Old 20th Jul 2016, 11:09   #1
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Failed to get assignment
According to this site BT Internet has a problem with one of their peering partners.
UPDATE: As of 10am, BT says the broadband outage is due to "power issues at one of our internet peering parters' sites in London" and that engineers are working on a fix.
This is probably why I cannot get a work unit at this time or upload my current completed unit:
08:49:28:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:49:28:WU00:FS00:Connecting to 171.67.108.204:80
08:49:32:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
08:49:32:WU01:FS00:Connecting to 171.64.65.92:80
08:49:49:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:37:05:WU01:FS00:Trying to send results to collection server
09:37:05:WU01:FS00:Uploading 5.42MiB to 171.65.103.160
09:37:05:WU01:FS00:Connecting to 171.65.103.160:8080
09:37:26:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
09:37:26:WU01:FS00:Connecting to 171.65.103.160:80
09:37:47:ERROR:WU01:FS00:Exception: Failed to connect to 171.65.103.160:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
I'm guessing when the others complete they will be the same.
__________________
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX 1080 Ti SLI; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Scorpuk is offline   Reply With Quote
Old 20th Jul 2016, 12:36   #2
Scorpuk
Hypermodder
Must be fixed now...
10:51:13:WU00:FS00:Connecting to 171.67.108.45:80
10:51:13:WU00:FS00:Assigned to work server 140.163.4.244
10:51:13:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 140.163.4.244
10:51:13:WU00:FS00:Connecting to 140.163.4.244:8080
10:51:14:WU00:FS00ownloading 2.54MiB
10:51:16:WU00:FS00ownload complete
10:51:16:WU00:FS00:Received Unit: id:00 stateOWNLOAD error:NO_ERROR project:10490 run:25 clone:0 gen:459 core:0x18 unit:0x000001ff8ca304f45537e8e0002117aa
10:51:16:WU00:FS00:Starting
__________________
Old 20th Jul 2016, 17:45   #3
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
Looks like I had a few issues as well.
However, there does appear to be an upload issue as well, which is not related Folding Forum thread.
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
