Old 14th Feb 2016, 10:40   #1
PcShedTV
Minimodder
PcShedTV's Avatar
PcShedTV has yet to learn the way of the Dremel
Our Journey to 3 Million PPD
So as I am a newbie in folding (only 49 days so far) I have been trying different hardware combinations, clients and OS to see what gives best performance for cost and efficiency. Its been a interesting journey so far and very addictive.
i had a few people asking what kit i been using to achieve the rapid climb within the team so i though i give a small summary of the components
Rig 1 - Watercooled Nvidia Asus Titan's 12GB are the kings of folding in my opinion. I got two of them overclocked (boosts to 1422Mhz) and temps do not rise above 40C degrees at full load pushing out 1M -1.2M ppd.
Intel 5960x 8 core cpu watercooled, overclocked to 4.2Ghz (from 3.0Ghz) running web browser folding client
Rig 2 Aircooled 2x Gigabyte 980ti (my favorite gpu for gaming) also folding, overclocked (boosts to 1550Mhz) and this is also pushing out 1M ppd. Intel 4790K overclocked to 4.6Ghz
I also have several servers (dual cpu Quad Xeon x5570 with different gpu folding now and again;
MSI 970 GTX - OC boosts 1533Mhz, 48C - 280k- 320k ppd
EVGA 690 GTX (dual gpu in 1 pcb) - OC boosts to 1228Mhz, 68C, 180k-230k ppd (quite disapppoint with its performance)
I also had a few AMD graphics cards, MSI R9 390 8G, R7 370 4G and R9 290x but again they did not perform as good as nvidia cards and they pulled a lot of power at the wall so I decided to not use them, sell them and get more 970gtx (another one arriving next week)
After testing 3x HP Z600 servers, 1x HP Z800 and tinkering with a evga sr2 server, i decided to sell them all and build 1 mega folding PC based on a server platfform. The reason for this is simply because i want permanent folding rig with the capability of folding 2-3million million points on its own and also utilise it for video rendering/editing projects. Also my Rig 1 will be up for sale this month so I need to build another to replace and exceed its performance to get contributing to the cause.
So if anyone is interesting in buying these servers, or my main rig, let me know. Pictures, videos of them can be found on social media and Youtube.
YT - https://www.youtube.com/watch?v=gRNnbR-wRWI
FB - https://www.facebook.com/PcShed
Instagram - https://www.instagram.com/pcshedtv/
Twitter - @Pc_Shed
G+ - https://plus.google.com/+PcShedTV
Check the lastest video on the current rigs and items for sale, everything is up for sale next week:
After researching for cpu and motherboard for next weeks build, there are 2 possibilities;
2 x Intel Xeon E5-2660 (lga 2011) 8C 16HT- 2.2ghz - boosts to 3.0Ghz with 20M Cache on a Asus Z9PE-D8 WS motherboard or
1x Intel Xeon E5-2675 V3 (lga 2011-V3 16C 32HT 1.8Ghz-boosts to 2.3Ghz 40M Cache on a Asus Z10PE-D8 WS Xeon Series S2011 v3 motherboard
Any thoughts and advice on this would be very much appreciated as i never done a build on these WS platfforms and not sure what ram would be best to use on them. In regards to gpu's to go in them there will be 7 x 970GTX's using usb pci express risers to begin. Solution for electricity consumption will be a 18 panels Solar panels installation probably in September this year.
__________________
Folding stats
PcShedTV is offline   Reply With Quote
Old 17th Feb 2016, 18:08   #2
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
Multi-socket WS's used to be the best hardware for Folding during the era of the Big Advantage Project (bigadv), but that was terminated at the end of January 2015; Big Advantage News.
It was during that era that many of those using company servers (inpharm, zz9pzza and more recently Nelio) shot up through the charts. With the cessation of that project however, multi-socket WS's aren't as desirable as they used to be for Folding, which might be why you've not had a response to your post, as most Folders now don't go down this route - GPU's produce the highest PPD these days.
I can't personally comment on your platform options - my only experience is with a quad socket (48 core) Opteron WS which I still use for Core A5 projects.
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 19th Mar 2016, 18:38   #3
DocJonz
DocJonz's Avatar
PcShedTV - What's happened to the PPD???
The mag article indicated you were heading onward and upward.
__________________
Folding stats
Old 20th Mar 2016, 11:15   #4
Tattysnuc
Thinking about which mod to do 1st.
Tattysnuc's Avatar
Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.
Come back PcShedTV!!!!
My servers in bits still moving to a bigger case and fitting a loop to keep it noce and cool with summer approaching....
__________________
Folding statsFolding stats
Tattysnuc is offline   Reply With Quote
Old 20th Mar 2016, 18:14   #5
piers_newbold
What's a Dremel?
piers_newbold has yet to learn the way of the Dremel
I was getting worried PcShedTv whats happened to your ppd ?
piers_newbold is offline   Reply With Quote
Old 21st Mar 2016, 08:00   #6
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Hopefully all is good.
Edit: Just checked his FB page, link up top:
Pc Shed
March 14 at 5:48am
We are coming to the end of our little folding aspect. We will continue to fold just not as much as we have been doing mainly due to electricity costs . But we are still going to continue to strive to help others as that's our main concept of PcShed smile emoticon Feel free to get in touch for advice and tips. Hopefully more game streams and reviews of products on the way .
__________________
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX 1080 Ti SLI; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Scorpuk is offline   Reply With Quote
Old 21st Mar 2016, 13:20   #7
Tattysnuc
Tattysnuc's Avatar
So much for onward and upward.
The cynical among us might say that PCShedTV was using folding/CPC as a method of little self publicising...
I say:
Good on 'em!
Thank you for supporting our team while conducting your experiment.
Please come back and share your learnings so that we can better our team and results - don't allow your efforts and energy be wasted - hardware moves on every year and those changes make the learnings go out-of-date quite quickly.
__________________
Old 15th Apr 2016, 00:35   #8
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming Saiyan
Blimey, that was a short lived but productive spell of folding. Well then, looks like it's up to me to fit as many GPUs as possible into the 8U of rack space I have to work with. Electricity costs won't be a problem for me in the short term but cooling might as the weather gets warmer. I think it's finally time for me to invest in a proper AC unit this summer. The exhaust temp of the cabinet was hitting the very high twenties today and it wasn't even that warm outside.
__________________
"For every stalwart bit-tech-worthy tech out there, another 2 cretinous arse-scratchers are out there pulling your patches and reconfiguring your ****." - Krikkit
Unicorn is offline   Reply With Quote
Old 29th Apr 2016, 17:56   #9
desertbaker
Minimodder
desertbaker is definitely a rep cheat.desertbaker is definitely a rep cheat.desertbaker is definitely a rep cheat.desertbaker is definitely a rep cheat.desertbaker is definitely a rep cheat.desertbaker is definitely a rep cheat.desertbaker is definitely a rep cheat.desertbaker is definitely a rep cheat.desertbaker is definitely a rep cheat.desertbaker is definitely a rep cheat.desertbaker is definitely a rep cheat.
So that is what happened to PcShed. I was getting concerned I was about to slide back down the leader board!
I'm back up and running with 4 GPUs. Had to change some fans on the AMDs although I think my Nvidia 770 has died. For reasons I don't understand, my older PC with the AMD's sometimes refuses to upload finished units and download new ones until I reboot the system. Difficult to do When I am in a hotel working.
__________________
Folding stats
desertbaker is offline   Reply With Quote
Old 17th Jan 2017, 12:57   #10
Tattysnuc
Tattysnuc's Avatar
I see you're registering points again recently - please share your changes
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
