Go Back   bit-tech.net Forums > Modding > Watercooling: in association with Aquatuning
Reply
Thread Tools
Old 13th Aug 2016, 15:57   #1
Quantum-192
Modder
Quantum-192 has yet to learn the way of the Dremel
Waterfall Trickling Sound in Front Radiator
Hi all. Filled The loop on Evie today and started the bleeding which went surprisingly well and easy. Trouble is I've been left with a strange issue....
The top rad is perfectly quiet so I presume rid of air but on my front mounted radiator (Black Ice SR2 280) I have a small waterfall like trickling sound which I assume is due to a trapped air pocket at the top of the rad.
On this rad I have both the loop input and output at the top of the radiator with the output returning to the reservoir. I have tried all kinds of case tipping a pump pulsing but can't get rid of it.
Only thing I can think of now is cracking open one of the other radiator blanking plugs to try and bleed the air out that way (until coolant flows out)?
Any thoughts on this waterfall tricking sound and how to get rid of it as its the only thing stopping Evie running dead silent.
__________________
Project Evie Steampunk Build
Quantum-192 is offline   Reply With Quote
Old 13th Aug 2016, 17:32   #2
Big Elf
“not another f—-ing elf”
Big Elf's Avatar
Big Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming Saiyan
It will clear eventually but can take a long time. You can try laying the case on its side making sure you position the res so it doesn't leak and remove the res filler plug. Looking at your layout a length of tubing temporarily connected to the fill port might be safest way to avoid a spill.
Alternatively (after looking at the finished pics) send it to me to look after and start building a new one.
__________________
Case Labs TH10│Asus Rampage III Extreme│Core i7 990X│24GB Corsair Dominator GT│GTX Titan SLI│Samsung 850 EVO 256GB│Crucial M4│2TB Samsung Momentus x 2│SeaSonic P1000W│EK Supremacy│EK FC-RE3│EK-FC Titan SE x 2│EK-RAM Dominator│Black Ice SR-1 480 x 3│Swiftech 35X2
Big Elf is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
