Go Back   bit-tech.net Forums > Partner Forums > Asus UK
Reply
Thread Tools
Old 20th Jun 2016, 15:22   #1
Zayfod
Multimodder
Zayfod's Avatar
Zayfod has yet to learn the way of the Dremel
Transformer tf701t keyboard deck, repair or replacement.
Hi,
The keyboard dock for my Transformer tf701t has broken after two and a half years of daily use, and I'm looking to either get it repaired or buy a replacement.
The metal supports in front of the clips dropped off over the last couple of weeks, and as of last night it no longer pairs with the tablet.
Thanks in advance.
__________________
A voice of reason... mainly ignored...
Deviant Art Gallery
Tyan Tiger K8W, dual AMD Opteron 240, 3Gb Ram. Dual core, the old fashioned way!
Zayfod is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
