Go Back   bit-tech.net Forums > Partner Forums > Asus UK
Reply
Thread Tools
Old 10th Feb 2016, 11:51   #21
AllanRoy
Minimodder
AllanRoy has yet to learn the way of the Dremel
Hi Ryan,
Thanks again for your reply, and I appreciate your help with this, given that this clearly isn't a problem related to my ASUS hardware! Though you'll be pleased to know that yesterday I replaced my MSI graphics card for a new ASUS Strix!
Anyway, as for the issue at hand, I have run /scannow - clear. Win 10 updates itself automatically these days. I use GeForce Experience to keep my graphics driver up-to-date. I'll look into using Intel's driver tool and see if that throws up anything. I recently installed CCleaner and have done a little bit of house keeping with that, but I'll pursue it further. I have Norton Security installed and rely on that to keep malware etc. at bay. Norton is giving me the all clear at present.
I'm happy to leave this problem here for now, although I shall continue to see what I can do to fix it, but my machine is running OK and I can get my work done. I'm managing Sleep Mode manually for now, and I can get by with that.
Picking up on my original post, you might be interested to know that a couple of days ago I re-flashed the BIOS again back up to the latest version 1402, just to see if it might fix the problem - it didn't, but it did reintroduce the "booting into BIOS" problem that started this thread! But I'm not going to worry too much about that (if I have to go back to version 0802, I will do) but it's interesting that flashing the BIOS to version 1402, is clearly introducing this problem.
Allan.
AllanRoy is offline   Reply With Quote
Old 10th Feb 2016, 12:16   #22
Ryan@ASUS
Minimodder
Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.
Hi Allan,
That's very frustrating that the latest BIOS does that. The problem for me is I've not heard of anyone else having this issue, in fact we have many media and customers using Maximus VIII Hero on the latest BIOS. This means we'd really need to narrow down to what specifically about your system caused the system to do it, and as you can probably guess it's no easy task! It could be anything, some particular combination of hardware or settings that causes the problem.
With regards to the sleep problem, while you can "live" with it, it seems like you shouldn't have to. If you get time, it'd be interesting to know if a clean install of a Windows OS on a spare drive still gives you the problem (i.e. narrowing down if it is software issue with your current OS setup or hardware related). Given the boot to BIOS issue, and if the sleep problem is hardware related. I think that's enough to command a warranty replacement of your board, there could indeed be a hardware fault causing both these problems.
Ryan
Ryan@ASUS is offline   Reply With Quote
Old 22nd Feb 2016, 13:11   #23
AllanRoy
Minimodder
Hello Ryan,
Do you really think it could be a fault with the MB? I have to say since I re-flashed BIOS back up to 1402, a couple of weeks ago, the "booting into BIOS" problem has been 100% consistent when booting from cold. If I then F10/exit the BIOS it will boot into the OS as normal. I didn't have this issue with the 0802, the BIOS the board shipped with. AS for my hardware, it's more or less straight out of the CPC "Elite" list:
ASUS Maximus VIII Hero
i7 6700K
Corsair H80i GT cooler
16BG Corsair Vengeance LPX 2666Mhz
2TB Seagate Barracude
500GB Samsung 840 EVO SSD
ASUS Strix GTX 970
I would have thought this was a fairly straight-forward set up.
As for the not-sleeping problem, I may pursue the "DistributedCOM error ID 10016" as it's the only error showing up in Event viewer.
However, if it came to it, what would be involved in sending back the MB?
Cheers, Allan.
Old 22nd Feb 2016, 13:51   #24
Ryan@ASUS
Minimodder
Hi Allan,
It may be or it may not...nothing is certain in the world of computers!
That said, I see no reason why you should be getting these problems. I know other media who have tested (similar) combinations of hardware without any issues so it leads me to the conclusion it could only be an issue with the motherboard. You're right, there's nothing unusual about your particular setup.
Even if you revert back to the old BIOS to fix the booting into BIOS problem, you're still left with the sleeping problem which suggests the PC cannot or is unable to suspend to RAM (since this is effectively what is involved in sleeping) and put the CPU in a low power state. While it could be a faulty RAM module or CPU, you'd be more likely to notice these with crashing and instability.
To send it back you'd have to raise an RMA/return claim with ASUS UK. Your board would be sent back for testing and once verified faulty it would be replaced with a new board. This may take a while, I can probably expedite the case so that a replacement is issued as soon as your board is received since I have the background info on the case (and know it's an intermittent problem). If you want to pursue this please let me know and I'll speak with the appropriate person.
Ryan
Old 28th Apr 2016, 16:44   #25
AllanRoy
Minimodder
Hello Ryan,
Just to update you on where I am with the ASUS Maximus Vlll Hero. About 2 weeks ago I updated the BIOS again, this time from 1402 to 1601. Since the upgrade I pleased to say that I haven't yet experienced the problem of it booting into BIOS instead of the OS. As you know, whilst I was running with version 1402, the system, when booting up, would consistently boot into the BIOS rather then Windows. Now under 1602, that problem seems to have disappeared.
I've still got the "not sleeping" issue, but I'm hoping that if I pursue a solution for the "DistributedCOM error ID 10016", I might be able to cure this too - I just need to find some time to explore this further.
Allan.
Old 29th Apr 2016, 14:26   #26
aramil
One does not simply upgrade Windows
aramil's Avatar
aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.
Event ID: 10016
The machine-default permission settings do not grant Local Activation permission for the COM Server application with CLSID {"Long CLSID String"} and APPID
{"Long APP ID String"} to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
1. Open Regedit
2. Go to HKEY_Classes_Root\CLSID\{"whatever "CLSID" is above"}
3. Right click on it then select permissions
4. Click Advance and change the owner to Administrators group. Also click the box that will appear below the owner line. ("Replace owner ...")
5. Apply full control
6. Go to HKEY_LocalMachine\Software\Classes\AppID\{whatever "APP ID" is above}
7. Right click on it then select permission
8. Click Advance and change the owner to Administrators group
9. Click the box that will appear below the owner line
10. Click Apply and grant full control to the Administrators group
11. Go to Administrative tools
12. Open component services
13. Click Computer, click my computer, then click DCOM
14. Look for the corresponding service that appears on the error viewer (check ID's match)
15. Right click on it then click properties
16. Click security tab then click Add User. Add Local Service then apply
17. Tick the Activate local box
__________________
System: Intel i5 3570K delidded CLU @ 4.4Ghz | Asus Stabertooth Z77 |Palit GeForce GTX 980 Super Jetstream 4Gb | Samsung 840 EVO 250Gb | Samsung 1Tb F2 | WD 1Tb | Corsair 750TX v2 | 16Gb (4x4) Corsair Vengence | Corsair K90 Keyboard | XSPC-Raystorm-750-RS2400 | Zalman MS800 | AOC 27" 2560x1440 | Windows 10 Pro 64bit | Linx10 Tablet ED: CMDR Aramil Lorrathain Become a Star Citizen get 5,000 free Credits HERE
aramil is offline   Reply With Quote
Old 15th May 2016, 14:58   #27
sahartech
What's a Dremel?
sahartech has yet to learn the way of the Dremel
sahartech is offline   Reply With Quote
Old 18th Jul 2016, 10:38   #28
AllanRoy
Minimodder
Hello Aramil,
Many thanks for that - explains a few things for me, very helpful indeed.
However, the "Booting in BIOS" saga continues!! After believing the problem fixed following an update to BIOS 1602, it was - for a few weeks. I recently had to swap out a faulty optical drive and after fitting the new one, guess what, the system began booting back into BIOS again, and is now doing so consistently, at all times, whenever or however it is rebooted.
I have to say I am getting fed-up with this. I am reluctant to take out the MB and send it back for replacement, because my system will be down for at least 10 days, probably more, and I have no other system to use. Also, I understand there's still a chance ASUS may say the MB isn't faulty and simply send it back as is.
In August I have a few days off, and I'm going to reformat the HD and re-install Windows 10 from scratch, and hopefully this will work. But if it doesn't, will I be still able to send this MB back for a replacement, please, Ryan?
Allan.
Old 25th Jul 2016, 12:12   #29
Will_ASUSUK
Minimodder
Will_ASUSUK has yet to learn the way of the Dremel
Originally Posted by AllanRoy View Post
Hello Aramil,
Allan.
Hi Allan,
Ryan is no longer working at ASUS, so I will be taking over. If you need it replaced, contact your retailer and arrange a replacement. Where did you purchase it from? It's always worth trying a replacement board to be on the safe side.
Regards. Will
Will_ASUSUK is offline   Reply With Quote
Old 28th Jul 2016, 10:39   #30
AllanRoy
Minimodder
Originally Posted by Will_ASUSUK View Post
If you need it replaced, contact your retailer and arrange a replacement. Where did you purchase it from? It's always worth trying a replacement board to be on the safe side. Regards. Will
Hi Will,
The MB was bought from Scan. I appreciate you're trying to be helpful, but trying out another board is simply impractical, as I just don't have access to another Maximus Vlll Hero.
Also, the primary reason I've been so reluctant to send it back thus far, is because it's going to be incredibly inconvenient (to say the very least) for me to be without the computer for the 10 days (or longer) that's it going to take to get a replacement - and that's if they do send a replacement, because I just don't know whether this is a MB problem or not. Ryan seemed to think it was. But if I go through all the hassel and serious inconvenience of taking out the MB, sending it away and coping without my computer (which I need for my work, it's not just a games machine) for 10 days or so, only to have them send it right back saying it's fine - I'll be just about ready to... well you can probably fill in the blank yourself. Do you see my point here?
Allan.
Old 2nd Aug 2016, 11:46   #31
Will_ASUSUK
Minimodder
Hi Will,
Allan.
Hi Allan,
I completely understand. Unfortunately that is the case with returns, sounds like a product fault, if explain to Scan in depth I am sure the replacement would be sorted without fail. Unfortunately there is nothing else we can do and it is the same with replacements on any brand. I had a similar issue when I had to return my 970 a year ago.
Apologies I couldn't help any further.
Regards.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
