Old 10th Jun 2016, 11:41   #1
hairyknacker
Multimodder
hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.
D5 pump noise
I refilled my loop a few days ago as I was replacing my GPU and now the pump makes a knocking/squeezing noise but stops if I tip the front of the case up by 6 inches or so.
Is this just air in the loop or something more serious as it never used to make this noise at all previously.
Temps seem fine but just getting annoyed by this noise
hairyknacker is offline   Reply With Quote
Old 10th Jun 2016, 11:44   #2
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
It sounds like there may be air in the loop.
__________________
Gamer: ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480 8GB | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv Tempered Glass | Win 10 Home | CM Masterkeys Pro L | Logitech G502 | Logitech G920
Ultrabook: ASUS ZenBook UX305F
TheMadDutchDude is offline   Reply With Quote
Old 10th Jun 2016, 11:46   #3
Big Elf
“not another f—-ing elf”
Big Elf's Avatar
Big Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming Saiyan
Sounds like it could be air but there's also the slight possibility of bearing wear that you can only check by removing the pump top and rotor and looking at both the bearing and the rotor.
If it was starved of water for more than a minute when filling it's enough to damage the bearing.
__________________
Case Labs TH10│Asus Rampage III Extreme│Core i7 990X│24GB Corsair Dominator GT│GTX Titan SLI│Samsung 850 EVO 256GB│Crucial M4│2TB Samsung Momentus x 2│SeaSonic P1000W│EK Supremacy│EK FC-RE3│EK-FC Titan SE x 2│EK-RAM Dominator│Black Ice SR-1 480 x 3│Swiftech 35X2
Big Elf is offline   Reply With Quote
Old 10th Jun 2016, 11:49   #4
hairyknacker
Multimodder
If the front of the case is tipped either up or down by a few inches the noise stops so I am hoping it is just air but it has not taken this long before to clear the air out of the loop- been around 4 days on and off
Old 10th Jun 2016, 14:31   #5
hairyknacker
Multimodder
must be air as I keep hearing lumps of water falling in the rads so keep running it till the air bleeds I suppose- taking forever- never this long before
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
