Old 24th Aug 2016, 10:08   #1
redline11
What's a Dremel?
redline11 has yet to learn the way of the Dremel
Would it be ok
Hi All,
any help would be great i am thinking of buying
Bitspower Water TanK Z-Multi Ultra 150 POM Version
and
EK EK-DDC 3.25 12V DC Pump
Would they be good together?
thanks
redline11 is offline   Reply With Quote
Old 25th Oct 2016, 11:58   #2
bundymania
Bastelorakel Industries Worldwide
bundymania's Avatar
bundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremel
I donīt know but i can recommend something like this as a good alternative product:
http://www.aquatuning.de/water-cooli...phacool-ddc310
The pump is silent, because it runs with max. 3100rpm and it has a metal bottom for cool operation
bundymania is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
