Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 15th May 2017, 16:50   #561
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
Even this year's uber ultra softs are fairly resilient compared to the last few years where they were basically ****ed after 1 lap.
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is offline   Reply With Quote
Old 15th May 2017, 17:05   #562
javaman
May irritate Eyes
javaman's Avatar
javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.
I some ways its better as they don't have to nurse the tires they can push more. Still a difficult balance between forcing pit stops and allowing the drivers to push all the time
javaman is offline   Reply With Quote
Old 15th May 2017, 17:32   #563
wolfticket
Downwind from the bloodhounds
wolfticket's Avatar
wolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyan
I bet a lot of the people complaining about it being processional because the tyres are lasting are the same people complaining last year about drivers not being able to push because of the tyres not lasting. F1 is like that.
__________________
Wolfticket: Ambitious but rubbish
"A facility for quotation covers the absence of original thought."
Dorothy L. Sayers (1893 - 1957)
wolfticket is offline   Reply With Quote
Old 15th May 2017, 17:44   #564
Wakka
Yo, eat this, ya?
Wakka's Avatar
Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.
2010 proved you don't need gimmicky tires to have a solid season of racing.
__________________
Intel 7600K @ 4.5Ghz - Asus Strix Z270I - Asus Strix GTX 1060 - 16GB HyperX 2400Mhz - Samsung 250GB 960 EVO / 500GB 850 EVO - Corsair AX750 - Phanteks Evolv ITX - Corsair H80i V2
Acer Predator XB240H - Corsair K65 / M65 / Void Wireless / MM300
Wakka is offline   Reply With Quote
Old 15th May 2017, 17:55   #565
fix-the-spade
Mod Master
fix-the-spade's Avatar
fix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyan
I'm of the opinion that Pirelli should make just two compounds, a hard and a soft, the difference between the two should be massive (several seconds per lap) and the same same two compound tyres should be taken to every race. It would leave teams (especially Merc/Ferrari) more vulnerable to changes in temperature and surface, instead of all the cars having the 'ideal' tyre at each race.
The current spread makes set up and strategy too easy to optimise. If I was being really evil I'd allocate two sets of softs and one of hard for qualifying. So top teams could either run hard in Q1 and risk being knocked out, or be left with two sets of worn softs for Q3.
__________________
CMDR Fix-the-spade
fix-the-spade is offline   Reply With Quote
Old 15th May 2017, 18:03   #566
RedFlames
RedFlames's Avatar
I'd personally like to see the 'both compounds' rule dropped, even if only for those outside the top 10 in qualy... in this race [wehrlein] and the last [hulkenberg] we had a car/driver well ahead of where you'd normally expect it, only for them to lose the place due to having to change to a different tyre.
Both times I wondered if they could've held on had the not had to pit.
So yeah, if a back of the field team wants to have a punt on doing the entire race on one set of tyres... I say let them.
__________________
Old 15th May 2017, 18:18   #567
yodasarmpit
No longer the other Brett.
yodasarmpit's Avatar
yodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyan
Agreed on the nonsense of forcing the use of both compounds, have two sets of compound available to each team throughout the year and let the teams make the appropriate choice on race day.
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home"
yodasarmpit is online now   Reply With Quote
Old 15th May 2017, 20:30   #568
The_Crapman
Don't phone it's just for fun.
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Mclaren's communication officer is an complete buffoon. He tweeted the the sky F1 team during quali to correct them in that luke skywalker used PHOTON torpedoes to blow up the death star...... Cretin.
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 15th May 2017, 20:31   #569
RedFlames
RedFlames's Avatar
__________________
Old 16th May 2017, 05:21   #570
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Really? Why didn't he just get Chief O'Brien to beam him in with a team to plant explosives instead?
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|980 Ti|3007WFP-HC|Parvum S2.0
David is online now   Reply With Quote
Old 16th May 2017, 09:29   #571
David
RIP Tel
David's Avatar
According to an interview with the daily fail, JB still had options for a drive as late as January, from two teams - apparently meaning both Williams and Mercedes approached him prior to the Bottas deal, as they were the only two who hadn't finalised their driver line-up by January.
__________________
Old 16th May 2017, 09:34   #572
legoman
breaker of things
legoman's Avatar
legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.
Because Kryton was helping Tuvok fix the hyperdrive on Serenity of course!
__________________
Taurus excreta cerebrum vincit
Fractual Core 500|Gigabyte GA-F2A88XN-WIFI|Athlon X4 860K|noctua nh-u9s|MSI 480 4Gb|Kingston HyperX Beast 8Gb|Sandisk 240Gb|Crucial BX300 240Gb|Samsung F1 1Tb|
legoman is offline   Reply With Quote
Old 16th May 2017, 11:08   #573
javaman
May irritate Eyes
javaman's Avatar
TBH I'd be surprised if Button wasn't considered even at the bottom of the short list of suitable drivers for both teams.
Ruling out drivers who were locked into F1 race seat contracts Button, Di Resta, Massa, Gutierrez would of been top of the list of drivers I would of went to
Old 16th May 2017, 12:04   #574
Wakka
Yo, eat this, ya?
Wakka's Avatar
Originally Posted by javaman View Post
Di Resta, Gutierrez
I would rather put Ronald McDonald in my car and reap the sponsorship money than either of those 2, personally!
Di Resta wasn't a bad driver, but had a rotten attitude when things didn't go his way and was possibly the most boring bloke in the entire F1 paddock.
Gutierrez has had some bad luck in his time, but the amount he got out-scored by Hulk and Grosjean accounts for far more than just luck imo...
Vergne, Kobayashi, Nasr, Glock or even Petrov would get preference if I was writing up the contracts
__________________
Old 16th May 2017, 13:40   #575
javaman
May irritate Eyes
javaman's Avatar
Di Resta: Yea could of done better. Was expecting a lot more from him tbh.
Gutierrez: Agreed. Never really rated him highly but still thought he was better than most other drivers of the last few years. As a stop gap he would of done ok if you couldn't get anyone else and exhausted most other options.
Nasr: I personally wouldn't even shortlist him. liked him more than Ericsson but I never rated him either.
Kobayahi: Had his moments but several races he really under performed. Would be nice to see him back but donno how to rate him.
Petrov: Forgot about him. Solid wouldn't be a bad choice. SImilar to Gutierrez.
Glock: I would argue he has been away from F1 too long now. From memory he was a victim to the pay driver glut that seemed to increase the years following Virgin, Lotus/Caterham and HRT joining. I remember his time at Toyota and he was solid but he seemed to fade being stuck in the Virgin. Donno how to rate him now.
Vergne: Him and Buemi I would have fairly high up of drivers to try and pry away before getting stuck into unattached drivers. TBH they would be after Sainz, Alonso, Verstappen, Riccardo, Vettel and Raikkonen on the list of "unrelistic targets that I'd be stupid not to try anyway list"
Alguersuari (if you could unretire anyone) might of been worth a punt.
Many drivers tho I would probably have settled with Wherlin or Occon than put any effort or fee towards getting. They're both fairly good drivers that most mid teams would love to have. TBH I would rate them almost as high as Bottas. Certainly Occon has shown good performance compared to Perez. If he remains there for next season and keeps the consistency I can see him getting the nod sooner rather than later.
Old 16th May 2017, 22:00   #576
RedFlames
RedFlames's Avatar
Photographer Shoots Formula 1 With 104-Year-Old Camera
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
