Old 29th May 2016, 08:44   #1
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
GTX 1080 PPD
Seems there are some early adopters in the other Folding teams in the US (quicker access to hardware, and better prices than the UK ...), and the numbers look promising - Post by Torin3 - with PPDs between 750-890k
If anyone sees any further PPD figures, or figures for non-Founder Edition cards, or for GTX 1070's in the coming week or so, pop them in this thread.
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 31st May 2016, 23:18   #2
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
Thanks for the update.
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Old 8th Jun 2016, 23:19   #3
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Let us know how ya get on with your 1080 Doc.
I'd guess 1070 will be in the region of 280k to 420k extrapolating the 1080's possible 750k to 890k. Depending on what overclocking is available.
Hopefully see 1070's appearing online soon with estimated prices, but probably around 300 - 400.
__________________
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX 1080 Ti SLI; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Scorpuk is offline   Reply With Quote
Old 9th Jun 2016, 08:04   #4
DocJonz
DocJonz's Avatar
You know me too well
Current plan is to replace my four GTX 780 Ti's with a couple of GTX 1080's - this will lead to less power draw (TDP down to 180W from 250W), fewer cards (and therefore further lowering juice bills), at the same time as increasing PPD. That's a Win-Win-Win in my books
__________________
Folding stats
Old 16th Jun 2016, 13:21   #5
Scorpuk
Hypermodder
Very tempted with the 1080 clown card.
__________________
Old 4th Jul 2016, 13:20   #6
Scorpuk
Hypermodder
Not sure about either going for 1070 or 1080.
No cheap 1080's now with the clown card rising in price by about 50.
__________________
Old 4th Jul 2016, 13:50   #7
Scorpuk
Hypermodder
Some GTX1070 folding figures here:
http://forums.evga.com/GTX-1070-PPD-m2497761-p2.aspx
AVG PPD: 569,252
__________________
Old 9th Jul 2016, 21:30   #8
piers_newbold
What's a Dremel?
piers_newbold has yet to learn the way of the Dremel
gtx 1080 ppd
Hi Doc
Just fitted a gtx 1080 and i am getting 811973 ppd unclocked and it runs alot cooler
Piers
piers_newbold is offline   Reply With Quote
Old 10th Jul 2016, 08:46   #9
DocJonz
DocJonz's Avatar
Originally Posted by piers_newbold View Post
Hi Doc
Piers
I think the word people use is 'sweet'!
Which card did you go for?
Are you running it under Win or Linux?
__________________
Folding stats
Old 10th Jul 2016, 15:26   #10
piers_newbold
What's a Dremel?
Hi Doc
I went for a palit card and i'm running it under windows 10
Old 16th Jul 2016, 10:22   #11
DocJonz
DocJonz's Avatar
I popped a couple of GTX 1080's in at the beginning of the week (replacing some GTX 780 Ti's) ...
PPD seems very variable - depending on WU, they are getting between 520k (P92xx projects mainly) and 1000K (P11406 Project) PPD each - see PC called 'Study' in my Sig web-link (below) for real-time numbers.
(Cards are EVGA GTX 1080 SC, running under Ubuntu 16.04, nVidia driver version 367.27)
__________________
Folding stats
Old 29th Jul 2016, 18:20   #12
chin913
忍び So say we all
chin913's Avatar
chin913 has yet to learn the way of the Dremel
[/URL]
Just put 2 gtx 970s in , any idea what ppd I should get ? i have the sli bridge on aswell
__________________
Folding stats
chin913 is offline   Reply With Quote
Old 29th Jul 2016, 20:59   #13
DocJonz
DocJonz's Avatar
For GTX 970's, check out real-time numbers in my sig - look for; Farm1, Farm2, Tester and P5QDeluxe ...
__________________
Folding stats
Old 29th Jul 2016, 21:11   #14
Scorpuk
Hypermodder
Try folding without the CPU folding.
Further up this thread I posted a link for GTX 1070 PPD where he got an average of about 500k on one card.
__________________
Old 29th Jul 2016, 22:47   #15
Scorpuk
Hypermodder
lol my bad, well bad eye sight. Thought you said 1070. 😶
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
