Reply
Thread Tools View Mode
Old 5th Dec 2016, 15:02   #81
neSSa
Supermodder
neSSa's Avatar
neSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run CrysisneSSa can run Crysis
Work on front panel grill
neSSa is online now   Reply With Quote
Old 5th Dec 2016, 20:38   #82
kim
Multimodder
kim has yet to learn the way of the Dremel
pure awesomeness...your Chrono-master makes me think of a time machine!!! this is a real masterpiece , i love it...
kim is offline   Reply With Quote
Old 6th Dec 2016, 13:38   #83
neSSa
Supermodder
neSSa's Avatar
Thank you @kim
Work on AIO panel
Old 7th Dec 2016, 16:27   #84
neSSa
Supermodder
neSSa's Avatar
A quick look at AIO panel
Old 8th Dec 2016, 06:58   #85
storm-83
Supermodder
storm-83's Avatar
storm-83 has yet to learn the way of the Dremel
I want to watercool my pc soooooo badly - only because i want the chance to incorporate a temp and pressure gauge!
I like this build very much. there are a lot of details to look at, without it being too crammed.
Looking forward to seeing some motion on those gears on the front
__________________
storm-83 is offline   Reply With Quote
Old 8th Dec 2016, 18:07   #86
neSSa
Supermodder
neSSa's Avatar
Thank you @storm-83, I'm glad you like it, good luck with your build!
Here is a brief look of the front panel, the making of the front mask is coming up and so do other details....
Old 12th Dec 2016, 20:10   #87
neSSa
Supermodder
neSSa's Avatar
Old 15th Dec 2016, 16:38   #88
neSSa
Supermodder
neSSa's Avatar
work on details
Old 17th Dec 2016, 08:22   #89
neSSa
Supermodder
neSSa's Avatar
Old 17th Dec 2016, 13:40   #90
neSSa
Supermodder
neSSa's Avatar
some work...
Old 17th Dec 2016, 18:46   #91
Polarblair
What's a Dremel?
Polarblair's Avatar
Polarblair has yet to learn the way of the Dremel
The refinement in this build is something else. You're customizing parts I hadn't even considered modding before. Some strong pornography right there
Polarblair is offline   Reply With Quote
Old 18th Dec 2016, 17:20   #92
neSSa
Supermodder
neSSa's Avatar
https://www.facebook.com/sspcmodding...4998021677833/
Old 18th Dec 2016, 19:20   #93
Sharangir
Minimodder
Sharangir has yet to learn the way of the Dremel
love the craftsmanship!!!
But, what is preasure? (has that been asked before?)
Sharangir is offline   Reply With Quote
Old 18th Dec 2016, 19:55   #94
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Serbian pressure
I like the volt meter and mod, would have liked to have seen how to do it though.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 18th Dec 2016, 20:23   #95
neSSa
Supermodder
neSSa's Avatar
Originally Posted by Vault-Tec View Post
Serbian pressure
Yes, yes, this is my mistake, i changed it to "pressure"
Old 18th Dec 2016, 20:34   #96
Vault-Tec
Vault-Tec's Avatar
Actually I have a spare volt meter. Might pull it apart tomorrow
__________________
MUWC Winner ROTT
Old 22nd Dec 2016, 17:51   #97
neSSa
Supermodder
neSSa's Avatar
"Chrono Master" project is finished!
The final photos and video will be uploaded on January 7th 2017
Old 27th Dec 2016, 11:05   #98
neSSa
Supermodder
neSSa's Avatar
Little secrets
Old 31st Dec 2016, 11:42   #99
neSSa
Supermodder
neSSa's Avatar
Little secrets 2
Old 4th Jan 2017, 09:58   #100
neSSa
Supermodder
neSSa's Avatar
Coming up in three days
Reply
Tags
aardvarks and aasvogels
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
