Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 21st Feb 2016, 18:42   #1
lilgoth89
Captin Calliope
lilgoth89's Avatar
lilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyan
Photo Recovery on Android
so my mother turned to be earlier on after accidentally deleting some of her old photos on her Galaxy S5 Mini and asked if i could recover them
so i fired up Recuva from Priform and set to work as normal, only to be stopped instantly by Recuva, not being able to communicate with my mothers phone, so i went to manually set it to mass storage mode only to find the option has now been removed. The only options are PTP or MTP
so basically i need a program that can recover her photos from the device either installed to the device or used from my PC
any thoughts ?
__________________
I7 3770 @ 4.5Ghz | Asrock z77 extreme 6 | 16gb hyper X Ram 1600 | SfX7870 oc |Crucial 512 gb M4 | Samsung Spin point 2tb x2 | SiverStone Raven02 | Corsair Hx 850
lilgoth89 is offline   Reply With Quote
Old 21st Feb 2016, 19:19   #2
roundyz
Multimodder
roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.
could you flash it to a rom that supports mass storage mode and leave the user partition (SD) intact?
roundyz is offline   Reply With Quote
Old 23rd Feb 2016, 19:54   #3
Buzzons
Mod Master
Buzzons is the Cheesecake. Relix smiles down upon them.Buzzons is the Cheesecake. Relix smiles down upon them.Buzzons is the Cheesecake. Relix smiles down upon them.Buzzons is the Cheesecake. Relix smiles down upon them.Buzzons is the Cheesecake. Relix smiles down upon them.Buzzons is the Cheesecake. Relix smiles down upon them.Buzzons is the Cheesecake. Relix smiles down upon them.Buzzons is the Cheesecake. Relix smiles down upon them.Buzzons is the Cheesecake. Relix smiles down upon them.Buzzons is the Cheesecake. Relix smiles down upon them.Buzzons is the Cheesecake. Relix smiles down upon them.
Worth checking to see if they've automatically been backed up to google drive? (it's usually on by default)
Buzzons is offline   Reply With Quote
Old 23rd Feb 2016, 20:50   #4
wolfticket
Downwind from the bloodhounds
wolfticket's Avatar
wolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyan
I generally wouldn't advise writing to storage you wish to recover from, but a quick search of the Play Store suggests there are a few well reviewed recovery apps for Android that would run on the device.
I think my go to recovery software PhotoRec might be able to do MTP too: http://www.cgsecurity.org/wiki/PhotoRec_FAQ
__________________
Wolfticket: Ambitious but rubbish
"A facility for quotation covers the absence of original thought."
Dorothy L. Sayers (1893 - 1957)
wolfticket is offline   Reply With Quote
Old 24th Feb 2016, 09:30   #5
Rhydian
Hypermodder
Rhydian's Avatar
Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.
Could be backed up on a few options on the phone she doesn't know about.
Dropbox and Drive etc.
Rhydian is offline   Reply With Quote
Old 26th Apr 2016, 09:03   #6
Duncan7722
What's a Dremel?
Duncan7722 has yet to learn the way of the Dremel
I also need to recover my deleted photos from my Samsung S6, any help?
Duncan7722 is offline   Reply With Quote
Old 1st Mar 2017, 14:43   #7
afrasiab
What's a Dremel?
afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.
the photos can be recovered easily by using apps which are available on playstore. I have used an app which I find on playstore which have recovered my photos.
afrasiab is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
