Old 15th Apr 2016, 10:54   #1
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
v6 client
Had to stop using my v6 client for the opteron as it just want getting any work units.
So now using v7 client and getting almost half the PPD.
__________________
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX 1080 Ti SLI; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Scorpuk is offline   Reply With Quote
Old 15th Apr 2016, 13:42   #2
Tattysnuc
Thinking about which mod to do 1st.
Tattysnuc's Avatar
Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.
Can you not specify which types of workunits to take by preference?
I've not played around with it, but I thought it was possible via the advanced options.
__________________
Folding statsFolding stats
Tattysnuc is offline   Reply With Quote
Old 15th Apr 2016, 13:44   #3
Tattysnuc
Tattysnuc's Avatar
List of performance by project/hardware:
https://docs.google.com/spreadsheets...2bf0/pub?gid=2
__________________
Old 15th Apr 2016, 13:46   #4
Tattysnuc
Tattysnuc's Avatar
List of advanced options:
http://www.overclock.net/t/979691/in...vanced-options
Not sure how up to date this is.
I suspect however that the projects you were processing were V6 specific and have dried up, like the BIGADV projects.
Wish they'd do some more projects like that again. It feels like there's been no initiatives from Stanford for ages, although that's probably more due to my ignorance.
__________________
Old 15th Apr 2016, 14:30   #5
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming Saiyan
I wasn't aware there was even any v6 work left to be done. I thought v6 had been dead for well over a year, since BIGADV was scrapped at the start of 2015. But I was out of the project fora couple of years and missed the whole v7 client launch, so it comes as no surprise that I didn't know the v6 clients would still get work.
__________________
"For every stalwart bit-tech-worthy tech out there, another 2 cretinous arse-scratchers are out there pulling your patches and reconfiguring your ****." - Krikkit
Unicorn is offline   Reply With Quote
Old 15th Apr 2016, 17:28   #6
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
Scorpuk - I switched my Opteron over to v7 after they ceased the BigAdv programme.
What you need is BigAdv-type WU's on the Opteron, i.e. those that run the A5 core rather than the A4 core. In order to do that you need to add two 'extra slot options' (what used to be called 'flags');
(1) client-type=bigadv, and
(2) max-packet-size=big
The points won't be anywhere near BigAdv levels - those days are gone - but they will be at the full potential of your Opteron cores.
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 15th Apr 2016, 17:54   #7
DocJonz
DocJonz's Avatar
For general info:
As far as I know the v6 client can still be used, i.e. it has not been deprecated yet. Obviously it is not being updated though.
For general clarity:
The v6 client doesn't do the Folding - that's done by the Cores - it just oversees the handling of Cores and WU's, and receiving/sending data/results.
__________________
Folding stats
Old 15th Apr 2016, 18:23   #8
Scorpuk
Hypermodder
Cheers Doc.
I didn't know what flags to use in v7, so just kept running with v6 as it seemed to work ok. Well until now.
Will probably be taking the opterons off over the next month as I move my media server to this case and expand the collection of drives.
Can stick a 970 in there to get more PPD than the opterons.
__________________
Old 15th Apr 2016, 18:26   #9
Scorpuk
Hypermodder
__________________
Old 15th Apr 2016, 18:43   #10
DocJonz
DocJonz's Avatar
That's the depressing thing for multi-socket machines - my GTX 960 has a greater PPD than my 48 Operton cores
__________________
Folding stats
Old 15th Apr 2016, 22:50   #11
Scorpuk
Hypermodder
Bleh. not getting anything either on client v7 with those settings
Code:
18:27:57:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m18:27:57:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
18:27:57:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m18:27:58:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m18:27:58:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
18:27:58:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m18:27:59:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
18:27:59:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m18:28:00:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m18:28:00:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
18:28:59:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m18:29:00:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
18:29:00:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m18:29:00:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m18:29:00:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
18:29:16:WU01:FS00:0xa4:Completed 500000 out of 500000 steps (100%)
18:29:17:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
18:29:27:WU01:FS00:0xa4:
18:29:27:WU01:FS00:0xa4:Finished Work Unit:
18:29:27:WU01:FS00:0xa4:- Reading up to 5429088 from \"01/wudata_01.trr\": Read 5429088
18:29:27:WU01:FS00:0xa4:trr file hash check passed.
18:29:27:WU01:FS00:0xa4:- Reading up to 5822260 from \"01/wudata_01.xtc\": Read 5822260
18:29:27:WU01:FS00:0xa4:xtc file hash check passed.
18:29:27:WU01:FS00:0xa4:edr file hash check passed.
18:29:27:WU01:FS00:0xa4:logfile size: 342163
18:29:27:WU01:FS00:0xa4:Leaving Run
18:29:30:WU01:FS00:0xa4:- Writing 11625915 bytes of core data to disk...
18:29:33:WU01:FS00:0xa4:Done: 11625403 -> 11019899 (compressed to 94.7 percent)
18:29:33:WU01:FS00:0xa4: ... Done.
18:29:34:WU01:FS00:0xa4:- Shutting down core
18:29:34:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
18:29:35:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:29:35:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7528 run:61 clone:0 gen:496 core:0xa4 unit:0x0000027bfbcb017d55990af7d2ef3105
18:29:35:WU01:FS00:Uploading 10.51MiB to 128.143.199.97
18:29:35:WU01:FS00:Connecting to 128.143.199.97:8080
18:29:41:WU01:FS00:Upload 26.17%
18:29:47:WU01:FS00:Upload 52.33%
18:29:53:WU01:FS00:Upload 76.12%
18:30:01:WU01:FS00:Upload complete
18:30:01:WU01:FS00:Server responded WORK_ACK (400)
18:30:01:WU01:FS00:Final credit estimate, 8731.00 points
18:30:01:WU01:FS00:Cleaning up
18:30:36:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m18:30:37:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
18:30:37:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m18:30:37:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m18:30:37:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
18:33:13:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m18:33:14:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
18:33:14:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m18:33:15:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m18:33:15:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
18:37:28:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m18:37:28:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
18:37:28:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m18:37:29:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m18:37:29:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
18:44:19:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m18:44:20:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
18:44:20:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m18:44:20:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m18:44:20:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
18:55:26:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m18:55:27:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
18:55:27:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m18:55:28:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m18:55:28:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
19:13:21:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m19:13:22:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
19:13:22:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m19:13:23:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m19:13:23:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
19:42:25:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m19:42:27:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
19:42:27:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m19:42:28:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m19:42:28:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
20:29:23:WU00:FS00:Connecting to 171.67.108.45:8080
\x1b[93m20:29:23:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
20:29:23:WU00:FS00:Connecting to 171.67.108.204:80
\x1b[93m20:29:24:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m20:29:24:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
__________________
Old 16th Apr 2016, 07:16   #12
DocJonz
DocJonz's Avatar
I'm also getting the same issue now - it is possible there is an issue with the AS, or a shortage of A5-based WU's. Delete the CPU slot configuration and start a new one - that should reset the Folding Slot ID which should allow it to point to a different AS to at least get some work.
Edit: Seems there's a shortage of WU's for multi-core (>24 core) machines; Folding Forum link.
__________________
Folding stats
Old 16th Apr 2016, 11:55   #13
Scorpuk
Hypermodder
Again cheers Doc.
Now running with 24, 24, 16. See what I get.
__________________
Old 27th Apr 2016, 07:29   #14
DocJonz
DocJonz's Avatar
Update:
Looking on the official Folding Forum, though the v6 client should still be valid to use, not many of the servers are issuing work to this client any more, so the recommendation is to upgrade to the v7 client.
__________________
Folding stats
Old 29th Apr 2016, 10:49   #15
Unicorn
Unicorn's Avatar
For general info:
Thanks Doc, I knew this but I fell into the bad habit of writing about it incorrectly years ago and old habits die hard!
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
