Reply
Thread Tools View Mode
Old 15th Aug 2016, 18:20   #41
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
I cut and bent the final piece of SS tubing yesterday. I really liked the challenge in using something different. I also like it's bright metallic finish. It doesn't absorb smudges, fingerprints, so maintenance it easy. The biggest advantage to using stainless for PC water cooling is it's corrosion resistant properties. It does require specialized tools that include a hacksaw with bi-metal cutting blade, hand files and deburr tool. You must deburr the edges of the tubing to avoid slicing into rubber o-rings for your compression fittings. It also requires a specialty bending tool, like a hand pipe or mandrel bender. I recommend the 600 series bender by Rigid Tool or Imperial brand tube benders, these are the lowest cost. Type of stainless tubing I used for my loop is T-304/304L, Seamless Tube in 0.5" x 0.035" x 0.43"
Mnpctech Stainless Steel 1/2" OD Compression Hardline Fitting
Tools & Supplies Used:
*RIGID 600 Series Tubing Bender
*Table Vise with Terry Cloth towel, to avoid scratching tubing.
*Micro Hand File
*Hacksaw with Bi-Metal Cutting Blade
*Table top grinder
*50 grit sand paper
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 16th Aug 2016, 13:52   #42
ToddK
Multimodder
ToddK's Avatar
ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.ToddK is the Cheesecake. Relix smiles down upon them.
I've wanted to do metal tubing for a while now. This will be great to follow. I guess choice of metal would be something to be aware of.
ToddK is offline   Reply With Quote
Old 16th Aug 2016, 20:43   #43
mnpctech
bit-tech sponsor
mnpctech's Avatar
hey Todd, I'm using T-304/304L, Seamless Tube in 0.5" x 0.035" x 0.43" with distilled water
I also changed my mind about the UV Orange front grill, applied primer coat while debate about leaving it matte black? or painting it the GULF blue to match the case body?
Remember Mnpctech 120mm blow hole fan grill kit?....looks evocative a fuel filler cap ring, and will be mounted in the top window of the mastercase, http://mnpctech.com/cooler-master-ma...se-top-window/
__________________
Old 16th Aug 2016, 22:28   #44
eucalyptus
I am 19 and Swedish!
eucalyptus's Avatar
eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.
I am speechless
Or I am not, because Owen are in the top 3 best modder in the world...................
__________________
Project Three Leaves / Build log / Galleries - Daylight / Night Vision / My setup
V8 Ocean / Build log
Follow- or send me a message on Facebook /Sebastian Edemalm
eucalyptus is offline   Reply With Quote
Old 17th Aug 2016, 23:45   #45
mnpctech
bit-tech sponsor
mnpctech's Avatar
Thank you for checking out the build and posting eucalyptus I hope to have another update posted in the morning
__________________
Old 18th Aug 2016, 14:25   #46
mnpctech
bit-tech sponsor
mnpctech's Avatar
Dressing up the 120mm Typhoon GT fan with machined overkill grill with Blue anodized washers for M3 screws, http://mnpctech.com/screws-anodized-...-corsair-xspc/
120mm machined aluminum Overkill Ring fan grill, http://mnpctech.com/pc-computer-cool...grills-custom/
__________________
Old 18th Aug 2016, 14:44   #47
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Love it. Any possibility of painting the water pipes to match though? never seen that done yet.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 18th Aug 2016, 15:46   #48
B NEGATIVE
All Hail Kim Jong Magoo!
B NEGATIVE's Avatar
B NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming Saiyan
BURN THE HERETIC!!!
__________________
Missed.....
Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
B NEGATIVE is offline   Reply With Quote
Old 18th Aug 2016, 17:22   #49
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Kinda liked the UV orange, though...
@Vault-tec - You don't just ask someone who spent WAY too much money on stainless pipes to paint them, dude!
-Although you could sneak a little paint in the groove of the compression fitting nuts to see how it looks.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 20th Aug 2016, 15:13   #50
mnpctech
bit-tech sponsor
mnpctech's Avatar
I can see how matching tubing would look nice, too. I chose this type of tubing because it's evocative of the fuel and brake lines used in street performance and racing cars. I really like the look and challenge of using something different than mainstream tubing like flexible or PETG etc.
Advantages of Stainless Steel Hard Line:
Bright metallic finish is aesthetically pleasing. SS doesn't absorb dirt, smudges, fingerprints or scuffs, making maintenance very easy. The biggest advantage to using 316 Marine Grade stainless for PC water cooling is it's corrosion resistant properties, so you can use distilled water in your loop.
Disadvantages of Stainless Steel Hard Line:
Costs more than traditional flexible tubing, acrylic petg etc. Stainless steel requires more time and specialized tools that include a hacksaw with bi-metal cutting blade, hand files and deburr tool. You must deburr the edges of the tubing to avoid slicing into rubber o-rings for your compression fittings. It also requires a specialty bending tool like the Rigid I used or mandrel pipe/ tubing bender. Tightest radius bend you can get with 1/2" OD in 0.035" wall thickness is 1-1/2" which makes it very challenging when used in a PC chassis, so you have to get inventive with your bends or use 90 degree fittings.
__________________
Old 20th Aug 2016, 17:17   #51
B NEGATIVE
B NEGATIVE's Avatar
Corrosion is entirely dependent on the surface potential of the material,SS wont suffer but thats not to say other metals in the loop wont be stripped. All kind of moot as Watercool have used slabs of SS for years as covers but its still something to consider. Pretty much any SS grade would be ok for our use tbh,IIRC low carbon grades are best for bending....I could have that wrong tho.
Im surprised,seeing as you were aiming for the motorsport look,that you didnt use braided and banjo bolts?
__________________
Missed.....
Old 20th Aug 2016, 18:33   #52
Vault-Tec
Vault-Tec's Avatar
Originally Posted by B NEGATIVE View Post
BURN THE HERETIC!!!
I'd just pee on your fire
__________________
MUWC Winner ROTT
Old 22nd Aug 2016, 15:57   #53
mnpctech
bit-tech sponsor
mnpctech's Avatar
I don't like the braided look and did hood pin latches in past build. I go with what feels right for me when it's my own build. Top blow hole exhaust fan grill, this reminded me of racing car fuel cap assembly, it's installed with 120mm Typhoon GT fan and M3 Blue anodized socket head washers, http://mnpctech.com/screws-anodized-...-head-washers/
120mm top blow hole kit, http://mnpctech.com/pc-computer-cool...-hole-fan-kit/
__________________
Old 5th Sep 2016, 13:46   #54
mnpctech
bit-tech sponsor
mnpctech's Avatar
Milling billet cable combs for the 24 pin ATX cable, http://mnpctech.com/buy-stealth-cable-combs-for-pcs/
__________________
Old 5th Sep 2016, 14:32   #55
Quantum-192
Modder
Quantum-192 has yet to learn the way of the Dremel
Those combs look amazing Bill.
Ever thought of doing some that are totally enclosed (so the cables thread through them) and then engraving MNPCTECH across the flat face.....they would look so cool on builds. You could even have anodised colours.....and brass ones for steampunk builds
__________________
Project Evie Steampunk Build
Quantum-192 is offline   Reply With Quote
Old 5th Sep 2016, 16:47   #56
neSSa
Supermodder
neSSa's Avatar
neSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run Crysis
Beautiful combs, will fit perfectly with pipes
neSSa is offline   Reply With Quote
Old 6th Sep 2016, 15:02   #57
mnpctech
bit-tech sponsor
mnpctech's Avatar
@neSSa, Agreed, I really like that look!
@Quantum-192, Yes, different styles would be cool! Are you using 4mm sleeving? I'm getting sample of 4mm MDPC-X sleeve to test. Overview of billet comb with 3mm OD sleeve
__________________
Old 6th Sep 2016, 15:30   #58
Quantum-192
Modder
Yes mate. 4mm sleeving for me.
I have now resleeved all of Evie's cables completely with MDPC-X sleeving.
Just watched your video on the combs and can see your rationale of making them 'clip in' for users that don't want to take their cables apart.....how about making a clip on plate with MNPCTECH engraved or milled on it that could be added after the comb had been clipped in to the cable? That would would be a great addition?
__________________
Old 7th Sep 2016, 13:25   #59
mnpctech
bit-tech sponsor
mnpctech's Avatar
Yea, lots of manufacturers and small shops offering custom order or pre-sleeved cables, so these give people option to add combs after cables are made. I was thinking of doing that for limited edition series with slightly different design. I need to check out Evie
__________________
Old 7th Sep 2016, 14:24   #60
Quantum-192
Modder
Look forward to seeing the custom combs Bill
I must admit I love your MNPCTECH products as they are of the very highest quality and design. You can see from Evie that I have your grills on the front and top of the case and I have another lot of your stuff going in my next build to.
I ordered one of your graphics card supports direct from you a few months ago.....you will be very surprised at how I'm planning to use it in the new build - certainly not how I imagine you thought it would be used when you designed it .....
I get most of my MNPCTECH stuff from Graeme at Kustom PC here in the UK but it was a pleasure dealing direct too.
Anyway, enough high jacking of your build log.......when will we see more of this beauty?
__________________
Reply
Tags
cooler master mods, mastercase window, mnpctech
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
