Old 4th Feb 2016, 21:15   #1
stealth80
Supermodder
stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.
ASUS ROG PG278Q
Hi, today I received my first ever Gsync monitor was excited. I hooked it up and straight away I noticed the text was quite blurry (only the black text/fonts, desktop fonts remain sharp) and figured it was because I was switching from an IPS monitor. I toyed with the turbo switch to change the refresh rate up from 60 to 120 to 144hz, that's operation in itself was quite clumbersome, I thought I would just press it once to show and again to shift it to the next refresh rate, however it is very hit and miss.
When the rate did eventually change I noticed some flickering around the screen, especially visible on the grey bars on the NVidia settings window. I toyed some more enabling/disabling gsync and SLI and the issue remained. It seems to have calmed down now, and is only visible in around 50% of situations. It persists through gsync on and off and I have tried 3 sets of drivers. The only time the flickering is 100% not present is if I enable ULMB.
Also gsync is permanently engaged unless I disable it in the driver, even on the desktop, I was under the impression the LED would be white and gsync disabled until a game was loaded up, however it remains red (and gsync mode is on in the screens OSD).
Below is a link to my desktop showing the flickering:
https://vimeo.com/154231377
And on the below link if you watch the "yes" box on the dialogue you can see that flickering also
https://vimeo.com/154235192
Thanks
__________________
Project Temporal Snow - http://forums.bit-tech.net/showthread.php?t=314299 - In Progress
Temporal Snow Ryzen Refresh https://forums.bit-tech.net/showthread.php?t=323038
Ryzen 1700 @ 4.0 GHZ - Gigabyte AX370 Aorus Gaming 5 - 16GB GSkill Trident RGB 3200 MHZ - Palit 1080 GTX Gamerock Premium - Samsung XP941 256GB - Crucial MX300 525GB - Fractal Design R3 Newton 1000w White Edition
stealth80 is offline   Reply With Quote
Old 5th Feb 2016, 10:08   #2
Ryan@ASUS
Minimodder
Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.Ryan@ASUS is the Cheesecake. Relix smiles down upon them.
Hi there,
Could bea backlight problem, potentially an issue with the G-Sync module.
Have you tried hooking it up to another system to rule out it being a problem with your particular system?
Also have you reached out to your retailer to let them know you're unhappy, making sure you do this within that 28day window (i think its 28days) so you can easily get it replaced if need be.
Regards
Ryan Martin
Ryan@ASUS is offline   Reply With Quote
Old 5th Feb 2016, 10:18   #3
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Display refresh rate switch won't work unless the display content is actively changing - so in game this will work, but on a static desktop it won't.
Try reducing pixel overdrive function (can't remember it's called) or adjusting the sharpness, this may help.
GSync is red and ULMB is orange - is there a visible difference?
If you have ULMB enabled, GSync will certainly be off - the two cannot work together.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 5th Feb 2016, 12:43   #4
stealth80
Supermodder
Ive tried it on my wifes PC with 670GTX, i5 4670K and it was the same.
Gsync is permanently on unless I enable ULMB which then allows me to enable it on the monitor (I'm aware they are exclusive of each other) The screen physically dims when I enable ULMB and the text appears a little better. I have RMA authority from scan, I'm just going to try a different cable as ive been told elsewhere a bad cable can cause these issues, however, personally I feel its either Gsync module or the back light
__________________
Old 5th Feb 2016, 13:17   #5
stealth80
Supermodder
Originally Posted by Ryan@ASUS View Post
Hi there,
Regards
Ryan Martin
Somehow missed your post lol
Yes scan have arranged RMA for Monday, so I suspect ill be back on my 1080P for a week. Gonna grab a new displayport cable today as others have said dodgy cables can cause these issues
__________________
Old 5th Feb 2016, 15:05   #6
stealth80
Supermodder
cable didn't fix it, RMA it is Monday, thanks all
__________________
Old 8th Feb 2016, 04:26   #7
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Can you opt for a 279? That uses a better IPS panel.
ULMB will dim because the backlight syncs to refresh, which drops is frequency considerably from 200+Hz to 120/144.
__________________
Old 8th Feb 2016, 09:16   #8
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Gsync has flickering issues with SLI fella.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 8th Feb 2016, 10:44   #9
Ryan@ASUS
Minimodder
Interesting, do you have some links/sources for this please? I'd be interested to take a look.
Old 8th Feb 2016, 12:39   #10
Vault-Tec
Vault-Tec's Avatar
https://www.reddit.com/r/nvidia/comm...nchingloading/
And it happened in Witcher 3 also.
https://steamcommunity.com/app/29203...8868357494581/
http://techreport.com/news/27449/g-s...s-and-here-why
I used to get it a lot running two Titan Black with an Acer XB280HK. AFAIK it still hasn't been sorted.
__________________
MUWC Winner ROTT
Old 8th Feb 2016, 20:52   #11
stealth80
Supermodder
It did it in single card mode and on my wifes PC on her single 670gtx, defo a problem with the screen, which has now been returned, fingers crossed for the replacement
__________________
Old 9th Feb 2016, 09:10   #12
Ryan@ASUS
Minimodder
Great thanks, certainly interesting reads. I'm not sure why its specific to SLI only if its due to the way G-Sync handles stalls in the game engine. Did you ever get your problem fixed? You say used to get it a lot, why do you stop getting it now?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
