Old 27th Nov 2016, 11:48   #1
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Back folding
Took a break from folding, but decided to come back. Probably going to be on and off, but should have 2 x GTX970's folding 24/7 and my Titan X Pascal when I'm not playing games.
Was thinking on replacing my GTX970's so had a look at costs:
Sources:
Average PPD - GPU PPD Database *Mostly overclocked cards
Prices - Overclockers.co.uk *There are other e-tailers out there who maybe cheaper!
Estimated Power consumption - Tomshardware.co.uk *Searched for stress testing with overclock power consumption and used this one source.
/KWh - Sust-it.net *UK Tariff Average for September 2016
Notes:
The GTX9xx are highlighted as e-bay was my only source for price and I took a low average from there. (Some insane prices there for outdated cards)
Estimated power is for GPU only, I think, so there might be aditional power for all other components not taken into consideration. (i.e. Yearly Cost could be slightly higher.)
Excel Spreadsheet: Download
__________________
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX 1080 Ti SLI; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Last edited by Scorpuk; 27th Nov 2016 at 11:59. Reason: Added link to excel spreadsheet
Scorpuk is offline   Reply With Quote
Old 27th Nov 2016, 13:29   #2
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
Good to have you back from your short break
Your spreadsheet looks like the ones I produce when toying with a new GPU
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 29th Nov 2016, 10:55   #3
Scorpuk
Hypermodder
Just realised GTX1060 comes in 2 flavours. Not only is memory reduced, but number of cores is too.
3Gb - Stream Processors: 1152
6Gb - Stream Processors: 1280
This drops the /ppd and makes the GTX1070 more favourable, but higher yearly costs than 1060.
__________________
Old 29th Nov 2016, 18:47   #4
DocJonz
DocJonz's Avatar
The vanilla GTX 1070 has a TDP of 140W rather than 180W - that improves things
__________________
Folding stats
Old 29th Nov 2016, 22:00   #5
Scorpuk
Hypermodder
Can you go over the TDP if you overclock?
__________________
Old 30th Nov 2016, 07:40   #6
DocJonz
DocJonz's Avatar
My understanding is yes. Pushing the voltage up can massively increase power consumption and take the over-clocked part over its TDP.
__________________
Folding stats
Old 1st Dec 2016, 12:57   #7
Scorpuk
Hypermodder
Well went for a GTX1070; GeForce GTX 1070 AERO 8G OC 8192MB GDDR5 PCI-Express Graphics Card.
Strange thing is the spec says it runs at Boost Clock: 1721MHz, but nvidia-settings is reporting 1830MHz; 1936MHz max.
Got a question for ya Doc.
I've put this in my Ubuntu Server, but not sure how I go about overclocking 2 cards where one of them is not connected to a monitor.
I tried:
Code:
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    Option         "Coolbits" "31"
    BoardName      "GeForce GTX 1070"
    BusID          "PCI:1:0:0"
EndSection
Section "Device"
    Identifier     "Device1"
    Driver         "nvidia"
    BoardName      "GeForce GTX 970"
    BusID          "PCI:2:0:0"
EndSection
But that didnt work.
GTX1070 I can change the fan speed, but not the clock
GTX970 I can change nothing.
Cheers.
EDIT: Power consumption not bad for GTX1070 & GTX970. (Also have 15 HDD's in the server )
Needs a bit more cooling. Both cards @ 81C.
__________________
Old 1st Dec 2016, 16:31   #8
Scorpuk
Hypermodder
Woo Hoo.
Found out how to overclock 2nd or more GPU's in Ubuntu from this site: https://forum.ethereum.org/discussio...dia-for-miners
My xorg.conf ended up as:
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" 0 0
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "HannStar Display Corp Hanns.G HH191"
HorizSync 31.0 - 82.0
VertRefresh 56.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:2:0:0"
Option "ConnectedMonitor" "DFP-0"
Option "CustomEDID" "DFP-0:/etc/X11/edid.bin"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "nvidia-auto-select +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Option "UseDisplayDevice" "none"
EndSection
Thankfully this allowed me to put the fan of the GTX970 to 100% and stop the throttling.
Hopefully all good now.
__________________
Old 1st Dec 2016, 22:35   #9
DocJonz
DocJonz's Avatar
Glad you got it working. (I couldn't remember the Coolbits value for accessing two cards with fan control ....)
__________________
Folding stats
Old 1st Dec 2016, 23:28   #10
Scorpuk
Hypermodder
Cheers Doc.
It wasnt coolbits for 2 cards, but working out how to fake a monitor attached so the coolbits work. No monitor, no coolbits.
31 is probably overkill and 12 would suffice.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
