortex
Great static pressure and quiet.
alfizzle is offline   Reply With Quote
Old 11th Dec 2015, 16:16   #3
Sn3akr
What's a Dremel?
I know, but there's 2 issues i'd like to avoid if possible..
A: Their Orange and i can't really avoid having to take them apart for painting them since i'm gonna do a white purple theme, and i'm not really sure how the hydro dynamic bearing are to take apart without damaging them.
B: Their not LED fans which i'd really like, and if i have to go for non led fans i'd go for some i know is fairly easy to take apart and reassemble.
Old 11th Dec 2015, 18:22   #4
alfizzle
I *am* a Dremel
alfizzle's Avatar
You can get them in led, didnt realise the ocuk ones where not led.
But blades are still orange, so yeah..
Old 11th Dec 2015, 18:38   #5
Sn3akr
What's a Dremel?
Didn't know they did them with LED, but again, i'm not real sure how easy they are to tear apart for painting or it'll ruin the bearings, being hydro dynamic, i guess there's some kinda fluid in them that i can't just replace.. And painting them without disassembling isn't the best of options
Old 11th Dec 2015, 22:11   #6
The_Crapman
Don't phone it's just for fun.
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
The xigmatek fans in my sig are pretty decent, although not widely available. There's plenty of colours to chose from too.
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 12th Dec 2015, 16:38   #7
stealth80
Supermodder
stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.
I used these in my project build:
https://www.youtube.com/watch?v=tOn-U_D4WVY
Enermax TB Vegas 120mm, pressure aint too bad for LED fan and theyre reasonably quiet if not full speed. Some great options in the range aswell
__________________
Project Temporal Snow - http://forums.bit-tech.net/showthread.php?t=314299 - In Progress
Temporal Snow Ryzen Refresh https://forums.bit-tech.net/showthread.php?t=323038
Ryzen 1700 @ 4.0 GHZ - Gigabyte AX370 Aorus Gaming 5 - 16GB GSkill Trident RGB 3200 MHZ - Palit 1080 GTX Gamerock Premium - Samsung XP941 256GB - Crucial MX300 525GB - Fractal Design R3 Newton 1000w White Edition
stealth80 is offline   Reply With Quote
Old 14th Feb 2016, 15:22   #8
tiger-moth
Modder
tiger-moth has yet to learn the way of the Dremel
Very pretty
Do they come in blue?
tiger-moth is offline   Reply With Quote
Old 19th Feb 2016, 15:19   #9
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
What about the new antec fans with the glowing ring?
__________________
Ediface
Silverstone FT03 Mini - i7 4790S - Noctua NH-L9i - Gigabyte GTX 1070 'ITX Edition' - Maximus Impact VII - 16GB DDR3 - 1TB NVME - SF600 - AOC Agon AG271QG - Xonar U7 - Bassshaker - RAT3 - Majestouch Minila - Q90s - Orbweaver - Warthog
Parge is online now   Reply With Quote
Old 19th Feb 2016, 23:13   #10
lancer778544
isnt really an ultramodder...
lancer778544's Avatar
lancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyan
BitFenix Spectre Xtreme? White LED, 3 pin, rubber corner mounts, rad screws included and designed for water cooling applications. They sound like your perfect fan...
__________________
Intel Core i7 6700k | Asus Z170-Deluxe | 16GB Crucial Ballistix Elite | MSI GTX 970 OC | 256GB Samsung 840 Pro | 1TB Seagate Barracuda | Corsair AX860i | CM Storm Trooper | Creative Sound Blaster Zx
lancer778544 is offline   Reply With Quote
Reply
Tags
advice needed, cooling, fans, static pressure, watercooling fan
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
