Reply
Thread Tools View Mode
Old 3rd Mar 2017, 09:55   #21
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Some one had to ask.. Did you make that panel out of alu or is it just covered in brushed vinyl?
Brushed vinyl is so good these days that it's almost impossible to tell.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 3rd Mar 2017, 10:39   #22
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
That's proper aluminium that.
I've got some brushed vinyl around still from Moderne, it's good stuff, although doesn't look nearly as good as the real thing up close.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: I Need Healing!, Parvum Argentum, Tower Level 10
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 3rd Mar 2017, 10:43   #23
Vault-Tec
Vault-Tec's Avatar
Nice
__________________
MUWC Winner ROTT
Old 20th Mar 2017, 15:33   #24
Maki role
Maki role's Avatar
So the date for some big stuff is drawing closer. So indeed it is now time to get some of the individual mods done, first up, the GPU!
__________________
Old 20th Mar 2017, 21:22   #25
Bartacus
Supermodder
Bartacus's Avatar
Bartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming Saiyan
Nice work on the GPU! Love the silver blades!
Bartacus is offline   Reply With Quote
Old 23rd Apr 2017, 23:40   #26
Maki role
Maki role's Avatar
Well I'm hoping the next 7 days to be a VERY busy week indeed.
I think it's about time this little build was finished off eh? So how about by starting with one of the major thematic elements of the interior, the glowing katana!
Big shout out to Parvum Systems for helping me get these parts cut. These particular ones could have been done fine by hand, but I added them to the cutting list for simplicity as then I know everything will be done just right. That said, there was a huge amount to do to the pieces afterwards.
It's a perfect cut, but because it was a quick pass it's rough as hell. Lots of work with files and sanding ahead
Sanding and polishing done, now to prime for paintwork
Paint on and now you can see the buffed up aluminium.
And with the blade section attached. This is opal acrylic, so the lights underneath will cause the blade to glow
Okay, I'll fess up, why on earth did I show you a lighting feature... with no lighting? Where's the damn glowing sword!?
Well simply put, I don't have any glowing lights I can use right now They'll be going into the build alright, but I don't have them external atm.
__________________
Old 24th Apr 2017, 12:00   #27
Vault-Tec
Vault-Tec's Avatar
I have no idea what that is, but it looks to be well done
__________________
MUWC Winner ROTT
Old 24th Apr 2017, 12:25   #28
Maki role
Maki role's Avatar
Haha, it's going to be the side panel for the PSU cover. There'll be RGB LEDs underneath the opal acrylic meaning the blade itself will glow however you wish.
Took a long time to paint and polish that piece. Went through 80/120/180/320/500/1000/2000 grits first then finished with 6000 grit polish on a sponge and then 11000 grit polish on a lambswool pad.
__________________
Old 24th Apr 2017, 12:39   #29
Vault-Tec
Vault-Tec's Avatar
I got the PSU cover part, just no idea what it is. Looks like a saw that Kenny Everett would have used in one of his Reg sketches
__________________
MUWC Winner ROTT
Old 27th Apr 2017, 20:28   #30
Maki role
Maki role's Avatar
And so with the next update we go!
So I went and gutted the case even further so as to make room for the new rear panel. I also went and installed most of the internal panels and structure, need to make sure everything fits perfectly before I begin painting. Things are starting to look distinctly more case-like finally.
__________________
Old 27th Apr 2017, 21:12   #31
C4B12
Minimalistic PC's
C4B12's Avatar
C4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on you
Nice job! I recently put together a Overwatch themed build too, for work though.
__________________
Scratch builds | The Red One | Cold Winter | CURV3D | C.ACE | SAIL |
Casemods | BarPC | F4DE | Spec-Edge |
Check out Minimalistic PC for news about modding and different projects!
C4B12 is offline   Reply With Quote
Old 10th May 2017, 17:26   #32
Maki role
Maki role's Avatar
After spending a while prepping everything, London got hit with the classic curse of cruddy weather. Unfortunately my workshop is now incredibly dense so painting case panels in it is simply not a good idea, so that means painting outside for now, not so good if it's constantly raining and/or windy.
Thankfully the weather recently relented and we got some honest sunshine and respite from the wind! So now the case is all primed and ready for painting the final coats. Naturally the paint I was originally using is no longer bloody available, so I caved and got a new spraygun system so that I can ditch cans and switch to proper stuff. I put in an order for a load of paint for a few builds, which should arrive Wednesday I think?
So in the meantime, I'll be working on the interior finishing touches and getting those out the door.
__________________
Old 19th May 2017, 17:08   #33
Maki role
Maki role's Avatar
W00t w00t, this is a fairly important update for the log but a bigger one for me.
So you may ask, why does it take so long to paint a case? Well that would be because the paint I was using ran out of stock... everywhere it seems, and it's been raining so so so much over the last few weeks.
So I had to combat this. Until now, I had to paint large parts (like side panels etc.) outside thanks to ventilation and overspray. Thanks to the terrible weather this simply wasn't possible. As luck would have it, on the good days a couple weeks ago there was no paint available near me.
So I took a bit of a jump and instead bought an HVLP automotive paint gun and a nice, large catering shelf to use as a spray booth. Along with the gun I picked up some white car paint and thinner. Anybody reading this who's made a similar jump or works at a business that paints items will know just how much of an improvement this is over rattle-cans.
So I now have the ability to paint larger items quicker, with a higher quality finish, cheaper, indoors and in a larger variety of colours and effects! The number of positives there is mind blowing.
Progress wise the painting is now 100% complete, I'm leaving it with a matte finish so as to match the acrylic. I've also done 90% of the cabling, will be photographing that next. So in short, this build is finally, after all these months, very close to completion!
__________________
Old 19th May 2017, 17:16   #34
Bartacus
Supermodder
Bartacus's Avatar
Very nice! You're stepping up your already impressive game.
Old 19th May 2017, 17:55   #35
Maki role
Maki role's Avatar
Just wait until you see what I have planned for the summer/autumn haha
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
