Old 22nd May 2016, 17:39   #1
Jeff Hine
Full-on self-deprecator
Jeff Hine has yet to learn the way of the Dremel
Group tests articles/Labs.
Not 100% sure if this goes here, so if it has to be moved to where it 'should be', then apologies in advance.
When doing Group tests, is there any benefit to comparing what's on test to similar (even generic) previous generation kit, for those of us that are only able to upgrade at 2+ year intervals?
Group test articles are always high on my interest charts & I find that the results would frequently be more meaningful if they compared to older tech., aside from the obvious "it's bound to be better, 'cos it's newer" outlook.
Put another way, is delving into direct comparisons of technical spec's of (for example) a GTX960 to a GTX660 no longer a valid approach to researching an upgrade & is 'better power efficiency', etc. enough to decide that 'this is what you should be using'...?
__________________
Gigabyte Z97X Gaming 3//4690K w/ AC Freezer i11//32GB 18660hz Corsair Vengeance//500GB Samsung 850EVO//2GB MSI GTX660 Twin Frozr III//750w OCZ ZT//Win10 Home
Thinkin' little of myself - I do it, so you don't have to.
World of Warcraft™ may be an old game, but it still deserves 'love'
Jeff Hine is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
