Old 10th Feb 2016, 17:41   #1
Impatience
Ultramodder
Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.
H220 X2
Could anyone comment on if you'll be stocking the new Swiftech H220x2? Only place in the UK that sells them so far is Newegg, and i'd rather use a seller i've bought from before!
Impatience is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
