Windows Can't open the document
Discussion in 'Software' started by martin0, 21 Dec 2016.
  1. martin0
    martin0 What's a Dremel?
    20 Dec 2016
    Hello,
    Has anyone any experience MS Word error: Can't open the document. If so could you help point me in the right direction? How to repair word?
    Any help would be appreciated.
  2. adoria
    adoria What's a Dremel?
    5 Jan 2017
    In a networked environment, Microsoft Word locks data files on a network preventing them from being edited by more than one person at a time. This prevents users from simultaneously making changes to a file, which can cause confusion and data loss.
    If a user tries to open a file on a network and the file is locked, Word will display a dialog box informing the user that someone else is using the file. The user can either wait until the current user exits the file, or they can open a copy of the file to make changes on. The user can then save the changes in a different file.
  3. martin0
    20 Dec 2016
    I want to say thank you for taking the time to share how to go about fixing this.
  4. slimithy
    slimithy Minimodder
    20 Aug 2014
    Does it open in Libre office?
  5. John55
    John55 What's a Dremel?
    23 Jan 2017
    DOCX-files open in OO and LO. But sometimes the formatting is a bit of. That's my experience.
  6. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    It might help if you were to include the error message when attempting to open the file, and as adoria pointed out, if it was a file on a network share, then you should see a copy of the auto-recover file in Windows Explorer. The file icon will be opaque and normally starts with ~$ (TIP: you'll need Windows Explorer view to display hidden files)
    If it is a network file, your IT dept should be able to tell you who has the file open. Unless you're a domain admin yourself in which case open computer management, connect to the file server and view open sessions.
