Old 10th Jul 2016, 01:15   #1
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyan
Linux questions
Do clients running on Linux still run faster and produce more ppd than Windows? If so, which distribution would you recommend for a Linux newbie, and would installing wine affect the speed?
If I install wine, should I use the Windows installer or the Linux installer?
The PC I fold on is only used for fah and bit torrent, so compatibility with anything else is not an issue (I do, however, run Firefox to connect to the stats server and folding forums, but am sure Linux has a good enough browser for that).
The more minimal the distro the better, although I would find it useful to have a gui if anyone can also suggest which gui will be easiest for a Windows veteran to get used to
My only other requirement is that it must support the RAID 5 array that I have about 6 TB of data stored on.
If it makes a difference, the system has an i7 6700K CPU and a pair of GTX 580 cards (which I would like to be able to overclock the same as in Windows, using something like MSI Afterburner).
__________________
HeatWare
debs3759 is offline   Reply With Quote
Old 10th Jul 2016, 09:02   #2
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
@Debs - I'll try and address your points as best as I can;
1. Normally you get a roughly 10% speed benefit from Linux over Windows.
2. I use Ubuntu, but others have their favourite flavours of Linux.
3. Long time since I used Wine, so can't really comment.
4. Firefox is the default browser in Ubuntu.
5. 'Ubuntu' has minimal install versions as well as full fat ones.
6. Ubuntu is GUI based.
7. Ubuntu supports Raid 5 (and other Raid types).
8. Most overclocking software that runs in Windows doesn't run in Linux. 'Old school' overclocking via the BIOS is surely the preferred route
If you go down the Linux route, it is beneficial, but there is something of a learning curve if you are just used to Windows.
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 10th Jul 2016, 22:40   #3
debs3759
debs3759's Avatar
Thanks. Not sure that I want to mod the GPU BIOS Sounds like a minimal ubuntu install will be worth trying.
I've had to underclock GPU2 as it keeps overheating and freezing.
__________________
HeatWare
Old 11th Jul 2016, 07:48   #4
DocJonz
DocJonz's Avatar
Sorry, I mis-read your post and thought you were looking to overclock the CPU ...
There are ways to adjust your GPU - you can use something called 'coolbits'. I've used it in the past to override the GPU's fan speed for example.
__________________
Folding stats
Old 11th Jul 2016, 08:34   #5
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
This is true only for the desktop variants; Ubuntu Server does not install a desktop environment ('GUI') by default.
Again, this isn't strictly true; its support depends entirely on how the existing array was created. Ubuntu will happily work with hardware RAID, and it also supports various types of software RAID. If the original array was created as a software RAID array under Windows, though, Ubuntu hasn't a cat in hell's chance of mounting it.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 11th Jul 2016, 13:09   #6
DocJonz
DocJonz's Avatar
Good Point. I actually only use the desktop version, even on my server.
PS Nice to have the staff roaming this particular Forum
__________________
Folding stats
Old 11th Jul 2016, 13:18   #7
Gareth Halfacree
WIIGII!
bit-tech Staff
What can I say? I'll do anything to avoid doing actual work.
__________________
Old 11th Jul 2016, 16:26   #8
debs3759
debs3759's Avatar
Fortunately the array was set up in the BIOS, although it does use the Intel drivers in Windows.
I've downloaded Ubuntu, will try installing it later in the week.
Will also look at coolbits
__________________
HeatWare
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
