Old 20th Apr 2016, 14:04   #1
giskard
System builder
giskard's Avatar
giskard has yet to learn the way of the Dremel
TurboV for Windows 10
I've upgraded from Win7 to Win10 but there's no Asus TurboV application that I can find will install to Windows 10. Is there a Windows 10 version available?
__________________
Intel i7-920 @ stock | Asus P6T SE | Arctic Freezer Pro 7 rev 2 / AS5
12GB Corsair DDR3 1600 | Sapphire HD 4670 Ultimate Edition 512MB
Corsair HX520 | Antec P193 | Samsung F3 500GB system disk
giskard is offline   Reply With Quote
Old 20th Apr 2016, 18:54   #2
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
Just install the Windows 7 version. If that doesn't work and a Windows 8/8.1 version is available, install that.
__________________
ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480@RX580 8GB with VRAM strap mod | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv TG | CM Masterkeys Pro L | Logitech G502 | Logitech G920 | ASUS ZenBook UX305F
TheMadDutchDude is offline   Reply With Quote
Old 20th Apr 2016, 19:24   #3
giskard
System builder
giskard's Avatar
I tried both those options but the installer says that the OS is incompatible and exits.
__________________
Old 20th Apr 2016, 19:41   #4
TheMadDutchDude
Flying Dutchman
How strange. I'll try to install it here and see if it does the same thing.
__________________
Old 20th Apr 2016, 20:07   #5
giskard
System builder
giskard's Avatar
Thanks, much appreciated
__________________
Old 2nd Aug 2016, 21:07   #6
wormy
Supermodder
wormy is definitely a rep cheat.wormy is definitely a rep cheat.wormy is definitely a rep cheat.wormy is definitely a rep cheat.wormy is definitely a rep cheat.wormy is definitely a rep cheat.wormy is definitely a rep cheat.wormy is definitely a rep cheat.wormy is definitely a rep cheat.wormy is definitely a rep cheat.wormy is definitely a rep cheat.
I've had the same, on a different board, and had no luck trying to install the W7 version but didn't yet try the 8 version.
wormy is offline   Reply With Quote
Old 2nd Aug 2016, 22:46   #7
TheMadDutchDude
Flying Dutchman
I forgot to get back to you on this ... I had the same issue.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
