As title says which is better. I have the pa120.2 now but can get the monsta for a good price. My temps now 65c with a 4690k @4.7ghz with 1.281 volts. 50c with 290 @1000/1250 or 56c @1200/1600. I was also thinking about getting rid of my 360, as not sure of the make and only 33mm thick and using the fans to bring cool in the case.
The 240 Monsta is a beast of a rad, and it's 20mm thicker than the Thermochill 120.2. If you have the room, give the Monsta a go.
I got room but sure if i be able to run push/pull, do you think i would be able to get rid of that 360 and just keep the monsta and the 120mm. Sent from my iPhone using Tapatalk
