Reply
Thread Tools View Mode
Old 24th Mar 2016, 15:32   #21
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
I'd have thought by now we'd have moved away from riveting everything into place... seems very 2004 Chieftec Dragon of them, particularly with those mid-plates and people very often replacing them with something custom nowadays.
Mankz is offline   Reply With Quote
Old 24th Mar 2016, 17:19   #22
B NEGATIVE
All Hail Kim Jong Magoo!
B NEGATIVE's Avatar
B NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming Saiyan
From a manufacturers standpoint,it a far superior fixing method than bolts,cheaper and almost 0 chance of failure. Its very easy to see why they use them. If someone can make themselves a midplate then a few rivets are not going to cause concern. My interest in this is that CM have marketed this case as modular but used rivets.....doesnt seem right to me.
While fans are on topic,I use a small bit of insulating tape over the hole so the clip has nowhere to go,the magnet is a good idea...wont work on EK Vardars tho,the clip is plastic on those.
__________________
Missed.....
Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
B NEGATIVE is offline   Reply With Quote
Old 27th Mar 2016, 14:49   #23
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
@jojo, Thanks buddy!
@Mankz, it baffled me as to why CM used rivets too, btw, Havent heard from you in awhile, hope everything is good!
@BNEG, good tip! and riveting also saves in production costs, easier and faster for factory assembly workers over screws
HAPPY EASTER!
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 27th Mar 2016, 16:00   #24
keenan
Supermodder
keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.
Outstanding Bill! Can't wait to see the finished result..
__________________
Project Marshlands
keenan is offline   Reply With Quote
Old 27th Mar 2016, 16:36   #25
C3PU
What's a Dremel?
C3PU has yet to learn the way of the Dremel
Top class as usual.
C3PU is offline   Reply With Quote
Old 30th Mar 2016, 13:56   #26
mnpctech
bit-tech sponsor
mnpctech's Avatar
Thank you for tuning in and commenting guys! I scored this Gigabyte OC Force Z87X MB from a friend. Just need water block for the CPU. Still debating on GPU(s)
__________________
Old 11th Apr 2016, 20:08   #27
mnpctech
bit-tech sponsor
mnpctech's Avatar
Some of you may find this guide I made over this weekend of interest. I rattle bomb a PC chassis with Plastikote's Engine Enamel paint. Great low cost alternative!
__________________
Old 12th Apr 2016, 17:24   #28
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
rep
-'Spring' in Minnesota, still in a coat and cap.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 14th Apr 2016, 15:22   #29
mnpctech
bit-tech sponsor
mnpctech's Avatar
LOL, we finally hit 60F yesterday, hopefully it stays
__________________
Old 15th Apr 2016, 03:10   #30
noobas4urus
Multimodder
noobas4urus's Avatar
noobas4urus is a Super Spamming Saiyannoobas4urus is a Super Spamming Saiyannoobas4urus is a Super Spamming Saiyannoobas4urus is a Super Spamming Saiyannoobas4urus is a Super Spamming Saiyannoobas4urus is a Super Spamming Saiyannoobas4urus is a Super Spamming Saiyannoobas4urus is a Super Spamming Saiyannoobas4urus is a Super Spamming Saiyannoobas4urus is a Super Spamming Saiyannoobas4urus is a Super Spamming Saiyan
As long as it's not -20F it's spring here. Looking forward to seeing this one in person Bill!
__________________
noobas4urus is offline   Reply With Quote
Old 15th Apr 2016, 13:20   #31
arduum
Minimodder
arduum has yet to learn the way of the Dremel
I like this project!
Reminds "gulf" poject
arduum is offline   Reply With Quote
Old 20th Apr 2016, 13:35   #32
mnpctech
bit-tech sponsor
mnpctech's Avatar
@noobas4urus, right on man!
@ardumm, thanks for tuning in and commenting!
I'm juggling time between my build and this deepcool genome build for computex atm
__________________
Old 21st May 2016, 20:13   #33
mnpctech
bit-tech sponsor
mnpctech's Avatar
Finally finished the Deepcool GENOME PC for 2016 Computex, so I can back to my build (Yay!) I scored this new Bitspower Summit EF cpu waterblock cheap on Ebay, and I do like the smoked acrylic top.
Cooler Master Mastercase 5 got a new front bezel grill laser cut from 1/8" thick Transparent Fluorescent Orange acrylic sheet
__________________
Old 9th Jun 2016, 14:30   #34
mnpctech
bit-tech sponsor
mnpctech's Avatar
Yes, I'm alive. Thank you for being patient. I had to halt progress on my build to fulfill commitments for Computex. Over the past 3 weeks I bought on 4790K for $225 shipped and $300 for reference GTX 980 on Ebay auctions. Fyi: Prices on used 980s are falling on Ebay as people upgrade to 1080s. I have one more build to finish, and I'll back on the track with this one!
Here is the PC I created for Deepcool's booth at Computex, http://mnpctech.com/deepcool-genome-...se-review.html
__________________
Old 2nd Jul 2016, 14:51   #35
mnpctech
bit-tech sponsor
mnpctech's Avatar
The extended holiday has bought me some time to work on my build. I recently scored EK water block for the Gigabyte OC force motherboard. It directly cools Intel Z87 southbridge (PCH), PLX PEX 8474 PCIe lane splitter as well as power regulation (VRM / MOSFETs) module. This will also compliment the stainless steel liquid lines nicely.
__________________
Old 2nd Jul 2016, 16:38   #36
ToddK
Multimodder
ToddK's Avatar
ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.
You guys and your amazing paint...
ToddK is offline   Reply With Quote
Old 18th Jul 2016, 19:45   #37
mnpctech
bit-tech sponsor
mnpctech's Avatar
Thanks Todd! On that note, it hurt to make the 3/4" hole into the paint to route the 316 stainless steel pc liquid cooling tube from the front radiator, but it just makes sense this way. I need to pick-up a bottle of the GULF Blue paint, so I can touch up the exposed steel in the hole. I modified one of the INLET/OUTLET black rubber grommets from NZXT Phantom to finish the mid section hole. Last night I bent the first SS tube of the loop. The stainless steel compression fittings are my own design. I wanted fitting that discreet in size and matched the tubing.
Mnpctech Stainless Steel 1/2" OD Compression Hardline Fitting
__________________
Old 27th Jul 2016, 15:11   #38
mnpctech
bit-tech sponsor
mnpctech's Avatar
Just a small update as my free time to work on this is getting more scarce. I've been bending the tubing and learning the ways of the Stainless Jedi. I love the look of stainless steel. It echos the fuel and brake lines on race cars, but has it's own learning curve. In retrospect, the scale of PC chassis is just too small for the 1-1/2" bends you get with the SS bending mandrels I've found.. Suppose I could go thicker wall and make custom mandrel, but I'll try 3/8" OD instead of 1/2" OD next time.
Specs: Stainless T-304/304L, Seamless Tube, 0.5" x 0.035" x 0.43"
__________________
Old 27th Jul 2016, 16:19   #39
Quantum-192
Modder
Quantum-192 has yet to learn the way of the Dremel
Bill it certainly is a thing of beauty with that paint job and the MNPCTEC stainless fittings look awesome - you displayed them on Sunday's Monkey Video and I was impressed with their simple but effective style.
Now, you just need to do them in brass and for 12mm tube and I know a build they would drop straight in very nicely
__________________
Project Evie Steampunk Build
Quantum-192 is offline   Reply With Quote
Old 27th Jul 2016, 22:12   #40
mnpctech
bit-tech sponsor
mnpctech's Avatar
How many fittings in 12mm and what grade is the Brass?
and Thank you! and glad to hear you watched the hangout, too
__________________
Reply
Tags
cooler master mods, mastercase window, mnpctech
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
