Reply
Thread Tools View Mode
Old 27th Sep 2016, 17:17   #21
neSSa
Supermodder
neSSa's Avatar
neSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run Crysis
@amagriva, in that place I will add a lot of details, stay tuned
Transcend 370s, watch video
neSSa is offline   Reply With Quote
Old 28th Sep 2016, 14:46   #22
neSSa
Supermodder
neSSa's Avatar
How huge is this "Monsta" radiator
Old 29th Sep 2016, 14:51   #23
neSSa
Supermodder
neSSa's Avatar
Shift the panel (Mastercase 5 PRO)
Old 5th Oct 2016, 19:21   #24
neSSa
Supermodder
neSSa's Avatar
New parts have arrived
Lamptron CM430, HeatKiller CPU block and Mayhems UV die...
Old 8th Oct 2016, 20:16   #25
neSSa
Supermodder
neSSa's Avatar
Case panels prepared for cutting ...
Old 9th Oct 2016, 12:21   #26
neSSa
Supermodder
neSSa's Avatar
Results after trim away parts of case, not many left
Old 10th Oct 2016, 12:19   #27
neSSa
Supermodder
neSSa's Avatar
Lamptron CM430, perfectly fit in my project, blue gear-wheels mmnjamm
Old 11th Oct 2016, 11:11   #28
neSSa
Supermodder
neSSa's Avatar
HeatKiller IV...
Old 12th Oct 2016, 13:27   #29
neSSa
Supermodder
neSSa's Avatar
Alphacool fittings ..
Old 13th Oct 2016, 12:33   #30
neSSa
Supermodder
neSSa's Avatar
PCIe riser has arrived
Old 15th Oct 2016, 07:43   #31
neSSa
Supermodder
neSSa's Avatar
Creating panels, front side, back side and the middle, small part is a new PCIe cover
Old 16th Oct 2016, 11:53   #32
neSSa
Supermodder
neSSa's Avatar
Asus Strix GTX970 arrived...
Old 17th Oct 2016, 16:31   #33
neSSa
Supermodder
neSSa's Avatar
New PCIe cover is finished
Old 19th Oct 2016, 18:50   #34
neSSa
Supermodder
neSSa's Avatar
Basic elements is finished, 2mm aluminum, laser cut
Old 20th Oct 2016, 17:33   #35
neSSa
Supermodder
neSSa's Avatar
My new toy,"Dremel 3000", and litle more handmade brush
Old 21st Oct 2016, 15:14   #36
neSSa
Supermodder
neSSa's Avatar
Progress ...
Old 22nd Oct 2016, 15:07   #37
neSSa
Supermodder
neSSa's Avatar
progress ...
Old 23rd Oct 2016, 14:47   #38
neSSa
Supermodder
neSSa's Avatar
GPU progress ...
Old 24th Oct 2016, 22:03   #39
neSSa
Supermodder
neSSa's Avatar
Alphacool radiators and pump, postition test ...
Old 25th Oct 2016, 17:30   #40
neSSa
Supermodder
neSSa's Avatar
Final cutting, fitting, drilling, and preparation for powdercoating...
Reply
Tags
aardvarks and aasvogels
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
