Go Back   bit-tech.net Forums > Partner Forums > Asus UK
Reply
Thread Tools
Old 30th Oct 2016, 17:39   #1
rainbowbridge
Banned
rainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyan
asus x99 delux-replacement will pick up current raid 1
Hello Asus.
Raid question when swapping out for a repaired or replacement..
For the Asus X99 Delux (excellent board recommend) I have a nicely set up RAID 1 with two small drives.
If I put in a replacement or repaired Asus X99 Delux (system fault, inside warranty) once I get it back from the vendor. Will it automatically pick up the current RAID 1?
In the BIOS under EZ mode, I do not see any option to save the RAID config out to a USB drive.
So in short if you take your ASUS X99 send it for a repair or replacement, when it comes back will it automatically pick up the current Raid 1 set up (read off the drives?) If not how do I back up my raid config to hopefully import into my replacement Asus X99-Dulux.
Thank you,
rainbowbridge is offline   Reply With Quote
Old 30th Oct 2016, 18:22   #2
noizdaemon666
I'm Od, Therefore I Pwn
noizdaemon666's Avatar
noizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyan
Short answer; yes. Just set SATA ports to RAID on the replacement board and it should pick up form where it left off.
noizdaemon666 is offline   Reply With Quote
Old 30th Oct 2016, 18:33   #3
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
It should do, yes. I swapped from a SOC Champion to the ASRock ITX board and it recognised it as soon as I set the BIOS to RAID. All data in tact, which I was most surprised by as it is a RAID0 array after all. As long as the chipset is the same, so X99 > X99, you should be absolutely fine.
__________________
ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480@RX580 8GB with strap mod | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv TG | CM Masterkeys Pro L | Logitech G502 | Logitech G920 | ASUS ZenBook UX305F
TheMadDutchDude is offline   Reply With Quote
Old 30th Oct 2016, 18:51   #4
rainbowbridge
Banned
Thank you guys, have a nice week.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
