Old 2nd Sep 2016, 21:14   #1
bigkingfun
Tinkering addict
bigkingfun's Avatar
bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.
Mobo center of mass
I realise this is not your average question, but would it be possible to get the data for a center of mass? Specifically for the X99-M WS?
I'm a mechanical engineer designing a custom case, and I would like precise data as I'm trying to shed weight, using topology optimization. Details available upon request.
Thanks in advance.
bigkingfun is offline   Reply With Quote
Old 16th Sep 2016, 14:21   #2
Will_ASUSUK
Minimodder
Will_ASUSUK has yet to learn the way of the Dremel
Hi Bigkingfun. I don't believe I could get hold of that information for you as it is not something we hold the specs for. By looking at the board it seems it is likely that the centre of mass is more likely going to be focused closer to the top left of the board. The best thing you can try is getting hold of one and testing it. Do you need it to have a centre of mass in the middle of the board?
Kind Regards.
Will_ASUSUK is offline   Reply With Quote
Old 6th Oct 2016, 15:27   #3
ferret141
Ultramodder
ferret141's Avatar
ferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyan
Do you own the board bigkingfun?
I take no responsibility for the consequences of the following advice from one mechanical engineer to another. I trust in your sensibilities.
Do it semi old school yourself.
Suspend the board from one of its mounting holes using a fixed pin that lets it spin freely
Take a photo of the board using a tripod or some other consistent method.
Draw a straight vertical line on the photo from the mounting point.
Repeat in other holes on the perimeter.
Superimpose your photos. The intersection of your lines is the centre of mass.
Instructions unclear, set fire to board
A la GCSE physics: http://www.bbc.co.uk/schools/gcsebit...ss/revision/1/
__________________
i5 2500K | Thermaltake Frio | 2x4GB Corsair Vengeance LP | ASUS P8P67 Pro | EVGA GTX680 2GB SC Signature 2 | Corsair AX1200 | 256GB OCZ Vertex 4 x2 R0 | 2TB WD Caviar Black | 3TB WD Red | SONY-NEC BD-5300S BD-RE | Silverstone Raven 2 Evolution (RV02E-BW USB3.0) | ASUS VG278H 3Dv2 | Win7 Ult. 64bit | Creative X-Fi Fatal1ty Platinum Champion Series | Speakers:Logitech G51 | Headset:Beyerdynamics DT770 Pro + ModMic 4.0 | Keyboard:Logitech G15 | Mouse:Logitech G9x
Plusnet | Loadout
ferret141 is offline   Reply With Quote
Old 12th Oct 2016, 20:34   #4
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Where do you have to place your finger for the board to balance on it?
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is offline   Reply With Quote
Old 12th Oct 2016, 21:24   #5
bigkingfun
Tinkering addict
bigkingfun's Avatar
That is actually a cool idea!
I do not own it (yet) but I'm doing the topology optimization with a simulated steel plate instead of a mobo, as a factor of safety
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
