Go Back   bit-tech.net Forums > Partner Forums > Asus UK
Reply
Thread Tools
Old 16th Jul 2016, 00:59   #1
////\oo/\\\\
Hypermodder
////\oo/\\\\'s Avatar
////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!////\oo/\\\\ - it's over 9000!!!!!!!!1!1!1!!!
[SOLVED] Maximus VIII Formula problems
Ok, so this is really weird...
System build:
MB: Maximus VIII Formula
CPU: i7 6700k
Mem: Corsair DDR4 3466 4x8GB (running at standard speed at the moment, not 3466)
SSD: Samsung 850 EVO SATA (connected to SATA 1, have tried other ports)
GFX: not arrived yet so using the GFX built into skylake
So I've put the system together, it posts to BIOS, I can install Windows, but if I try to install any updates at all (tried ASUS MB CD drivers, ASUS online drivers, Microsoft auto updates, Microsoft manual updates), when it reboots I see the Windows loading screen, and then I lose the video signal...
Thoughts?
__________________
Squigg
////\oo/\\\\ is offline   Reply With Quote
Old 16th Jul 2016, 01:29   #2
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
The many joys of Windows 10, I'm afraid. You may need to reinstall Windows.
__________________
ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480@RX580 8GB with strap mod | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv TG | CM Masterkeys Pro L | Logitech G502 | Logitech G920 | ASUS ZenBook UX305F
TheMadDutchDude is offline   Reply With Quote
Old 16th Jul 2016, 10:19   #3
////\oo/\\\\
Hypermodder
It's a new build so a completely fresh install, I've started from scratch about 5 times now, same result every time. As soon as I try to load any update on reboot I lose video signal after the initial wondows loading page
Also, Windows can't see the LAN connection, can only use wireless? I think that might be related to the drivers, but then when I try to install any, we're back to the missing video signal issue...
__________________
Squigg
Old 16th Jul 2016, 10:53   #4
////\oo/\\\\
Hypermodder
And I've just noticed my spelling mistake in the thread title, damnit
It was late / stupid iPad spellcheck...
Fixed! (the spelling mistake)
__________________
Squigg
Old 16th Jul 2016, 18:45   #5
////\oo/\\\\
Hypermodder
Solved!
Video output was running through my AV amp, connecting it directly to the TV resolved the problem
__________________
Squigg
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
