Old 25th Jan 2016, 15:31   #1
tiger-moth
Modder
tiger-moth has yet to learn the way of the Dremel
Thermaltake F31
I'm going to buy either the Thermaltake F31 or F51 from you.
I know the F31 is an ATX case but do you know if it will take an E-atx board measuring 10.5 inches wide (ie an inch wider than ATX?)
I like the smaller size of the F31 case.
These seem to be the only cases which fit all my criteria; quiet, will take a 240 rad in the roof, optical disk bay, fan control, will take an E-Atx board
tiger-moth is offline   Reply With Quote
Old 11th Feb 2016, 12:29   #2
tiger-moth
Modder
If anyone's interested I asked thermaltake.
My Gigabyte X99 gaming 5P will fit inside the F31, it will just cover up the rubber cable grommets a bit.
There's a picture of one inside the F31 on their publicity photos.
Be handy if companies stated how large a mobo will fit inside their cases, eg E-ATX up to 26.5cm
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
