Old 16th Jan 2016, 21:57   #1
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyan
Trumpet Blowing 2016
2016's Thread
"In case you are new member to our folding team this thread is for sharing your personal achievement's and milestones with the rest of us, doesn't have to be a huge milestone but something you are proud to have achieved towards the science"
__________________
HeatWare
debs3759 is offline   Reply With Quote
Old 17th Jan 2016, 03:15   #2
debs3759
debs3759's Avatar
I just made it into our top 100, with 27.3 million points.
Only making 125-130K ppd, but waiting for Pascal to up that later this year
__________________
HeatWare
Old 17th Jan 2016, 08:50   #3
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Congrats debs3759.
Looking forward to Pascal too.
__________________
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX 1080 Ti SLI; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Scorpuk is offline   Reply With Quote
Old 21st Jan 2016, 21:49   #4
PcShedTV
Minimodder
PcShedTV's Avatar
PcShedTV has yet to learn the way of the Dremel
Top 100, hopefully, see you soon!
Well I started folding 26 days ago and started on 9,583th position on the Custom PC & bit-tech's folding team and now managed to get to 118th position with ppd of 2,121,925 avg and still climbing.
There are 2 pc's folding 24/7 and a another pc which we just added a titan x 12GB so this should bring ppd up a bit more.
Currently building a old evga x58 SR2 with dual xeon for further increase ppd.http://folding.extremeoverclocking.c...hp?s=&u=693549
PcShedTV is offline   Reply With Quote
Old 24th Jan 2016, 10:10   #5
Scorpuk
Hypermodder
Congrats PcShedTV you are currently 98th Team Rank and rising rapidly.
Nice hardware you have there. 2.2 years and falling until you over take me.
__________________
Old 24th Jan 2016, 20:12   #6
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
Good to have some new members on the Team - welcome aboard
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 25th Jan 2016, 22:57   #7
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyan
I used to run a SR2 when I was folding big ADV... Good look mate 😀
Sent from my Nexus 7 using Tapatalk
__________________
3770k @ 4.8GHz, GTX980 OC'd, Custom loop,
kirk46 is offline   Reply With Quote
Old 30th Jan 2016, 02:48   #8
PcShedTV
Minimodder
PcShedTV's Avatar
Cheers. Finally made it to Top 100 and currently sitting at 65th position with 40,435,113 points and ppd of 2,145,300 in 34 days of folding. The evga sr-2 is currently being built all watercooled with EK blocks for chipset/VR and cpu's. A pair of old xeon 6 core 5650x and digging out some 690gtx's to see how they do.
2 more old HP pc servers to be build in February using old 1366 socket with pair of xeon quad 5550x and 5570x. going to be using pci risers to add extra GPU.
Finally aquired totally 2 x Xeon 8 core E5-2660 which is going to 2011 socket dual workstation but not sure on gpu's to run on that as this build is going to be done in March.
Hopefully I will achieve my second target of 3M ppd by Feb and 4M ppd by March. Time will tell!
Old 30th Jan 2016, 21:24   #9
DocJonz
DocJonz's Avatar
That's some impressive server grunt you've got access to PcShedTV! Nice job on the PPD
Should make your house all nice and toasty
__________________
Folding stats
Old 1st Feb 2016, 22:10   #10
Tattysnuc
Thinking about which mod to do 1st.
Tattysnuc's Avatar
Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.
80 mill!
Would be more but had problems with my eVGA gtx 980tis from Overclockers. Ended up the DOA one was replaced with ANOTHER one which was DOA. Figuring that out all took time, so at the moment I've just 2x machines folding on GTX 780s until I can get some work down-time - if that exists.
Well done PCShed - you're smashing it!
__________________
Folding statsFolding stats
Tattysnuc is offline   Reply With Quote
Old 2nd Feb 2016, 16:27   #11
PcShedTV
Minimodder
PcShedTV's Avatar
Originally Posted by Tattysnuc View Post
80 mill!
Congrats reaching 80 million, it will be another 4 weeks before i reach that milestone with the current planned rigs which i am currently building. managed to acquire a 690gtx dual gpu card, so we will see how that performs.
Old 2nd Feb 2016, 16:29   #12
PcShedTV
Minimodder
PcShedTV's Avatar
Cheers, 60th now with and just about holding 2Million ppd. I think i can bring that 2.2 years timescale down a bit with a few more rigs!
Old 2nd Feb 2016, 16:30   #13
PcShedTV
Minimodder
PcShedTV's Avatar
When you had your EVGA SR-2 what ddr3 ram works best for you?
Old 2nd Feb 2016, 16:32   #14
PcShedTV
Minimodder
PcShedTV's Avatar
Thanks, 2 pcs are in the house the others are in the garage shed. But the end of this week hopefully only one in the house and 4 servers up and running!
Old 2nd Feb 2016, 16:35   #15
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
Were you the one that nabbed the auction on eBay I just missed out on?
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 3rd Feb 2016, 23:58   #16
PcShedTV
Minimodder
PcShedTV's Avatar
Which auction was that? i bidded on quite a few?
Old 5th Feb 2016, 06:14   #17
PcShedTV
Minimodder
PcShedTV's Avatar
50M Milestone reached!
So 39 days folding and finally reached the 50 Million milestone, with 6120 WU and PPD of 2,062,183. My ppd took a hit as had to do a few changes to the graphics cards, as needed them for the servers I currently buillding. hopefully over the weekend will have 2 up and running 24/7
This folding is getting addictive!!!
https://www.facebook.com/PcShed/phot...type=3&theater
Old 5th Feb 2016, 11:26   #18
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming Saiyan
Congratulations on that milestone! I dread to think what the electricity bill must be like with that farm running!
I am still trying to tackle some stability problems with my own machines which are folding on a remote site, however I have slowly but surely clawed my way back into the top 100. I'm going to add at least another one GTX 970 back into the GPU setup as soon as I get it; I'm waiting for an RMA replacement which will probably arrive at the end of this month.
__________________
"For every stalwart bit-tech-worthy tech out there, another 2 cretinous arse-scratchers are out there pulling your patches and reconfiguring your ****." - Krikkit
Unicorn is offline   Reply With Quote
Old 5th Feb 2016, 14:40   #19
PcShedTV
Minimodder
PcShedTV's Avatar
Electricity costs not too bad, hence trying to use efficient PSU. I have been looking at 970 GTX as you can pick them up now under 200 used. What sort of ppd are you getting with yours and what core clock speeds are you running?
Old 6th Feb 2016, 20:08   #20
PcShedTV
Minimodder
PcShedTV's Avatar
Will we hit 60 million milestone before the weekend is over??? When i think now is a Yes!
Finally got all 4 servers up and running his weekend and currently folding using the Web Browser Client (http://folding.stanford.edu/nacl/?team=35947) at the moment until I can afford and load them up with graphics cards.
So specs wise they are 3 HP Z600 and 1 HP Z800 Server:
Server 1 - Dual Xeon Hex core X5650 with HT (24 cores)
Server 2 - Dual Xeon Quad core X5550 with HT (16 cores)
Server 3 - Dual Xeon Quad core X5570 with HT (16 cores)
Server 4 - Dual Xeon Quad core X5570 with HT (16 cores)
Check photos on the current state of them on link below;
https://www.facebook.com/media/set/?...7888680&type=3
Been changing cpu heatsinks to ensure temps are kept at bay as they will be running 24/7 but to be fair the HP heatsinks do a pretty good job as these cpu are 95W
Been testing a 690 GTX dual GPU and MSI R7 370 4G, overclocked of course but a bit disappointed with ppd its getting (amazing card for pc gaming at 1080 and 1440p).
2 more server pc builds to go, dual cpu evga sr2 with x5650, Asus Z9PE-D8 with 2x E5-2660 then that is it. The Folding Farm complete ready to load up with GPU's.
Monday testing a MSI 970GTX and see how that does, if ppd is good then that is my gpu of choice.
Anyone have any thoughts on this or any recommendations?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
