Go Back   bit-tech.net Forums > Partner Forums > Asus UK
Reply
Thread Tools
Old 30th Jul 2016, 12:47   #1
teamtd11
*Custom User Title*
teamtd11's Avatar
teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.
Asus z170 Sabertooth S - Assist fans never turn off
Hi, Strange issue with my Asus Sabertooth z170 S motherboard. When I shutdown the PC now, the assist fans never turn off. When I power the computer back on I get a anti-serge warning, Bought a brand new power supply but the issue is the same.
If after shutting down I turn the PC off at the wall, when I turn it back on again the next day all is okay, No anti-surge warnings.
I have tried this with a 650W Cyonic by Seasonic AU-650x, and a XFX 1050W power supply.
I have also reset bios to defaults with the onboard jumper.
Bios is the latest version.
Any Ideas? I have no issue with turning off at the wall on a night, its just strange.
__________________
i7 6700k @ 4.6Ghz - Asus Sabertooth Z170 S / EK Z170 S Monoblock - 16GB DDR4 3Ghz Corsair White LED RAM - GTX1080 Founders @ 2,126 MHz / EK Full Block
teamtd11 is offline   Reply With Quote
Old 2nd Aug 2016, 11:57   #2
Will_ASUSUK
Minimodder
Will_ASUSUK has yet to learn the way of the Dremel
Hi,
Apologies you are having issues, have you tried turning off surge detection in the BIOS?
Regards
Will_ASUSUK is offline   Reply With Quote
Old 2nd Aug 2016, 12:52   #3
teamtd11
*Custom User Title*
teamtd11's Avatar
Hi, Yes turning off surge protection in the bios stops the warnings on boots, and everything seams to work fine.
Am I fine running the machine with this disabled?
__________________
Old 3rd Aug 2016, 10:27   #4
Will_ASUSUK
Minimodder
Excellent, yes that is fine to run it without it on, sometimes it can be a bit sensitive. Regards Will.
Old 14th Aug 2016, 02:34   #5
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
For what it is worth, I think that it is a compatibility issue with the board and/or PSU. I have the Sabertooth Mark 1 in my current rig (for now) which portrayed a very similar issue to yours. Mine, however, would take anywhere from one to twenty (or more) quick power on/off cycles to just POST with a Corsair AX1200i. As soon as I swapped it for a Superflower 1200w unit, the issue disappeared immediately. The issue was still present, even when the surge protection was turned off in the BIOS. I thought it was just a misfortune on my half, but it wasn't.
I now have the surge protection enabled (because I thought I'd try it) and it has not tripped once since then. I wish I knew more on the matter, but I think it really is as simple as a compatibility issue, which is likely to be down to your board and PSU combo.
The only common thing I notice between your PSUs is that they are both made by Seasonic - XFX uses them as their OEM.
__________________
Gamer: ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480 8GB | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv Tempered Glass | Win 10 Home | CM Masterkeys Pro L | Logitech G502 | Logitech G920
Ultrabook: ASUS ZenBook UX305F
TheMadDutchDude is offline   Reply With Quote
Old 15th Aug 2016, 10:41   #6
teamtd11
*Custom User Title*
teamtd11's Avatar
Thanks for this. I still see the issue with the PC needing to be turned off at the wall to stop the assist fans spinning. This could be it as everything was fine with a corsair TX750 but it was the loudest thing in the PC. So I swapped it out.
Time to start selling these power supplies
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
