Go Back   bit-tech.net Forums > Partner Forums > Asus UK
Reply
Thread Tools
Old 21st Aug 2016, 12:42   #1
ch424
Design Warrior
ch424's Avatar
ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.
VivoMini VC65 availability
Hi
I am quite interested in getting an ASUS VivoMini VC65. They're listed on the asus UK website but apparently not stocked anywhere. If you look on ebay there are various sellers in the USA and Spain. Are they going to be available in the UK at any point soon please?
Thanks
ch424
ch424 is offline   Reply With Quote
Old 16th Sep 2016, 14:15   #2
Will_ASUSUK
Minimodder
Will_ASUSUK has yet to learn the way of the Dremel
Hi,
I have just emailed one of our product managers as to why that might be. I will let you know on this thread by Monday. Have you tried CCL Computers as I think they have some in stock.
Kind Regards.
Will_ASUSUK is offline   Reply With Quote
Old 17th Sep 2016, 10:06   #3
ch424
Design Warrior
ch424's Avatar
Hi Will
Thanks for the update! Indeed - I see CCL have one model in stock. It's the version with an i3 and a DVD drive. Do you know if they are going to stock one of the 2- or 4-drive versions, and perhaps an i5/i7 model please?
Best wishes
Alex
Old 19th Sep 2016, 09:46   #4
Will_ASUSUK
Minimodder
Hi Alex,
I am not saure in regards to CCL.
icubes.co.uk have a configuration option that our product manager suggested. I think you can customise it.
Please see here: https://www.icubes.co.uk/sector/35/asusvivomini.aspx
Kind Regards.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
